Door control module (DCM) - Mercedes Benz SLK Forum
  • 1 Post By curro101
#1 Old 10-09-2015
Vehicle: 2005 SLK 280
Other Toys: pick up truck
Quoted: 12 Post(s)
According to MB, the DCM needs replacing for the central locking via the key fob to work again, just the drivers door (LHD) central ocking on the passenger door works fine.
They changed out the actuator behind the door lock saying you always replace this first to see if it solves the issue, it did not, we had to pay for it anyway, and a perfectly good part has been trashed (alarm bells started ringing) as the quote for the DCM replacement is not cheap.
They broke 2 clips or the door panel and never replaced them, and ripped the crap out the door liner behind the panel, and just stuffed it in a hole in the door....(have pictures of this cowboy workmanship btw)
2005 slk 280 with only 14000 miles on it,its mint, full MD service history, they are animals, they will never see that car again (wife is mortified)
So basicly if I replace this part, what else is needed to finish the job coding wise? did read an article saying you can sometimes wipe and re-code the DCM, and it may work, or just fit a new one...
kev
kevf is offline
#2 Old 10-09-2015
Quoted: 12 Post(s)
Have done a search, and the previous time these pesky DCMs came round before, there was no conclusion to the threads, and conflicting information, someone said they are plug and play, and someone else says they have to be coded via das3 I assume (dont quote me, as this is what im trying to find out.......)
kevf is offline
#3 Old 10-10-2015
Quoted: 12 Post(s)
Anyone at all on this simple one? is the DCM plug and play, or does it have to be coded? if I replace it myself to keep the door card cowboys at bay...
kevf is offline
#4 Old 10-10-2015
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Sean gave an answer here :
https://www.slkworld.com/slk-r171-gen...ol-module.html
Basically meaning , if you buy a new one , it'll need programing by DAS , if you get a used one , so long as it came from a car with the same extras as yours , ie door puddle lights , you should be ok , only if you have more/different options than the car the module came from , will you need to get it coded to activate those options , otherwise it should be ok ....
kevf likes this.
curro101 is offline
#5 Old 10-10-2015
Quoted: 12 Post(s)
appreciated, did not find that post via search, absolutely no chance of finding an indy where I live, will take it to another MD further away, and get it replaced and coded, only just getting involved with the car due to the wifes upset with the original MD, huge learning curve on this car electricly, very minimum electrical options on this one, due to me asking them to take out as much as possible (jammed sunroof on an older merc) never realised` how much a laptop has you by the balls on these cars nowdays.
kevf is offline
SLK Cabrio-Module-de installation Aycee SLK R170 class DIY 5 05-13-2016 11:10 PM
Acronyms, TLA's and other abbreviations Seanhump General Discussion 3 11-20-2014 06:06 PM
Roof Stuck Open, Has My Piecha Module Failed? shark SLK R171 General Discussion 21 09-16-2012 02:43 AM
Stereo wiring and a roof module?! Help! jfb1977 General Modifications R171 0 08-22-2008 10:44 AM
Help! Can Comfort Vario Roof Module cause Transmission Problem? ericmb SLK R171 General Discussion 12 04-19-2007 02:01 PM
