| Where to get R171 SLK Items Ask where to get or buy items for your SLK. No Commerical Posts Allowed. Please note you will require a minimum of 10 posts to create a thread here. |
| | #81 (permalink) |
| SLK World Member Join Date: May 2007 Location: San Francisco, CA
| I don't have bumper booster, but I swear there's no difference for me when it comes to AM/FM reception. Maybe I didn't try enough stations, but all the ones I remembered (haven't used FM/AM since I got Sat Radio in my last car) worked just fine. Remote range, on the other hand, is significantly reduced - especially on the passenger side (for U.S., that's awy from the antenna). Sometimes I have to be almost within arms reach from the passenger side to unlock. From the back and the driver side (which is typically the side I approach), there's no problem at all. Why would you want to unlock from 20 meters? Before the short antenna, I'd always worry that I would unlock by accident as I walk away, but now I no longer worry about that. p.s. Come to think of it, those who want long-range probably has top mod installed for one-touch-lower of the roof? |
| | #82 (permalink) |
| Oh, and the short antenna without booster still works from 20 from the back. I unlock from my apt on the second floor as I walk towards the ground-level garage. Straight-line it should be about 20 meters. I think screwing the antenna really tight helps a lot, though I don't see why that would matter so much. |
| | #83 (permalink) | |
Country: Thanks: 135
| | #84 (permalink) |
| Elite SLK World Member Join Date: Oct 2006 Location: Ellicott City & Salisbury, MD
Vehicle: 2007 SLK 280
Country: Thanks: 4
| i hate to say this but i do have sl antenna installed and reception is useless... i would recommand R170 antenna |
| | #85 (permalink) |
| SLK World Junior Member Join Date: May 2008 Location: Bournemouth, UK
Vehicle: SLK Kompressor in Silver, Sports Pack, with 19" Wheels
| Here's my stubby Antenna from an SL on my SLK. But I also get really bad reception on my ariel. Is there nothing I can do to improve it? I can't even get the national radio station. |
| | #86 (permalink) |
Country: Thanks: 376
| Check this link: http://www.slkworld.com/general-modi...antenna-5.html There's info on improving the SL antenna but not by much. More significant with the short R170 antenna.
| | #87 (permalink) |
| Senior SLK World Member Join Date: Sep 2007 Location: Melbourne, Australia
Vehicle: A200, SLK R171 350
Country: Thanks: 3
| Has any one got a picture of the r170 antenna? I have the sl ant. but if the r170 looks as good, I may change to the r170 cheers |
| | #89 (permalink) |
| SLK World Member Join Date: Jun 2008 Location: Madrid (Spain)
Vehicle: SLK 200 (R171)
| ellimb, go first to that thread: http://www.slkworld.com/general-modi...html#post84093 This is the mod I made, and I have to say that the improvement applied to the SL's antenna is good enough for me |
| The Following User Says Thank You to eddyther For This Useful Post: |
| | #91 (permalink) |
| R170 ant is about 4-5 cm longer than the R230 ant. The R170 short ant is covered by a black matte flexible rubber sleeve. The R230 ant is covered by prepainted metal sleeve.
| | #92 (permalink) |
| Senior SLK World Member Join Date: Aug 2008 Location: Atlanta
Vehicle: SLK320 and others...
Country: Thanks: 29
| It sure does. There's about an inch or two difference (sorry I don't have the exact measurements, but they're probably in this thread already). But that inch difference will let you coil wire inside to make a much longer antenna. There is a GREAT thread in this forum about how to do just that. If you can't find it, let me know and I'll find it for you... Never mind, I just went back and saw that it's included in etyu's post. The same one with the photo... Or eddyther's post... If I look again, sombody else will have posted it before I finish this... Last edited by dmjonez; 10-10-2008 at 04:12 PM. Reason: addition |
| | #94 (permalink) |
| Senior SLK World Member Join Date: Sep 2008 Location: Angleton, TX USA
Vehicle: 2006 SLK350 +C/H
Country: Thanks: 17
| I did this mod....it looks SOOOOOOO much better than the whip antenna!! Simple, affordable, and high impact. Highly recommended!! |
| | #95 (permalink) | |
| SLK World Member Join Date: Jul 2007
| | #96 (permalink) |
| Gauge 20 IIRC is the max thickness although I doubt if AM/FM reception would be any better than gauge 22 solid wire. See post #175 of this thread: http://www.slkworld.com/general-modi...antenna-9.html
| | #97 (permalink) |
Country: Thanks: 3
| Hi Folks Guess what about the r170? I have not seen a r170 in Australia with an antenna !!! Cos it is embedded in the rear windscreen. So, my short antenna is sl type. In southern hemishere, the windscreen antenna works better!!! ![]() Also the r 171 in Australia has no side markers. |
