Go Back   Mercedes SLK World Forum > Mercedes Benz R171 SLK Class Cars > Where to get R171 SLK Items
Where to get R171 SLK Items Ask where to get or buy items for your SLK. No Commerical Posts Allowed. Please note you will require a minimum of 10 posts to create a thread here.
Windrestrictor
Old 05-09-2007   #41 (permalink)
Vehicle: 2007 SLK280
I got a free one with the same color from my dealer! The transmission is not so good, but the look is so good that I am not going to replace it.
View watsons's Photo Album watsons is offline
Old 05-09-2007   #42 (permalink)
Vehicle: SLK55 2006
So...how is the remote reception on the Brabus bumper antenna? Is it highly directional? is it anywhere close to the stock reception? Can it be installed in the headliner of the car underneath the vanity mirrors? or in the door panels or dash?
Old 05-09-2007   #43 (permalink)
Due For Service
Its not quite as good as OEM but its very close.
It has to go in the trunk because all the control modules for the antenna are in there.
Old 05-09-2007   #44 (permalink)
Vehicle: SLK55 2006
Aftermarket antenna can have pretty long extenions? in my other car i have a 4 foot extension for the radio, and a 2 foot extension for the cellphone...can i use an aftermarket antenna and amplifier with the remote key then? i'm not very concerned about the radio reception, just about the key.
something like this:
http://shopper.cnet.com/car-video/au...-32168012.html
Old 05-09-2007   #45 (permalink)
Due For Service
I don't know about an aftermarket mate, with the Brabus the antenna pads hook up to the booster that takes power from the Rear SAM the booster then connects to the antenna control module via FAKRA the control module splits the key signals out and sends them off via CAN and sends all the other RF on the line into the AGW, the problem is knowing what signal range to boost you would need to work out what frequency the key uses and find a compatible booster to put in the line if you got one with enough kick you could use the SL antenna just fine without adding others.
It would need to be located in the trunk if you did want to add other antennas you could run a line back to it but the booster would need to be by the control module thats fixed in the trunk.
If you have a scanner to find the key frequency then i think its possible.
Old 05-10-2007   #46 (permalink)
N4PWJ's Avatar
Vehicle: 2006,slk280,carlsson
Other Toys: Caterham
Originally Posted by OWL-SLK View Post
That´s true Eddy.
I friend of mine is working on a antenna for the R171, but we have to wait a little for the result.
so Gero, any word on your friends product yet?
Old 05-10-2007   #47 (permalink)
I´ll get the result from Dr. Sven Battermann on the 19th of May. He´s travelling a lot around the world so he needs time. Hope he found a way.
http://www.geml.uni-hannover.de/inst...ann/index.html
Old 05-10-2007   #48 (permalink)
N4PWJ's Avatar
that is quite a picture!!!
cheers Gero. Just looking for a cheaper alternative than the Brabus and the SL antenna looses reception.
Old 05-10-2007   #49 (permalink)
Wimbledon_SLK's Avatar
Vehicle: SLK 280
Other Toys: Honda VFR 750
the post face lift SLK may have a cross between the long and the short antenna
http://www.autoexpress.co.uk/news/sp...cedes_slk.html
P
View Wimbledon_SLK's Photo Album Wimbledon_SLK is offline
Old 05-10-2007   #50 (permalink)
Zeiser50's Avatar
Vehicle: SLK 55 AMG
Just for info, i have installed an electric wire in the bumper (4 meters) in parrallel with the SL antenna. Radio reception becomes good (less than OEM, but good enough i think. More directive) even with the SL antenna.
Few euros only .... Unbeatable !
Installation needs to remove the bumper, which is quite easy.
------Michel------
-SLK 55 AMG 2005-
View Zeiser50's Photo Album Zeiser50 is offline
Old 05-10-2007   #51 (permalink)
N4PWJ's Avatar
do a step by step would you Zeiser50 please.
Bit more info on the wire. I can remove the bumper easily, it's the wiring of this extra wire im curious about.
Old 05-10-2007   #52 (permalink)
I could use piccies and narrative tutorial on removing the rear bumper and the wire install. Thanks in advance.
Old 05-10-2007   #53 (permalink)
Zeiser50's Avatar
Vehicle: SLK 55 AMG
Ok guys. i will try to make a report .....
------Michel------
-SLK 55 AMG 2005-
Old 05-10-2007   #54 (permalink)
Please start a new thread on how to's. I think we should sticky some of the "how to" threads in this forum -- like varioroof module install, aftermarket bluetooth, clear sidemarkers, etc.
Old 05-10-2007   #55 (permalink)
Vehicle: SLK55 2006
like this?
http://www.benzworld.org/forums/r171...faq-links.html
Old 05-10-2007   #56 (permalink)
Ynot's Avatar
Originally Posted by cyberdrakon View Post
that's alot of searching. good job.
Old 05-11-2007   #57 (permalink)
Saw it today at benzworld.
Old 05-11-2007   #58 (permalink)
Zeiser50's Avatar
Vehicle: SLK 55 AMG
i have some thought during this night.
Bumper removal or wire installation will not be a big deal for a lots of people. However, to connect this cable to the antenna amplifier, i've :
. opened the antenna amplifier,
. used a solder iron and solder the new wire.
This may be difficult for some of you. Anyway, i will make the report to explain exactly what i have done.
Another way is to create a kind of 'Y' cable, connected between the antenna and the amplifier, wich allows to add the new wire easaly. i have to check what is the antenna P/N, and if can be found easaly ..
i will post some pict in order to explain more clearly ...
Stay tuned .......
------Michel------
-SLK 55 AMG 2005-
Old 05-11-2007   #59 (permalink)
N4PWJ's Avatar
cheers Zeiser, will be a useful tutorial.
I agree we should have a new category on the main page called 'how to's' for R170's and R171's.
Old 05-14-2007   #60 (permalink)
Senior SLK World Member
Vehicle: 05' SLK55 Orion Blue
Other Toys: CBR600rr, Mustang SC 480hp
Originally Posted by msfamilia View Post
The power of DIY flat black!
So what color did you originally order it in? I take you are using the original SLK base with that?
View ppower's Photo Album ppower is offline
