| Senior SLK World Member Join Date: Jan 2008 Location: Studio City
Vehicle: 09 SLk55
Country: Thanks: 2
| Hello. how complicated replacing the leather cover over the gear lever. Like to take it out and match the stiching with red to match the interior |
| | #2 (permalink) | |
Vehicle: 2009 SLK 55 AMG
Country: Thanks: 8
a search of the forum will produce this entry from Dan: 1) Put the shifter into N 2) Grab the driver side of the leather covering and push it to the passenger side (It will release) 3) Lift the leather cover and turn the release key on the shift lever 4) Pull the shift knob and leather cover up and they will pop off the lever
__________________ Jeff 2009 SLK 55 AMG Black/Black Premium 1, Multimedia, Lighting packages Clearshield Protective Film OEM MB Plexiglass Windscreen Eurolight Clear Side Markers Smarttop version 3.22 Kleyman 3rd Brake Light Flashing/Strobing Module V1.5 (Noregrets Custom Works) | |
| The Following User Says Thank You to jbanks15 For This Useful Post: |
Country: Thanks: 376
| Is there a reason to put the shift lever on Neutral (N)? Is it just for ease of removal because of the angle of the shift lever? The reason I ask is I was able to remove the grear shift knob using the above procedure but with the transmission on P. I was looking for a way to remove the #$%^! blank piece of aluminum on the 55 gear shift knob.
Country: Thanks: 96
| Its just habit for me to put the shifter into N before going to remove the covering since I'm normally in the process of removing a dash and we have to disconnect the battery to do that so the shifter becomes locked and if its locked in P we can't remove the cubby/lighter and the AC controls. If your just removing the shifter then you can omit the N part.
| The Following User Says Thank You to DansSlk For This Useful Post: |
Vehicle: 09 SLk55
Country: Thanks: 2
| Speaking of te black top of the shifter.... I really dis like the way it looks... Will the non amg star fit? At least it will have the star insted the blank Unless i can by the AMG version..If any one knows the part number. |
| A non-AMG shift knob will fit (e.g., from the 350, 280/300 with the 7G auto transmission). I inquired from parts department; however, MBUSA will sell it as an entire assembly only, ie., gearshift knob assembly with the leather shift gear cover; cost about $260.
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Mod. R170 ant., EuroClear sidemarkers w/PIAA PlasmaIon lamps, chromed front & rear turn indicator lamps, PIAA SuperPlasmaGTX front parking lamps, bilateral rear fog lamps enabled. Last edited by etyu; 08-04-2008 at 01:31 PM. |
| | #8 (permalink) |
Country: Thanks: 96
| Toward the driver for the RHD
| Cleaning the Leather | Nena | General Discussion | 11 | 09-07-2008 11:43 AM |
| Gear Lever Badge | KTownAMG | General Discussion | 8 | 06-23-2008 01:36 PM |
| Spare leather? | richard_leeds | Where to get R171 SLK Items | 8 | 06-20-2008 12:30 PM |
| Seat lever | GrubbyGirl | Ask DansSLK | 4 | 06-29-2007 12:00 AM |
| Change the gear change/automatic gear box SLK 280/350 | Banned | General Modifications R171 | 8 | 02-05-2007 10:37 PM |
