Go Back   SLK World Forum > Mercedes Benz R171 SLK Class Cars > SLK R171 General Discussion
Tire Rack- Revolutionizing Tire Buying
Old 05-24-2008   #1 (permalink)
Vehicle: 2009 SLK 55 AMG
Default question smarttop v 3.1
hello all
just finished installing smarttop v 3.1 on my new09 slk 55.
question. using remote, 3 click top goes up and windows close.
but when in car and tap on center console 1x to close roof and roll all windows up, it does not shut any of the windows.
funtion 2 is set at 2=ignition off allowed. i put it back to setting 1=on and it also does not shut the windows. i have to shut manually.
any ideas? thanks
Premium 1, Multimedia, Lighting packages
Clearshield Protective Film
OEM MB Plexiglass Windscreen
Eurolight Clear Side Markers
Kleyman 3rd Brake Light Flashing/Strobing Module V1.5 (Noregrets Custom Works)
View jbanks15's Photo Album jbanks15 is offline   http://www.slkworld.com/Boss Key
Old 05-24-2008   #2 (permalink)
Someone (IIRC, WhiteRabbit) did post that the roof control lever on the center console doesn't work like before (not because of SmartTop) but MB has changed the "instructions" in MY 2009. Two clicks on the center roof control lever doesn't work on the windows either. After the roof is raised (using center console control button), the windows have to be closed manually using the window control buttons on the door panel. First the main windows, and if you continue to push and hold, then the quarter panel windows.
Old 05-24-2008   #3 (permalink)
thanks for quick reply etyu. emailed mods4cars anyway. will wait until car cools before attempting filters and those darn clear markers again
another question. when i program the speed, what is the sound the car makes to confirm? a horn sound, 2 horn sounds, a beep? i heard all three
but i must say, this install of the smarttop was quiker then the vario roof mod. i spent 3 hrs with that and 2 hrs taking that canbus cover off. this time i followed your advice and additionally approached it from the back. didn't break anything for a change
View jbanks15's Photo Album jbanks15 is offline   Boss Key
Old 05-24-2008   #4 (permalink)
WhiteRabbit's Avatar
Vehicle: 2009 SLK 350
Originally Posted by etyu View Post
Someone (IIRC, WhiteRabbit) did post that the roof control lever on the center console doesn't work like before (not because of SmartTop) but MB has changed the "instructions" in MY 2009. Two clicks on the center roof control lever doesn't work on the windows either. After the roof is raised (using center console control button), the windows have to closed manually using the window control buttons on the door panel. First the main windows, and if you continue to push and hold, then the quarter panel windows.
As noted above, this is exactly what I found on my 09. It still annoys me that the windows do not go up with the top when using the inside roof button. More than once I raised the top and got out of the car before I noticed that the windows were still down. Even that would not be so bad if a double-click of the roof button raised all the windows like it does on earlier model cars. Bummer. I could use the key to raise the top & windows after I get out of the car but don't like to do that as it is drain on the car's battery.
2009 SLK 350, Arctic White, Gullwing Red, 7G Automatic, Premium PKG I, Lighting, Heating packages, Auto Climate Control, smartTop roof module v3.22, Clear side-marker lenses.
View WhiteRabbit's Photo Album WhiteRabbit is offline   Boss Key
Old 05-24-2008   #5 (permalink)
Click it or ticket!
SLKCop's Avatar
I wouldn't worry too much about that. You should be able to raise/lower the roof several times on battery power alone without negatively affecting it.
Mike
View SLKCop's Photo Album SLKCop is offline   Boss Key
Old 05-24-2008   #6 (permalink)
white rabbit, can u comment on this:
Old 05-24-2008   #7 (permalink)
I think it was just a single chirp when it engaged but I did it 3 weeks ago and can't be sure now. I think it gave 2 chirps when I tried to lower the top while the car was moving but before I had set the speed limit for it.
Old 05-24-2008   #8 (permalink)
another question. when i program the speed, what is the sound the car makes to confirm? a horn sound, 2 horn sounds, a beep? i heard all three..
IIRC, on mine it was a single beep while I was at 30 mph. There were no horn sounds.
Jbanks, did you notice (before SmartTop install) if the car would chirp on lock/unlock (on the MY 2008 it would, so I didn't do the reseat fuse procedure)? On the SmartTop install, did you reseat a fuse in the engine compartment fusebox (driver side)? This may explain why you have a horn sound on top of the beep.
Old 05-24-2008   #9 (permalink)
... I could use the key to raise the top & windows after I get out of the car but don't like to do that as it is drain on the car's battery.
If you raised the roof already while parked and you notice the windows are still down as you walk away, just use two clicks on the SmartKey lock button, and the SmartTop will close the windows for you.
Old 05-24-2008   #10 (permalink)
before install, 09 does chirp once on unlock and 3 on lock. i did not do the fuse reseat. so i think i heard the horn and not a chirp. anyway so far i can put it up or down at less than 30 mph which is the area i set it at.
Old 05-24-2008   #11 (permalink)
I have mine set at 30 mph but only retract/raise the roof at parking lot speed (5-15 mph), no speed bumps. This way the roof won't stop midway if for some reason one goes a tad faster than the programmed speed limit.
Old 05-25-2008   #12 (permalink)
Actually I have the window activation on two key clicks turned off. Twice in the pouring rain I hit the unlock button twice while running towards the car and of course all the windows went down. So rather than risk soaking the car I don't use that feature of the SmartTop. I could also just use the IR feature of the key to raise the windows if I'm close enough to a door for it to work.
Old 05-25-2008   #13 (permalink)
Donation Level 4
Guys - any one want to point me to a good vendor for a SmartTop? (Forum sponsor?)
View UK-C200's Photo Album UK-C200 is offline   Boss Key
Old 05-25-2008   #14 (permalink)
http://www.wilhelmy-it.de/ not a sponsor as far as i know.
Smarttop Purchase shpritz Where to get R171 SLK Items 10 06-06-2008 04:56 PM
SmartTop Module Woolly General Modifications R171 21 04-08-2008 05:18 PM
SmartTOP install help! ocninc Performance MODS for the R171 2 07-23-2007 12:32 PM
mods4cars smartTOP thanosSLK General Modifications R171 67 04-10-2007 02:24 AM
Mods4Cars SmartTop Woolly Where to get R171 SLK Items 8 12-15-2006 12:18 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
