trouble codes c1210, c1707 and c1100 - Mercedes Benz SLK Forum
#1 Old 01-21-2015
Vehicle: 05 slk350
Other Toys: 95 eclipse gst, 99 expedition, 02 accord, 02 maxima
I just got these codes and I'm searching online, but can't get an exact description of what part is the problem to fix it.
tnsr35 is offline
#2 Old 01-22-2015
Star/DAS Registered Owner
Quoted: 499 Post(s)
Who told you these codes have been set - indy shop or dealer, and do you know what diagnostic tool was used to retrieve the codes?
What was the car doing that caused you to have the codes retrieved?
mchild is online now
#3 Old 01-22-2015
Vehicle: 05 slk350
I have an icarsoft scanner
I got the esp/abs malfunction and when I do the scan I get these three codes.
I found a description online for C1100 Left Front Axle VSS Circuit Fault
but I can't find anything on any of the other two fault codes.
tnsr35 is offline
#4 Old 01-22-2015
Vehicle: 05 slk350
vss just hit me
Vehicle Speed Sensor
tnsr35 is offline
#5 Old 01-22-2015
Quoted: 6435 Post(s)
if you want your datacard and the part number for the vss post your vin
#6 Old 01-23-2015
Quoted: 499 Post(s)
Be aware that MB sets both fault codes and warning codes. The CarSoft reader may be interpreting warnings as faults. The only way to know for sure is to have your car hooked up to a MB SDS system. It will tell you all faults and warnings and where the issue is - or at least close. All of these diagnostic systems are best used by techs with experience as as a fault can be set for a particular part when an associated part is the true problem. There is a recent thread here where an `05 350 was throwing codes for a faulty A/C compressor, but it was determined the front SAM was the true problem. Experience helped in that situation.
If it were me I would replace the speed sensor, reset everything, and see if anything else comes up.
#7 Old 01-23-2015
Quoted: 499 Post(s)
vss just hit me
Front speed sensor part number is 203 540 04 17. About $60 from online MB dealer and about $45 from RockAuto.
#8 Old 06-27-2017
Vehicle: 2008 Edition 10, SLK 350 Silver..All Stock
Other Toys: 2010 Harley Davidson, Road King
On My comand/NAV what are the code to enter
I have a 2008 SLK 350 edition 10, Silver. I understand the Navigation unit is a comand center and I need the codes?
Next is the Nav unit, is it in the trunk like the owners manual says? I don't want to go to the dealer to get soaked, placing the DVD comand/map disk above the screen in dash..
Bagoman_SLK is offline
#9 Old 06-27-2017
Originally Posted by Bagoman_SLK View Post
I have a 2008 SLK 350 edition 10, Silver. I understand the Navigation unit is a command center and I need the codes?
Next is the Nav unit, is it in the trunk like the owners manual says? I don't want to go to the dealer to get soaked, placing the DVD command/map disk above the screen in dash..
Post your question in your intro thread and/or make a thread in the r171 general discussion section
what are the code to enter?
what codes? please be specific in your new thread
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
