| Where to get R171 SLK Items Ask where to get or buy items for your SLK. No Commerical Posts Allowed. Please note you will require a minimum of 10 posts to create a thread here. |
| SLK World Junior Member Join Date: Jun 2007
Vehicle: SLK200 2007 model year.
| I have seen on the Benz World forum and a few other places the mention that a new MB OEM stubby antenna specifically designed for the R171 that was being released in September or October this year (2007). Does anyone know anything about this and do we have an MB part number for this yet? |
| | #2 (permalink) | |
Vehicle: 2006 SLK 280 w. 6M
Country: Thanks: 18
It seems that a shortened antenna will be part of the R172 facelift. See pictures here. | |
Country: Thanks: 376
| If one decides on the SL antenna (they come pre-painted), just be aware that the radio reception would diminish noticeably and the range for using the SmartKey is reduced from 100 ft to 30 ft approximately.
Vehicle: SLK280
Country: Thanks: 6
| I'm still waiting eagerly in anticipation for the new stubby antenna designed specially for the R171. From initial reports of it, was supposed to be similar to the SL-style antenna, but the one in the facelift pictures looks more like the R170 style ones, which while shorter than the current whip, is IMHO no match for the SL-style ones. Hopefully Mercedes will confirm soon what it looks like....if it ends up looking like the R170 style, might end up going for the SL short antenna, and then just adding the bumper extension as per one of the guides here. |
| | #6 (permalink) | |
Country: Thanks: 54
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. ----------------1----------------- --------SLK 55 ///AMG--------- THE MON55TER ON THE BLOCK Last edited by -1-; 09-26-2007 at 08:12 PM. | |
| Elite SLK World Member Join Date: Aug 2007 Location: New York
Country: Thanks: 29
| Has anyone tried modifying the existing whip? ie: cutting off the rod above the taper point? It probably doesn't look as good as the smooth SL option but maybe a compromise in looks vs performance...thoughts?
__________________ Steven To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. 06 SLK 350, Iridium Silver, Blk Int, Chrome Trims, AMG Body, Aerowings,Wide Base Tire Flares (Thx CDRN) Green Filters, Filled Sidemarkers, Painted Ant, Komfort Module (Thks NR4L) Rear Spoiler - Piecha, Brabus springs, R170Moded Ant, 19" TSW Bremma, Mich PS2 |
| | #8 (permalink) | |
Country: Thanks: 54
It's been done before by at least one SLK owner and reported on one of the MB forums. I believe he reported less reception which makes sense. Nothing wrong with keeping the factory antenna if you want performance. I don't use AM-FM so I could care less, but I don't like the reduced range on my SmartTop module. I plan to add another "stealth" antenna to improve range.
| | #10 (permalink) |
| I went to my dealership today and picked up a R170 stubby antenna. I have put it on the car when the vehicle was in my garage so reception is not as if I am out doors but have found no real difference in FM reception on BBC Radio 1 and 2 and no difference in mobile phone reception (the signal reading is the same for the whip and this unit (not sure if the integrated phone system shares this antenna)). I am not sure about the range of the remote but I always stand next to the vehicle to open it anyway, and no difference was detected. I will do some further tests and let you know how it goes. This effectively is a cut off R171 standard whip antenna. It is black and plastic but about the same length as the thick bit on the original Antenna. The connection is just the same as the original whip so it is plug and play. It also looks as if it was designed for the car as it matches perfectly. Not as sophisticated as a colour coded SL antenna but a nice upgrade and on my dark Bentoniote Blue car it blends in nicely. I have put the original whip antenna in the boot so if I go to Scotland touring and reception did become a problem I can easily swap them in a couple of seconds. My dealership tried to identify the new R171 stubby antenna but can not find it. The part number is A170 820 06 75. EDIT I have been testing the antenna this week end. Sadly it is not as good as the standard antenna. Telephone is fine, locking is fine but what does seem to happen is that it takes a while to find the RDS stations if you decide to listen to a different station. So for example: You listen to radio 1, then listen to the CD, you then switch back to the radio and try to listen to say Radio 2. Sometimes all you get is a faint hiss and then after about 40 seconds it finds the station, which is a pain. So in summary, if you turn the car on and listen to the same radio station all the time it is fine but if you decide to change station you may have issues. I am also not sure whether the RDS traffic system would work effectively. Last edited by Goldfish11; 09-30-2007 at 03:28 PM. Reason: testing |
| | #11 (permalink) | |
Country: Thanks: 18
| | #12 (permalink) |
Vehicle: '06 slk55
Country: Thanks: 67
| Ikarus, Thanks for the post above. It is very helpful and I plan to give it a go. In the meantime, here is the babelfish translation and pics: Meanwhile there is a possibility, on use of the 170er short blade antenna (Part No. A170 820 06 75), of improving by a small modification, the receipt quality the same substantially. The stub can be warmed up, with something fate and a hair dryer, through and takes off at the separation edge to open. To the appearance coming short cables (which is appropriate for the telephone receipt only), becomes then approx. above. 5-6 mm strips. Then one takes two, long pieces "bell wire" (Ø 0.5 mm/Ø 0.9 mm with isolation) to at least 75 cm (for expert Lambda/4) and wickle these as parallel as possible to a spiral. As starting I took in addition a small female hexagon box spanner (Allen key). In the further process a ball-point pen had to hold. The wire is then so to windings and by right too "friemeln" that it fits into the inside hollow flagpole antenna. Admitted, it is already a little "Gefummel". Subsequently, the two wire ends with the upper end of the existing antenna wire are soldered. After that the spiral will isolate in such a way over the Drahtstumpen inverted that one can plug everything together again beautifully and "is finished the summerhouse; -) . Wireless reception and range of the radio locking are absolutely everyday life suited and might approx.. 75-80% of the achievement of the series antenna correspond. The telephone receipt is invariably good after my subjective impression (D1-Netz). Great a Kompromis between good optics, expenditure, achievement and price. These data are natural without guarantee and under exclusion of any adhesion. Pictures:
__________________ SOLD! 06 Mercedes Benz SLK55 Caspian Blue / Black & Ash To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. |
| | #13 (permalink) |
| DSB, please post your tutorial when you do this mod to the R170 antenna. Let us know the type of wire that you use also.
| | #14 (permalink) |
Country: Thanks: 18
| Thanks dsb for extracting those pics! That Babelfish translation is not too bad, I've seen a lot worse. So can anybody say whether 86$ plus tax is an ok price for this thing? |
| | #15 (permalink) |
Vehicle: '06 slk55
Country: Thanks: 67
| Ikarus, I think I paid around $70US. However, it was such a long time ago that I don't remember exactly. I am working on 'fixing' my antenna right now. Until I'm complete, here's a link with previous antenna discussion: http://www.mbworld.org/forums/showth...t=r170+antenna
| | #16 (permalink) | ||
Vehicle: '06 slk55
Country: Thanks: 67
http://www.slkworld.com/general-modi...0-antenna.html
__________________ SOLD! 06 Mercedes Benz SLK55 Caspian Blue / Black & Ash To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. | ||
| | #17 (permalink) |
Vehicle: 2006,slk280,carlsson
Country: Thanks: 1
| i got the SL antennae, and reception on FM is lost drastically, but then inner city it is still good, but in rural areas its is poor, but i just listn to a cd then. the visual impact is massive i think and an essential addition to the r171. |
| | #18 (permalink) | |
| Elite SLK World Member Join Date: Aug 2006 Location: London
Vehicle: SLK 280
Country: Thanks: 34
P | |
