Old 06-02-2008   #1 (permalink)
Super Moderator
Default Mercedes UCI - Universal Consumer Interface
Keep your eyes open for retrofit kit's for this unit, i don't know quite how the facelift fit's into it if at all.
Basically its the retrofit of the USB (and others) setup in the new model's coming out that gives the the ability to connect any standard's compatible device to the car (MB specific compatibility is not required), just about everything will be supported and the system will also supply power to the devices.
This will be a serious upgrade from the traditional iPod kit since it will allow access to many more devices.
I will keep you guys informed as i find out more info with regard to headunit compatibility and so on.
View DansSlk's Photo Album DansSlk is offline   http://www.slkworld.com/Boss Key
Old 06-02-2008   #2 (permalink)
Cool, much prefer USB (Universal Serial Bus) over the SD card slot, although I have none in my pre-facelift COMAND. Glad MB is catching up (albeit kinda slow).
Old 06-02-2008   #3 (permalink)
alroumi's Avatar
Will this be compatible to the older command?
06 Porsche Cayenne S
07 Jaguar XKR Coupe'
View alroumi's Photo Album alroumi is online now   Boss Key
Old 06-02-2008   #4 (permalink)
I wish the engineers would also consider retro-compatibility when they come out with new head units. It will also be good for business (parts and service departments), i.e., OEM retrofit kits.
Old 06-02-2008   #5 (permalink)
Super Moderator
The unit is compatible with the MOST architecture that has been on the 171SLK from the start, if it's compatible with the system software on the NTG2 COMAND (pre-facelift) i don't know at this time nor do i know if they will give the NTG2 a software upgrade for it.
This will be like the iPod kit or the phone kit, they are technically retrofit kit's that have all the parts under a common number and have detailed instructions for the install but if it will be a home mod i doubt it, there is going to be a lot of work to fit it in but they might surprise me and as soon as i know something i will let you know.
Hopefully it will be for both pre and post facelift car's, it does mention control from the steering wheel and the headunit by the way.
Old 06-02-2008   #6 (permalink)
I ordered this option and have it in my SLK55... minus the white 'connections' box (under investigation). Option shows up in Comand as 'Media Interface'.
Quote from Mercedes:
Stuttgart – One simple move is all it takes: with the new Mercedes-Benz Universal Media Interface it’s easy to hook up cutting-edge mobile entertainment and communication devices such as USB-based MP3 players, music mobiles or the iPhone® to the on-board audio system. The interface, from Mercedes-Benz Accessories GmbH, is designed to allow customers to integrate the latest mobile multimedia technology into the existing vehicle architecture in various model series. The Universal Media Interface is compatible with the Audio 20 CD, Audio 50 APS and COMAND APS audio systems. When combined with the Audio 20 CD, which does not feature an integral navigation function, the interface also allows GPS map navigation.
Our desire not to be without our personal collection of music and images when on the move is growing in significance all the time. As a result the market for portable multimedia devices such as USB-based MP3 players, music phones and iPods ® is booming. The problem: the commercial solutions available for connecting up these entertainment devices on board have, until now, always involved a clear loss in quality. Help, however, is at hand: in the form of the new, retrofit Mercedes-Benz Universal Media Interface, an intelligent and particularly user-friendly solution. It allows external devices to be used via the on-board audio system – with the highest playback quality, convenient controls and perfect integration into the vehicle architecture.
Further advantages for the customer: following installation of the i nterface by a specialist Mercedes-Benz workshop, no further hardware or software installations are required. The module is discreetly located in the glove compartment, and external multimedia devices are quickly and simply connected “plug & play”-style. In addition to the relevant connections for various end devices, the interface also offers an SD card slot. To activate the various multimedia functions, all the user has to do is press the AUX button on the car radio. The convenient rotary controller on the centre console can then be used to navigate the clearly structured menus and select the required functions.
