Welcome to SLKWorld
Old 08-27-2008   #1 (permalink)
Vehicle: Black with black 2005 SLK350. Roof module, chrome door pins, AMG bonnet vents, R170 antenna.
Default Fuel tank capacity - 70 litres / 9 litre reserve.
So...I'm confused.
Depending on what reviews / stats you read the tank capacity for an R171 SLK is 70 litres with a 9 litre 'reserve'.
What does this mean?
Does it mean when I get down to zero miles range on the computer I've actually got 9 litres of fuel left?
What does a 'reserve' tank actually mean?
Clarification would be good!
Cheers!
View jfb1977's Photo Album jfb1977 is offline
Old 08-27-2008   #2 (permalink)
The reserve is whats left when the fuel warning light comes on.
The Following 2 Users Say Thank You to DansSlk For This Useful Post:
Old 08-27-2008   #3 (permalink)
Cool. So, just to make sure I'm crystal on this - when the "reserve fuel" orange light comes on (which for me is normally around 35 miles) I've got 9 litres to go?
Sorry if that's a dumb question!
Old 08-27-2008   #4 (permalink)
Yeah but you probably wont be able to use all of that because you get that bit of capacity below the inlet or thats on the wrong side of the slosh barrier, factor it for say 7 ltrs when the light is on.
Old 08-27-2008   #5 (permalink)
dltslk's Avatar
Other Toys: 1968 Pontiac GTO
Donation Level 8
Yeah, I figure I have 1 1/2 US gallons left when the light comes on which means the way I drive the 55 it's time to find a gas/petrol station FAST!!!
David
View dltslk's Photo Album dltslk is offline
Old 08-28-2008   #6 (permalink)
With modern fuel system in vehicles being under pressure, I don't think it wise to drive to the point where the warning light comes on. I read somewhere that if the fuel tank goes to empty and air gets in the fuel line, it is difficult (PIA) to prime the fuel lines. Is this accurate info?
Old 08-28-2008   #7 (permalink)
If you drove it to a stall then yeah would have air in the lines and it would have to be forced out by the pump so thats stress it could do without, it's the sediment that concerns me because it sits just waiting for the tank to run low and the pump to suck it up and send it on the way to the engine.
Old 08-28-2008   #8 (permalink)
Founding Member #7
mtiede's Avatar
hmmph. Doesn't the fuel line always suck from somewhere near the bottom of the tank? So sediments would always be a risk?
Old 08-28-2008   #9 (permalink)
No not right at the bottom, its a lift pump and it uses the fuel for cooling so it likes to keep as much fuel around it as possible.
The muck is right at the very bottom, the last place the pump can take fuel from, remember its not like a water pump with a single intake it can take fuel from multiple levels.
Old 08-30-2008   #10 (permalink)
Senior SLK World Member
Vehicle: A200, SLK R171 350
Hey boys
I have driven my car until the RANGE says 0 kms which I quickly drove into the next petrol station!!
View ellimb's Photo Album ellimb is offline
Next generation SLK engine capacity Tslick AMGs 3 07-08-2008 07:16 AM
Low Power With a Full fuel Tank BENZO Ask DansSLK 9 07-01-2007 07:59 PM
Windscreen washer tank Zut SLK R171 General Discussion 9 01-13-2007 04:14 PM
SLK55 Oil Capacity bloflin Ask DansSLK 3 01-08-2007 02:24 PM
SLK cargo capacity reallife General Discussion 5 07-28-2006 12:27 PM
