Common and easy to do DAS 'tweaks' - Page 5 - Mercedes Benz SLK Forum
 40Likes
#81 Old 03-03-2016
Star/DAS Registered Owner
Quoted: 484 Post(s)
Originally Posted by Pioneer4x4 View Post
No, I did find that already, when you display the engine temperature, it is a bar from 40 to 120 Celsius, I was wondering if that could be changed.
It is shown on page 122 of that document.
No that display can not be changed. Stuck with Celsius.
mchild is offline
#82 Old 03-03-2016
Vehicle: GONE - 2005 SLK350 Auto Caspian Blue/Beige Trim ,Heat, Light, Comfort, Premium, Ent. w/Nav
Other Toys: 1967 Chevrolet El Camino.2015 Charger R/T R&T B5 Blue
Quoted: 213 Post(s)
OK, thank you for the reply, I was mainly curious.
Pioneer4x4 is offline
#83 Old 04-09-2016
Zenman 63's Avatar
Vehicle: No SLK
Other Toys: Porsche Cayman S 981 + Porsche Cayenne GTS
Quoted: 149 Post(s)
Just at the same stage as above on Geoffs car, he's coming back tomorrow so will look again at the menus but think there all enabled, must be missing one.
Zenman 63 is offline
#84 Old 04-10-2016
Zenman 63's Avatar
Vehicle: No SLK
Quoted: 149 Post(s)
Menu 8 was missing, its down at the bottom, job done.
The Following User Says Thank You to Zenman 63 For This Useful Post:
#85 Old 04-10-2016
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 419 Post(s)
...Ta Da!!
Zenman 63 likes this.
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is offline
#86 Old 04-10-2016
Geoffo's Avatar
Vehicle: 2010 Slk 55 Amg
Quoted: 49 Post(s)
Just wanted to say a big thank you to Zenman 63 for all his time and effort turning on menus and enabling options for me. Top man!!!! Also thanks Seanhump for guiding us to menu 8 to get the temperature display enabled. I am well pleased.
Geoffo is offline
#87 Old 10-11-2016
Caboz's Avatar
Vehicle: SLK R171 2004 200 Kompressor - Kleemann K2
Other Toys: Volvo V50 2.0D
Quoted: 17 Post(s)
Originally Posted by Marco06 View Post
Flashing Comand NTG 2.5 unit with Telematics Disc A1718274359 (07-2011) : firmware 09.29
In progress..
Hi! What is the procedure to do this?
Tks!
Caboz is offline
#88 Old 12-23-2016
Quoted: 213 Post(s)
Can the additional menu that you access by hitting reset 3 times be enabled all the time? I like how you can see the volts in the MFD as well as the other toys like basically enabling track mode.
Also from another screenshot I saw on this thread, there was mention of a trunk release, what is that?
Also, also,
I have a 2005 SLK350 with everything I know of except the sport package. Other than the true "M" mode, what else can I get enabled? I was thinking the both rear fog light option, I do use them occasionally on early morning commutes in Pittsburgh, and nobody here knows what 1 small bright red light means (at least they see it! but they think something is burnt out on the other side)
The gallons remaining would be cool, and the dumb rotational tire pressure would be cool as well. Once that is enabled, can you turn it off easily?
#89 Old 12-23-2016
Seanhump's Avatar
Quoted: 419 Post(s)
Afternoon ...
a few answers in bold for you ...
Can the additional menu that you access by hitting reset 3 times be enabled all the time? - Fraid not ...
I like how you can see the volts in the MFD as well as the other toys like basically enabling track mode. - A facelifted AMG cluster can do this (the volts that is, along with oil temperature and the race timers)
Also from another screenshot I saw on this thread, there was mention of a trunk release, what is that? - The one on the key, possibly
Also, also,
The gallons remaining would be cool, and the dumb rotational tire pressure would be cool as well. Once that is enabled, can you turn it off easily? - Yes, with DAS
You missed ...
Cornering fogs at the front
Temperature in the lower MFD
dbgrn likes this.
Sean
Mods so far...
Seanhump is offline
#90 Old 12-23-2016
Quoted: 213 Post(s)
Originally Posted by Seanhump View Post
Afternoon ...
You missed ...
I already have those options built in, and thanks for all the answers on the other questions.
#91 Old 12-28-2016
Quoted: 213 Post(s)
I wanted to post a HUGE thank you to "mchild"! He remembered that I live in the Pittsburgh PA area and reached out to me on Christmas weekend since he was going to be in the area and brought his setup. I drove and met him and he spent some of his time on my car and enabled several items for me.
Both rear fog lights
Gallons in tank (I have no idea why that is not on by default)
Runflat (Smart/Dumb tire pressure monitor)
The main thing I really wanted was to get "M" mode enabled and I think we were missing a step, and I certainly can't fault him on it because he has a 6sp manual SLK, not an area he was used to poking around in.
Apparently something needs enabled in the "Central Gateway (CGW) & Electronic Selector Module (ESM)" We could not find the setting in one of them (I don't recall right now) and did enable that part. I think the issue might be that we needed to enable/add the 428 code, got me.
Anyway, the main reason I am posting is to give a big "Thank You" to "mchild" for going out of his way to contact me, and offer his time.
etyu and dbgrn like this.
#92 Old 12-29-2016
Quoted: 484 Post(s)
Glad I could help. I'm working on figuring out why my system did not provide the screen we were looking for to do the switch on of the M mode. Even if I don't get that resolved, I am fairly sure I have a work around. Once I have that confirmed I will let you know and we can see if there is any chance we can get together again.
etyu, jbanks15 and Pioneer4x4 like this.
mchild is offline
#93 Old 12-29-2016
Quoted: 213 Post(s)
Sounds good, thanks again. I may look for a wheel or components in the mean time.
#94 Old 10-07-2017
Beppi's Avatar
Vehicle: 2006 Mercedes-Benz 200slk
Other Toys: Boats
Quoted: 137 Post(s)
Send a message via AIM to Beppi
Beppi is offline
#95 Old 11-21-2017
Vehicle: 2008 R171 280 in Thulite Red
Other Toys: Holiday home in France
Quoted: 79 Post(s)
Reading through the postings I am right with a UK car the lower display cannot be changed from kph to mph and the only way is to set the car up as though it is Euopean which I assume would cause problems.
Such a shame that MB interpreted the EU rules thus. The (Opel) / Vauxhall Insignia in the UK has a MPH dial but the digital speed display can be switched between MPH and KPH by the driver.
Redleader is offline
#96 Old 11-21-2017
dbgrn's Avatar
Quoted: 1035 Post(s)
You are right that, for a R171 in the UK, the default (MB OEM) behaviour is for the lower MFD to be fixed at displaying km/h.
However, if this is changed using STAR (which I believe does involve it being set-up as though it's a car from elsewhere in Europe), then this can be switched... I leave my lower MFD displaying outside temp by default now. I can also switch my main speedo (and the lower MFD with it) between displaying mph and km/h (there's an indicator in the middle of the speedo that switches to indicate which is being displayed).
As far as I am aware, there's no downside to this change - everything else on my car continues to function as it should.
- Dave
Mods:
(MB p/n A1718202075)
wind deflector
• Post-FL wing mirrors
• CF-effect interior trim
• AMG LED puddle lights
• Piecha DRLs
dbgrn is offline
Overfilling automatic transmission - no big deal + easy remedy ITAdrian SLK R170 General Discussion 2 08-27-2014 01:23 AM
2 easy (and common) mods... Boompa Steve General Modifications R171 16 01-26-2011 12:56 PM
