| Where to get R170 SLK Items Ask where to get or buy items for your SLK. No Commerical Posts Allowed. Please note you will require a minimum of 10 posts to create a thread here. |
| Elite SLK World Member Join Date: Sep 2006 Location: Kaiserslautern, Germany
Vehicle: 2000 Designo SLK230
Country: Thanks: 85
| Does anyone happen to have a passenger side headlight ass'y they want to get rid of? (U.S. Spec) Fully functional, of course. After some investigation, I found mine is missing a tab on the inside bottom that holds it in place in order to adjust the pitch of the beam. Whoever had it before me just jammed it in place so it wouldn't move. Knuckleheads. When I wanted to adjust it up it wouldn't move.Thanks! Last edited by DesignoSLK; 10-09-2007 at 03:53 AM. Reason: clarification |
| Elite SLK World Member ![]() Join Date: May 2007 Location: Søgne
Vehicle: 96 SLK 230K
Country: Thanks: 13
| Hi Kevin Was'n scheiß in good en![]() Should US cars have a different headlight?? If not you got a new one for 80 Eur here: http://tinyurl.com/357pbe There's also a lot of guys that have changed to clear glas in MBSLK.de. That means they don't need their original lamps...... You're a member there - Ask..... You could also change to Clear glas while you're at it. http://tinyurl.com/37yy6f Send a mail to Gero, He'll get you a good price at Piecha......
| | #3 (permalink) | |
Country: Thanks: 85
Country: Thanks: 85
| After a thorough inspection of the ass'y it turns out the two "ball and sockets" were never properly mated after whatever event took place with the previous owner to cause it. After reseating both pivoting points and making correct alignments, everything is secure and adjustable again. I'm no longer overdriving my low beams and it only cost me the time to remove the ass'y to reinsert the ball joints. PHEW! That's $300 bucks I don't have to spend. |
| | #5 (permalink) | |
Country: Thanks: 289
Country: Thanks: 13
| That's Good Kevin ![]()
| | #9 (permalink) |
Country: Thanks: 85
| You have to remove the turn signal first. There's a hole that requires you to insert a long screwdriver in and nudge to one side. Then the turn signal comes out to make the bolt accessable to complete the removel. I know that's not the best explanation. There's a better one on the owner's manual. I don't, but thanks for the offer. |
| R170 - Headlight | jasper | Ask DansSLK | 4 | 10-24-2007 03:22 PM |
| Headlight Switching | microbe | SLK R171 General Discussion | 8 | 03-15-2007 04:54 PM |
| headlight dissassembly | cyberdrakon | Ask DansSLK | 22 | 01-28-2007 06:37 PM |
| Headlight Adjustment | ShortShift | Ask DansSLK | 4 | 01-19-2007 12:58 PM |
| Water spots inside headlight lens | Dinoman | SLK R171 General Discussion | 21 | 08-01-2006 01:18 PM |
