Eco Mode - Mercedes Benz SLK Forum
 4Likes
#1 Old 10-24-2012
Vehicle: 2012 SLK 250 CDi AMG Sport
Eco Mode
Morning
I have been wondering...is there a point where having the Eco stop/start function on actually becomes un-Eco or more importantly is damaging to the engine?
As an example, when driving inner city where there are plenty of hold ups, stops, starts etc the Eco mode can stop the engine and then have to restart it lots of times, and sometimes it's only off for a matter of seconds before we start moving again.
Does all the stop/start and short time between stopping and starting actually cause more harm than good?
Anyone any thoughts on this?
Garf
Garf255 is offline
#2 Old 10-24-2012
creepy coupe's Avatar
Vehicle: R172 200 AMG
Other Toys: Ford Mondeo
The first thing I do is switch ECO off. I don't find it works very well with a slight shudder on restart. I also do like the thought of the engine/starter keep switching on /off.
It shouldn't really bother me, as we will only keep the car for a couple of years, but I have a fair amount of mechanical sympathy.
creepy coupe is offline
#3 Old 10-24-2012
Room 4 2
slk55_kt's Avatar
Vehicle: 2013 SLK 55 AMG
Quoted: 21 Post(s)
I've wondered about the ECO function, too. And not just in terms of efficiency, but also in terms of motor wear. I assume MB took this into consideration when they designed the system, but 'back in the day', it was considered 'common knowledge' that the most wear on an engine occured at startup - mainly because the oil pressure took a second or two to build up. Maybe that logic only applies to the 'initial' or 'cold' startup, and not intermittent starting/stopping after warm-up the way ECO functions - it could be that there's enough of an oil film on all of the wear surfaces that a short start/stop cycle won't do any harm? Also, in the AMG, MB supposedly limits the performance until the oil temp reaches 176 F, so they've probably taken these oil pressure fluctuations into account. For now, I'll assume that MB has ECO figured out and my engine won't be any worse for wear when it's active, but I may change my thinking and just turn it off every time I take the car out.
slk55_kt is offline
#4 Old 10-24-2012
Yes.Years ago it was about 75% of engine wear was caused from cold starts. I think modern oils have pretty much taken care of the, although obviously most engine wear is from cold. For me it's all the other things connected with stop/start. Each time the engine restarts and backlash is taken up and in the case of the SLK with automatic handbrake release, this immediately transfers to the drive train. It's interesting the with the AMG cars, you can set it not to default to on each time you climb in. I'd like that on my car.
#5 Old 10-24-2012
Vehicle: 2012 (September?) SLK 200 (R172)
IMVHO (a very personal view).. Car manufacturer need to meet the ever more strict environmental commitment set by different countries in order to sell their cars in those countries. If the Eco system can help put their cars into the markets, lets worry about the long term reliability issue later. If they can't even sell the car it is game over.
Still Learning likes this.
bbbling is offline
#6 Old 10-24-2012
Vehicle: SLK55 AMG 2013
Quoted: 12 Post(s)
doesn't bother me, i have a warranty and only plan on keeping the car for 3 years anyway.
Im sure they've done their research and wouldn't add a feature to the car that would damage it, especially on an expensive AMG engine. It doesn't use the feature for the first few minutes as it shows inactive, so I'm guessing this is something to do with making sure the engine is at least warm enough to make it a non-issue.
on fifth gear this week (UK car show) they tested the stop start on a renault and it gave 20% extra distance from the same amount of petrol when driving around central london/birmingham (not sure which, but it was a big city).
I keep it on, even on an AMG......
davidkn is offline
#7 Old 10-24-2012
Delucas's Avatar
Vehicle: MERCEDES SLK R171 -2009- MERCEDES - BENZ SLK 170 2000 -- MERCEDES A 170
Other Toys: ALFA ROMEO SPIDER 2000cc - VAUXHALL CORSA SR - LEGO STAR WARS 1791 X WING
Quoted: 538 Post(s)
Well eventually these cars will be passed on in the years and thats when the faults arrise .
Ie costly starter motor !
Battery wear !
As more and more demands on the battery are put on these .
Thats when there start /stop are switched off.
Im all for better fuel economy but when the bill comes in to repair the start / stop technology ooouuuccchhh !!
Delucas is offline
#8 Old 11-02-2012
Vehicle: 2012 SLK 350
Other Toys: Jetski
If I stop the engine manually and then start it again manually, does that have the same effect as the eco start stop or is the eco functioning differently?
jgonz2513 is offline
#9 Old 11-02-2012
NTT
Vehicle: 2017 C63 Coupe
Quoted: 16 Post(s)
As far as I am aware the starter motors are different.
They are designed to handle frequent use.
I think the engine management system also remembers the position of each piston, and fires up the best positioned one first for quick startup's
NTT is offline
#10 Old 11-02-2012
Vehicle: 2011 SLK 350 AMG Sport, Edition 125, Fire Opal.
When the engine stops in ECO mode, all the ancillaries continue to work, which doesn't happen if you just turn off the engine.
mj01 is offline
#11 Old 11-03-2012
Beausoleil's Avatar
Vehicle: C207 E350CDI
mj01 is right. Most importantly the auto transmission has an oil pump that continues to operate when the engine turns itself off.
