Windrestrictor
Old 09-29-2006   #1 (permalink)
Default Power failure
Has anybody experienced that the power was lost about 5 seconds after hard acceleration?
It was gone for 2 seconds, and then it came back again. A little bit scary indeed.
I have the 5-speed AT and I’m not sure if the problem occurred when shifting from first to second gear.
Bengt
View bejak's Photo Album bejak is offline
Old 09-29-2006   #2 (permalink)
Ynot's Avatar
Bengt
I had that problem when I drag race my brother, I over revved it and the engine shut off for a second or two, did you have it on manual shift? Did you over rev it? It's normal, the electronics is stopping you from ruining your engine.
Old 09-29-2006   #3 (permalink)
Don't worry about i have accidentally over revved a manual SLK and had the same thing happen like Ynot says its just the computer killing the power you will have the same problem if you floor the throttle with the car in neutral where it will kill the power way before the red line for your engines benefit.
Old 09-30-2006   #4 (permalink)
Well, over revving with the automatic transmission? Is it possible? The gear box should shift up to next gear when the engine is on top rev, or?
Perhaps the right rear wheel lost grip and some electronic gizmo shut off the power momentarily?
Bengt
Old 09-30-2006   #5 (permalink)
Yeah if a wheel lost traction then thats the feeling you get it is quite invasive the tranny will hold a gear to almost the red line if you are pushing it but it wont over rev it no
maf sensor failure jbanks15 Ask DansSLK 5 07-29-2008 05:29 PM
Intermittent indicator failure... Rhino SLK R170 General Discussion 1 05-27-2008 06:36 PM
SLK350 spring failure pjgraham86 General Discussion 4 01-14-2008 01:07 PM
Transmission Failure CDN-SLK55 SLK R171 General Discussion 15 03-23-2007 06:43 PM
HD Failure easty Off Topic 10 10-20-2006 08:05 PM