Perfect map navigation as a retrofit
The new Universal Media Interface can do even more: customers who use the popular ex-factory Audio 20 CD system, which does not feature integral navigation, benefit from a convenient retrofit navigation system when they select the Universal Media Interface. In addition to the required navigation software, the module set includes the latest map data for .
The system uses several information sources – such as the speed of travel and GPS coordinates – to pinpoint the location of the vehicle. Using the controller in the centre console is particularly convenient and safe. The map appears in the existing display and arrow symbols in the car’s instrument cluster indicate the recommended route. This means that there is no need for an additional monitor, which would impair the interior harmony.
The destination can be input without a time delay as the map data is stored in the internal memory. Calculation of the route is also instant, thanks to the system’s powerful processor. Numerous additional characteristics make na vigation exceptionally versatile. The standard TMC function (Traffic Message Channel) warns of tailbacks in real time and recommends diversions. The angle of the map depictions can be adjusted or switched to “Bird View Mode”. Audible directions can be given in 14 languages .
The system is always up-to-the-minute: because the Universal Media Interface features an SD card slot as standard, updates are simple to upload using the appropriate SD card, which can be purchased retrospectively as an option. This makes the Universal Media Interface an attractive and fully integrated retrofit navigation solution.
Unrestricted operating comfort
The music part of the new interface is perfectly integrated into the vehicle architecture. The driver can control all of the music functions – such as scrolling through playlists, navigating through menus, fast forwarding, rewinding or repeating a track – using the controller in the centre console. The audio system’s colour display ( five-inch screen with Audio 20 CD and Audio 50 APS and seven-inch with COMAND APS ) informs the user, among other things, of the title of the track, the name of the artist and the current mode of the MP3 player.
The music functions can also, as an option, be operated via the multifunction steering wheel. Here the most important information is displayed in the instrument cluster.
The power supply solution is equally elegant: the Mercedes-Benz Universal Media Interface automatically powers up the battery of the portable communication and entertainment devices via the on-board power supply as soon as the connection is established and the ignition is switched on. When the device is removed from the glove compartment after a long drive, the battery will be fully charged.
Video library and image database on board
Another special feature is planned for the COMAND APS control system: using the Universal Media Interface it will be possible to view photos or videos, for example from an iPhone , iPod , media player or digital camera, in the on-board display.
The Mercedes-Benz Universal Media Interface will initially be available for the Audio 20 CD system in the two new C-Class model series – Saloon and Estate. The market launch is planned for the 1st quarter of 2008. It will gradually be extended to other models series. Connection of the interface to the Audio 50 APS and COMAND APS audio systems will follow in a second development stage. A preview of the new Universal Media Interface will be provided during the International Motor Show in.
The functions of the Mercedes-Benz Universal Media Interface at a glance
When combined with the Audio 20 CD audio system, the Mercedes-Benz Universal Media Interface offers the following functions, which are shown on the display:
· Map navigation
· Integration of a USB-based MP3 player or a USB stick with audio files (“USB”)
· Playback of MP3 audio files saved on an Apple iPod® or the new iPhone® (“iPod/iPhone”)
· Connection to a conventional external audio device (“AUX”)
· Wireless transmission of audio signals by Bluetooth® (“audio streaming”)
When combined with the Audio 50 APS audio system and the COMAND APS control system, the Mercedes-Benz Universal Media Interface offers the following functions, which are shown on the display:
· Integration of a USB-based MP3 player (“USB”)
· Playback of video clips, photos and album logos from iPhone® and iPod® planned for COMAND APS in second development stage (“Video”)
View SLK55UAE's Photo Album SLK55UAE is offline   Boss Key
Old 06-02-2008   #7 (permalink)
Wimbledon_SLK's Avatar
Vehicle: SLK 280
Other Toys: Honda VFR 750
Yes i have ordered it too.
