Old 07-31-2008   #1 (permalink)
Vehicle: Silver 55 AMG
Default Odd problem....
I noticed that my rear right turn signal light and the right license plate light is not working. I tried checking the bulbs, and the contacts. The contacts are not getting power. Also, i checked the fuses and all of them are good. It seems like an odd problem that only 2 bulbs are not getting power. All other lights work. Any help would be greatly appreciated. Thanks in advance.
View vegeta's Photo Album vegeta is offline
Old 07-31-2008   #2 (permalink)
Normally what I'd do here is first a simple continuity check so I'd disconnect the applicable connectors from the Rear SAM, then disassemble the connector (simple really) and use a multimeter to check line resistance on the +12 line then put the connector back together and then do a check on the ground.
If the wiring is good then the fault is in the SAM, either in coding or a hardware failure and thats when I'd get out the DAS and test it.
Are you not getting any sort of "bulb out" warning?
Old 08-01-2008   #3 (permalink)
No "bulb out" warning at all. That is what I found very odd. If I get a chance this weekend, I'll take a look at it. If I can't get to it, I am planning on bringing the car to the dealer on Monday and see what they can do. Thanks Dan for the help.
Old 08-14-2008   #4 (permalink)
Default Update
Went to the dealer today and they checked it out. The SAM needed to be replaced. So it was taken care of under warranty and all is well again. Thanks again Dan.
problem after problem HwoALanG SLK R171 General Discussion 19 02-11-2008 06:35 PM
Do other MT owners have this problem? mcat SLK R171 General Discussion 18 07-03-2007 03:01 PM
oh my god ~ problem after problem. HwoALanG SLK R171 General Discussion 23 05-29-2007 11:40 AM
Odd Exchange w/SLK owner... webslinger SLK R171 General Discussion 38 05-25-2007 03:17 AM
The odd holes Corkscrew SLK R171 General Discussion 4 11-22-2006 09:00 AM
SLKWorld 2006-2009
