Go Back   SLK World Forum > Mercedes Benz R171 SLK Class Cars > SLK R171 General Discussion
Visit Autogeek.net
Old 07-06-2008   #21 (permalink)
Default What is the optimal operating temp?
Originally Posted by Duo-Art View Post
Once your oil reaches its full operating temperature, the gasoline and water vapor that blow past the piston rings is vaporized (boiled away) and is removed by the crank case ventilating system. That's why short trips are not good for an engine, the oil doesn't get hot enough so sludge developes.
What is the best operating temperature for the SLK engines? Is there a range?
View etyu's Photo Album etyu is offline   http://www.slkworld.com/Boss Key
Old 07-06-2008   #22 (permalink)
Right! That was discussed at our Mercedes Club meeting. As we all use our cars for short trips as well as long one, the advice for mid-enterval oil changes was given.
The SLK -- What the SL was supposed to be.
View Dolebludger's Photo Album Dolebludger is offline   Boss Key
Old 07-06-2008   #23 (permalink)
Founding Member #7
mtiede's Avatar
Mine appears to be up to operating temperature in about a mile (if I recall rightly). I think the heater is putting out heat in less than a mile.
View mtiede's Photo Album mtiede is offline   Boss Key
Old 07-06-2008   #24 (permalink)
So does mine. Yet, for reasons I can't explain, our "panel of experts" at our Mercedes Club meeting all were of the opinion that taking short trips does take its toll on the oil. On my two non-Mercedes vehicles (Honda S 2000 and Ford truck) the owners' manuals say 7K mile oil changes for long distance driving, and 3.5K mile oil changes for cars frequently used for short trips. I'm not smart enough to know the "why of all of this.
Another related thing our panel of experts mentioned was on the question of using high change interval synthetic oil (such as Mobil 1) in cars that didn't come with synthetic oil. The consensus was "don't". Their explanation was that the gaskets and fittings in the oil system of some cars are not designed for the thinner viscosity that the synthetics develop at full engine heat, and leaks may be developed. Again, that's what the experts said, but I'm not smart enough to explain it further.
Old 07-06-2008   #25 (permalink)
Donation Level 6
O.T. Synthetic oil is great for lubricating moving garage door parts in cold weather. It works better than anything else that I've tried.
View Duo-Art's Photo Album Duo-Art is offline   Boss Key
Service A - Oil Change Excess tai230k SLK R171 General Discussion 14 03-23-2008 09:32 PM
Quick question, oil gauge shows 9.0L after oil change cyberdrakon Ask DansSLK 8 03-06-2008 01:45 PM
Oil Change microbe SLK R171 General Discussion 6 03-05-2007 03:37 PM
oil change jun127 General Discussion 0 02-24-2007 12:32 AM
oil change SLeeK350 SLK R171 General Discussion 10 12-10-2006 08:51 PM
