How do I perform window parameterization? - Mercedes Benz SLK Forum
 7Likes
  • 1 Post By Gary545
  • 1 Post By curro101
  • 1 Post By Seanhump
  • 1 Post By PaulRUK3
  • 1 Post By jbanks15
  • 1 Post By craiggraf
#1 Old 03-30-2017
PaulRUK3's Avatar
Vehicle: R171 SLK350 (2004) Black, 7G-Tronic, Airscarf, Parktronic, Red Heated Seats, AMG Bodykit, STUNNING!
Other Toys: C320 (W203 2000) Auto, Sadly Departed R170 SLK320 (sob)
Quoted: 17 Post(s)
I am slowly trying to sort out minor niggles with my new Black Beauty and one of the things that doesn't work is the remote opening of the roof (it does have the 880 option code). Now, I realise that this has been covered at length, but, one thing that popped up in my trawl of the internet was a bulletin dating back to 2004 titled 'Vario Roof Cannot Be Opened / Closed Via Infrared Function (Code 880)' and what to do about it, so I thought I would start with that. One of the stages is to perform parameterization of the windows. I have a (copy) Star/DAS/Xentry with developer mode, so I tried to do this. Whilst I do have a basic knowledge of it, there was not an option to perform parameterization. Any ideas at how to do this please?
PaulRUK3 is offline
#2 Old 03-30-2017
Quoted: 2213 Post(s)
Not heard that phrase before.
There is a windows resynch that doesn't need DAS and is done with the window buttons.
Try this lot for the one I mentioned.
Mercedes Benz SLK Forum - Search Results for slkworld.com synching windows
Have your read through the forum DAS threads?
DAS/STAR Coding - Mercedes Benz SLK Forum
#3 Old 03-30-2017
Vehicle: 2009 SLK 200K, Palladium Silver
Other Toys: Honda VFR 1200 Crosstourer DCT
Quoted: 15 Post(s)
Hi Paul, I've also got option code 880 and it only works if you stand very close to the drivers door and keep your key pointing directly to the sensor on the door handle whilst continuously holding the unlock button on your? key.
If you hear an alarm coming from inside the car while doing this then there will be a message on the dash display such as boot partition not closed.
Good luck with getting it sorted.
Gary545 is offline
#4 Old 03-30-2017
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
As Avel Du mentioned, are you sure it's not referring to the window re sync?
With the ignition in 2nd position, close the doors and then push and hold the down button, continuing to hold it down 3-4 seconds after it reaches the bottom, repeat in the upwards direction and then for the passenger side.
Have you thought about fitting a smarttop, it's much less hassle to use and better than the factory system?!
curro101 is offline
#5 Old 03-30-2017
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 424 Post(s)
The factory remote roof operation is next to useless ...
A Smarttop is needed!!
And +1 to the instructions above - DAS isn;t needed for those ...
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is offline
#6 Old 03-31-2017
PaulRUK3's Avatar
Quoted: 17 Post(s)
Yes, done the resynch. This is the link to the bulletin:
http://www.billsden.org/fileadmin/me...b_77_39_31.pdf
Yes, successfully enabled both fog lights, enabled cornering fogs (even though my car has cornering fogs but it wasn't enabled for some reason), and more by luck than judgement ('cos Xentry was in German after a certain point) successfully changed kph in the lower MFD to mph (even though I was following the instructions for changing the display to show temp in the lower MFD and still not managed it.....!)
PaulRUK3 is offline
#7 Old 03-31-2017
PaulRUK3's Avatar
Quoted: 17 Post(s)
I have closed the partition and held the keyfob as close as 1mm from the sensor. There is no alarm and nothing in the display.
PaulRUK3 is offline
#8 Old 03-31-2017
PaulRUK3's Avatar
Quoted: 17 Post(s)
I don't know if it is referring to the re sync or not, I was just following the bulletin. Surely though, if it was referring to the re sync, it wouldn't be telling me to use STAR to do "parameterization"?
I agree about a SmartTop, however, I am one of these anal people that thinks that if something SHOULD work, it MUST work!! I am saving the biggest and probably the most difficult task until last, an inoperable heated driver's seat.....
PaulRUK3 is offline
#9 Old 03-31-2017
Quoted: 6460 Post(s)
clean the sensor?
get a smarttop? it uses rf instead of ir
Seanhump likes this.
#10 Old 03-31-2017
Vehicle: 2005 SLK350 Automatic; Comfort package, Premium package, 6 disc changer, heated seats. Black on bla
Quoted: 37 Post(s)
Another Mercedes "feature" that is totally useless as Seanhump points out. What a sad testimony to what is supposed to be superior German engineering. If you don't mind standing outside your car for 22 seconds while holding your key fob two inches away from your door handle, I suppose you get what you deserve.
carguy is offline
#11 Old 03-31-2017
Quoted: 15 Post(s)
You don't even know me, so how do you know what I Deserve ?
Gary545 is offline
#12 Old 08-21-2017
Vehicle: 2006 SLK55 Silver
I also know that if your battery (12v vehicle battery) is a bit low, the roof will not raise or lower with the IR remote.
craiggraf is offline
Driver window won't close steve010 SLK R171 General Discussion 24 12-03-2017 01:03 PM
Side window question Dr Tomato SLK R170 General Discussion 13 06-22-2017 02:23 PM
Window problem it only goes one way and the solution Vilse.se SLK R170 General Discussion 4 06-21-2017 12:13 PM
Vario-Roof / Window issues Lioninstreet SLK R171 General Discussion 44 04-28-2015 10:48 PM
Window adjustment/wind noise diagnosis Michelle's SLinKy SLK R171 General Discussion 16 04-09-2015 07:40 AM
