Changing 06 SLK 280 Headlight Housing - Mercedes Benz SLK World Forum
Go Back   Mercedes Benz SLK World Forum > Mercedes Benz R171 SLK Class Cars > SLK R171 General Discussion
SLKWorld.com is the premier Mercedes-Benz SLK Forum on the internet. Registered Users do not see the above ads.
Old 02-21-2009   #1 (permalink)
SLK World Junior Member
Vehicle: 2006 SLK 280
Default Changing 06 SLK 280 Headlight Housing
I am getting ready to change my driver side headlight housing. I see two screws holding the unit in.
While I am doing this I am replacing the drive side fog light. So I will have the inner fender well cover removed.
So my question is will I be able to pull the headlight housing out either from the top without removing body parts or pull it down through the fender well?
Thanks in advance for any advice or help.
Mike
View miwade's Photo Album miwade is offline   Reply With Quote
Old 02-21-2009   #2 (permalink)
Vehicle: 05 SLK350
Originally Posted by miwade View Post
Mike
Mike
If my recollection serves me well, you need to remove the front bumper to remove the front light fixture.
Not removing the bumper to completely access the light housing will probably lead to breaking of plastic tabs on the light fixture
Hope this helps
View GearHead's Photo Album GearHead is offline   Reply With Quote
The Following User Says Thank You to GearHead For This Useful Post:
Old 02-21-2009   #3 (permalink)
When you get the chance to do the change, how about taking step-by-step photos and then posting them as a tutorial w/narrative?
Pewter(cubanitsilber metallic)/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package; Designo Black Leather Cover on e-brake handle(Thank you Bill T), SmartTop v3.x, John's 3BFM, M113 AMG OEM air filters, Modified R170 ant., clear side-markers & front parking lamps w/error-free LEDs, chromed front & rear turn indicator lamps, steel mesh at battery bay cover & cabin air intake, sock-over-seatbelt buckles, belt-loop guide protectors, Lamin-X fog lamp protectors.
View etyu's Photo Album etyu is offline   Reply With Quote
Old 02-21-2009   #4 (permalink)
I will do that and share it. Good idea.
Old 02-21-2009   #5 (permalink)
Sulley007's Avatar
Chats: 444
Thanks Mike. Maybe posting it under the DIY section would be a good place?
View Sulley007's Photo Album Sulley007 is offline   Reply With Quote
Old 02-21-2009   #6 (permalink)
aka John
Vehicle: RHD Jasper Blue C200K Coupe, RHD Jasper Blue SLK55, LHD Black SLK350, LHD Firemist SLK55
Chats: 1143
Guys - there's another thread here somewhere that I posted pictures in...
Found - here you go. And yes, you will need to remove the headlight from the top, not the bottom.
http://www.slkworld.com/slk-r171-gen...og-lights.html
PLEASE be aware that you will need to realign the headlight if you remove the housing.
View UK-C200's Photo Album UK-C200 is offline   Reply With Quote
Old 02-21-2009   #7 (permalink)
I think the procedure for the fog light does not apply to removing the whole headlamp housing or assembly.
Old 02-28-2009   #8 (permalink)
OK I want to thank everybody for their input.
First you can replace the headlight housing from underneath the fender well without removing the bumper. You will have to loosen the bumper on the side that you are changing.
It is very simple but will require the wiggling the light housing until it goes into place.
So follow the instructions posted on how to change the fog light.
Loosen the bumper three bolts two in center for hood support and the one near the light assembly. See the posting on how to remove the bumper from a SLK 350.
There is a brace, inside the fender well and underneath the light assembly that goes to where he fender and bumper meet. Remove that brace.
There is also a bolt holding the light assembly in place under the light housing. You will have to remove it and the two on top of the light housing.
From there you will be able to drop the light assembly down through the fender well once you unhook all the lights.
Reverse the procedure to install.
It was really very easy.
SLK 55 AMG vs SLK 280/350 Body/bumpers B4TM4N SLK R171 General Discussion 4 08-29-2008 05:35 PM
01 280 SLK bumper fit a 01 230 Slk? ziagroup SLK R170 General Discussion 4 07-25-2008 05:14 PM
09 SLK 350 - 06 SLK 280 Comparison WhiteRabbit SLK R171 General Discussion 53 05-13-2008 09:21 AM
SLK 280 vs. SLK 55 AMG - Suspension setup B4TM4N Performance MODS for the R171 4 11-13-2007 04:17 AM
Nav system 05 SLK changing display features lummer Ask DansSLK 3 03-16-2007 02:19 PM
Powered by vBulletin Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SLKWorld 2006-2010
Design by Fife Web Solutions
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226
