Old 05-03-2008   #1 (permalink)
SLK World Junior Member
Vehicle: SLK 200
Default Door Light
Hello to all the forum!
I've just buy a 2006 SLK 200 Black and I see that the car doesn't have the door light for foot area illuminating once the door is open. Pratically is the light that is assembled in the bottom part of the door and came with the interior light package.
Is it possible to install as a retrofit?
Has anyone do it?
For me it would be very useful because I'm living in a dark country area.
View lcerini's Photo Album lcerini is offline
Old 05-04-2008   #2 (permalink)
Lifetime SLK World Member
ir-ops's Avatar
Vehicle: happily owning a 2008 black on black manual/sport r171 200k f/l since july 2008
Donation Level 5
do you live in Middle-Earth?
just kiddin'...
warm welcome aboard and enjoy your new ride.
my tech knowledge is very limited, so i leave the reply to your question to other members. dan is the tech guru around here, he 'll be happy to advise...
best
ir-ops
View ir-ops's Photo Album ir-ops is offline
Old 05-04-2008   #3 (permalink)
rlbawk's Avatar
Vehicle: 2008 Yukon Denali
Other Toys: 2006 BMW 325 Convert
Welcome to the forum and I'm with ir-ops....Dan can answer about anything for you.
Randy B
Black - Black/Ash, PII pkg, Airscarf, Green Filters, Clear side markers, chrome turn signal bulbs,
Smarttop module, 19" TSW Snetterton Wheels, Chrome fins, Custom Windrestrictor.
View rlbawk's Photo Album rlbawk is offline
Old 05-04-2008   #4 (permalink)
Thanks guys.
Are you sure you actualy dont have the light fitted at all? It could have just blown a bulb.
If its not fitted you can retrofit it simple enough really its just a short length of wire and a bulb holder.
Old 05-04-2008   #5 (permalink)
My prior 280 did not have the convenience package (as labeled in the US), so there were no ambient lighting. The area underneath the door will show a rectangular indent where the light fixture would be. This will have to be punched/cut out and I don't know if the wiring loom/harness is already inside the door panel or not.
I'm fairly certain that Dan can figure a way to get the lamp assembly (this has the lampholder, wedge 5W, and translucent shield molded as one) connected.
Old 05-04-2008   #6 (permalink)
Vehicle: SLK 200
Default Light assembly not present
Thanks for the reply! This forum is simply fantastic!
I saw from the bottom of the door that are present the housing (rectangular indent) for the lights.
I'm just thinking to assembly the lights by myself but I don't know were to find the lamps assembly.
Does anyone know if the wiring harness is already present?
Old 05-04-2008   #7 (permalink)
Vehicle: SLK 200
Wink
just kiddin'...
best
ir-ops
Not really... I leave in Italy near the Chianti area ! The place were I park is quite dark and I think that in winter the lights under the door are a must have!
Old 05-04-2008   #8 (permalink)
If you have the indentation's in the bottom of the door's then what you need to do is cut those out so you have a hole for the light fitting then you simply install the harness from the door controller to the fitting and your done.
The fitting can be brought from MB and i doubt the harness is installed but its only 2 wires so its very easy to make.
Old 05-04-2008   #9 (permalink)
ir-ops's Avatar
Donation Level 5
very nice icerini,
have been to italy several times, but never to tuscany.
would really love to come visit firenze, and take a winery tour around the region someday soon.
fan of chiantis and sassicaias over here...
brgds
ir-ops
Old 05-04-2008   #10 (permalink)
Default Pix and Part No.
Below are couple of pix of the door lamp:
door lamp at bottom of the door panel towards the rear edge
detail of door lamp assembly (molded part no. 203 820 08 01), use small flat head screwdriver to pry loose the rear part, bring rear part down as it pivots and then slide out:
Old 05-05-2008   #11 (permalink)
Vehicle: SLK 200
Thumbs up
Thank you very much for the pictures an the part number! Now everityng is clear!
Tomorrow I'll go to my MB dealer to ask for the lamps... I'm going to install them on the next week if I found the parts!
Maybe I will take some picture in order to make a step by step procedure for the forum.
Old 05-05-2008   #12 (permalink)
Default That would be great
...Maybe I will take some picture in order to make a step by step procedure for the forum.
That would be great.
I hope there's a wire harness in there somewhere with the connector on each door. If not, Dan may be able to tell us how to do the wiring.
Door Leather Baron7700 Caring for your SLK 18 1 Week Ago 02:02 PM
AMG smoked rear light clusters / 3rd brake light. jfb1977 Where to get R171 SLK Items 2 07-24-2008 11:40 AM
Light up door handles SLKman General Discussion 0 10-13-2007 04:42 PM
Any door rust? Tslick SLK R170 General Discussion 7 02-07-2007 12:34 PM
Door rattle bclark SLK R171 General Discussion 14 07-12-2006 08:34 AM
SLKWorld 2006-2009