P
View Wimbledon_SLK's Photo Album Wimbledon_SLK is online now   Boss Key
Old 06-02-2008   #8 (permalink)
Vehicle: SLK 280
UMI (Universal Media Interface)
The long awaited arrival of the new UMI box is almost upon us! This fantastic new product available only for the New C-Class (W/S 204) works in conjunction with the Audio 20 system.
With the UMI fitted to your New C-Class it will turn the Audio 20 into full 3D European navigation mapping system!
The UMI also has connection ports for USB, AUX and iPod. With an iPod connected you get full integration and can use the steering wheel controls to navigate through your iPod while it charges.
You can also stream music to the UMI direct from your mobile phone. The UMI is discreetly fitted in the glove box of your C-Class to hide it from prying eyes. Due early June with pre-orders being taken now! Fitted price is to be confirmed but we expect an approx fitted price of £800-£1000.
Old 06-02-2008   #9 (permalink)
-1-
Don
-1-'s Avatar
About time. Those with the Audio 20 were stuck in time with very few options other than a complete head unit replacement. We eagerly await the cost and installation requirements. Thanks for the info guys.
THE MON55TER ON THE BLOCK
View -1-'s Photo Album -1- is offline   Boss Key
Old 06-02-2008   #10 (permalink)
Founding Member #7
mtiede's Avatar
C-Class only?
View mtiede's Photo Album mtiede is offline   Boss Key
Old 06-02-2008   #11 (permalink)
vincent007's Avatar
Vehicle: White '09 SLK 350
Other Toys: Honda Valkyrie, Honda Ridgeline
Send a message via AIM to vincent007
I'm picking my '09 SLK up today and 'm going to be real disappointed if I can't retrofit this in....
I thought the new C-class and the '09 SLK had the same command?
Vinny
View vincent007's Photo Album vincent007 is offline   Boss Key
Old 06-02-2008   #12 (permalink)
This is an option (518) with all recent Mercedes cars, new and facelifted with the new audio systems. That includes the new C, CLC, SL, ML, SLK... also for future 2009 I guess. Around US$240 option.
The Following User Says Thank You to SLK55UAE For This Useful Post:
Old 06-02-2008   #13 (permalink)
Vinny
Yes... they have the same comand as far as I know. I am sure it can be retrofitted assuming its requires only a cable and a module.
Old 06-02-2008   #14 (permalink)
Vehicle: SLK 280
Correct! I ordered it for my new SLK
Old 06-02-2008   #15 (permalink)
vincent007's Avatar
Maybe DanSLK can comment and clear up my confusion on this for the SLK....
Old 06-02-2008   #16 (permalink)
Vehicle: 05 350
The comments about GPS on the Audio 20 are interesting. I think they must mean the new Audio 20 which has a ful colour screen? The previous version has a simple dot matrix single colour display.
Edit: The MB UK website says "Only available in conjunction with integral 6 CD changer, Audio 50 APS or COMAND" ... http://tinyurl.com/6x4hsd
View richard_leeds's Photo Album richard_leeds is offline   Boss Key
Old 06-02-2008   #17 (permalink)
HwoALanG's Avatar
Vehicle: 2007 SLK 280
Donation Award
i want one ~~~ where can we get it?
View HwoALanG's Photo Album HwoALanG is offline   Boss Key
Old 06-02-2008   #18 (permalink)
Super Moderator
OK guy's i think there's some confusion here, this is for a device that allows different audio feeds to be connected to the car's ICE network, don't expect it to give the whole nine yard's that MB are going on about.
If you have a post facelift car then you can get the factory option retrofitted for better functionality, IF this unit is compatible with pre-facelift car's then it will probably emulate the CDC and you will not have the option to do anything other than feed music from it.
It will be available as a retrofit for a wide variety of model's, it's just going to start with a few.
For those asking about the COMAND, NO the SLK facelift COMAND is not the same as the new C class COMAND, the SLK unit has more in common with the pre-facelift unit than the model's with the control panel and display screen separate.