Beausoleil is offline
#12 Old 11-03-2012
Vehicle: 2013 SLK55 AMG
Post ECO Mode in 55 AMG
Question for this thread...
I just took delivery of a SLK55 AMG, currently going through the break-in period.
I've noticed the Start/Stop function begins to activate literally right out of the garage, before the motor could possibly be at the correct operating temperature
Is this normal?
Given the complex logic the system uses to activate the function, it seems odd that only one trigger for the system wouldn't work.
Any insights would be appreciated!
Thanks,
mrob-1991 is offline
#13 Old 11-03-2012
Quoted: 3968 Post(s)
mrob,
Thank you,
Moderator/Founding Member
Wavetrac LSD thread here:
#14 Old 11-03-2012
Quoted: 12 Post(s)
Is this normal?
Thanks,
I don't know what the requirements are, but mine seems to start working at varying distances from home, sometimes I get to the end of the street and stop and it comes on, other times it takes 5-10 mins, not sure whether its to do with engine temperature, whether you have the heating/aircon on etc.
Sorry.
mrob-1991 likes this.
davidkn is offline
#15 Old 11-01-2015
Vehicle: SLK R172 AMG 200 Bought new Oct 2011
Other Toys: Suzuki Hayabusa, VW California.
Quoted: 42 Post(s)
I have a 2011 R172 SLK and the ECO dosent work AT ALL . I can turn it on when I start the car, The green light comes on stays on for 4 seconds
then goes off and dosent come back at all. I did a return journey of 240 miles yesterday
and no matter what I did NOTHING happened. Surely by that time the engine should be the correct temp etc.
Im getting a little P**** of with my SLK now + all the other faults
PeterRoberts is offline
#16 Old 11-01-2015
Nob
Vehicle: SLK 250 R172 July 2011 model.
Quoted: 12 Post(s)
Does ECO show in the display? Maybe the switch is faulty?
Nob is offline
#17 Old 11-01-2015
Quoted: 42 Post(s)
The switch does actually work but the eco sign does not show up in the centre screen any longer. Like I said it comes on for about 4 seconds then that's it. Nothing.
#18 Old 11-01-2015
I always say when something electronic screws up, reboot the car
disconnect the negative cable for minimum 30 minutes
reconnect cable and reset clock and synch windows
see if issue has been resolved
#19 Old 11-02-2015
mikez328's Avatar
Vehicle: 2012 SLK 250 Cdi
Other Toys: Toyota RAV4
PeterRoberts (& JBanks): My previous car was a BMW123D with "Stop/Start". If the battery is disconnected on any BMW fitted with "Stop/Start", upon reconnection the function will not work until you have visited a BMW dealer & paid for the car to be re-coded - not cheap. The S/S function is dependent on many factors monitored by the ECU including, to name but a few, Engine coolant & outside air temperature, electrical functions in use (battery load) & MOST importantly, the charge condition of the battery. One of the first indications of a bad battery on a BMW is the clock zeroing itself & "Stop/Start" not functioning. I had these symptoms & discovered I could not just replace the battery myself so had to pay BMW €397 to fit a new battery (AGM!!!) just to get the computer recoded for the S/S to work again. I would assume that the Mercedes ECU is probably similar in operation.
Has your battery been disconnected previously? If not, get your battery checked.
Mike
mikez328 is offline
The Following User Says Thank You to mikez328 For This Useful Post:
#20 Old 11-02-2015
WhiteRabbit's Avatar
Vehicle: 2012 SLK 350 (R172)
Quoted: 62 Post(s)
Mike
Wow, I sure hope that is not the case for Mercedes cars with Eco Stop/Start. I replaced the battery on my r172 last year with no problems but it does not have Eco Stop/Start. However, my new 2016 GLA 250 4Matic does have Eco Stop/Start so this concerns me!
2012 SLK 350, Mars Red, Ash, 7G Automatic, Premium Pkg I, Lighting Pkg, Multimedia Pkg, Sport Pkg, Digital Dual Zone Climate Control, Panorama roof, Air Guide Windstop, Chrome Bonnet Fins, smartTOP roof module v1.42, Akebono ceramic front brake pads, TRW ceramic rear brake pads, DIY Backup Camera
Other Ride: 2016 GLA 250 4Matic, Cirrus White, Ash, Premium Pkg, Multimedia Pkg, Panorama Sunroof, Bi-Xenon Headlamps, Blind Spot Assist
WhiteRabbit is offline
Human Verification
Unlocking DVD Engineering mode how to get into Extra menu's in engeering mode zeroassassin SLK R171 General Discussion 22 04-07-2014 08:08 AM
ECO mode fault? andy768 SLK R172 General Discussion 5 09-06-2012 02:02 PM
How to switch off the Eco Mode setting? Also how to default in Sports Mode? addictive SLK R172 General Discussion 32 05-01-2012 04:06 PM
WHY ESP MALFUNCTION and went into LIMP MODE..on and off mrl0n3ly714 SLK R171 General Discussion 1 07-29-2011 12:56 PM
The M Mode SLK_BLK SLK R171 General Discussion 38 12-06-2007 09:15 AM
