| Elite SLK World Member Join Date: Dec 2006 Location: EWR / CLE
Country: Thanks: 1
| Hi, In my searches for the right used SLK, I sometimes come across cars without the lighting package. How much would it cost to add the OEM Xenon headlamps? I'm not interested in aftermarket kits. Is it as simple as buying one of the headlight assemblies from eBay and putting them in? Like this auction? It says it includes the computer, ballast, and bulb, is there anything else I would need to get? Thanks. |
| Sponsored Links | |
Country: Thanks: 96
| Yeah this has been done before. I did notice some wiring differences at the SAM when i looked into it for someone a while back but that does not seem to cause any problems. Everything you need is attached to the headlamp assy, i don't know about the US so it might be worth checking this but in the EU they must auto level and that requires more wiring and sensors (The US lights auto level from the factory but as i say i don't know if thats good sense on MB's part or a requirement) Once you fit them you will need the computer coded to show Xenon present.
Country: Thanks: 1
| Dan, thanks...that's good to know it won't be too costly to retrofit. I imagine MB charges a lot more than $300 for each headlamp assembly. For some reason a lot of people didn't order the lighting package it appears. I find it odd that they are not standard. |
Country: Thanks: 1
| Duo-Art, I'm just trying to keep my options open in case I find a car I otherwise really like, but it is missing a feature on my "must have" list. |
Country: Thanks: 54
| I agree, factory xenons should be standard on the SLK. Other brands have them. Nissan equips the Maxima and 350Z with xenons as standard. I would assume less than half the SLKs produced have the bi-xenons. I agree, either factory or OEM retrofit for me. My wife's SLK 350 has the haolgens and I wanted the factory xenons. The dealer charges $1200 per assembly new. That was almost two years ago. I found a used set that was stated as a "matched set, like new". I paid $1200 plus shipping. What I received was not as stated, so I returned them for a refund. I went with 5000k H7 bulbs in her car and I like the look. I did the same with our VW NewBeetle and my Mazda6. Be aware that "most" SLK xenon assemblies for sale online have broken mounting tabs. Some are sold broken, other claim to have been repaired (glued). There was a german vendor who advertised "new" SLK xenon assemblies on eBay for $1200 per pair, plus shipping. That would be my recommendation if he's still around. I read of several who have swapped their halogen assemblies with the factory xenon assemblies with no problems other than not having the auto leveling feature and having to code the xenon=on function through the dealer.
| Elite SLK World Member Join Date: Feb 2008 Location: Yukon, OK
Country: Thanks: 40
| For what is is worth, I bought a new '07 SLK280 last November from an MB dealer at a "too-good-to-walk-away-from" price. It had most of the equipment I wanted, but not xenon lights. I checked around and was getting prices like $2700 USD for parts alone. Don't know if I could have eventually beat that. Hope so. But then I heard of Philips X-treme "plug and play" halogen replacements. They came in two models -- 55 watt road approved and 100 watt off road only. Price about $50 USD per pair. I heard that they give almost a xenon beam of light. I bought the 55 watt bulbs and installed them. They are VERY close to the xenons on my C 320 and Honda S 2000. Well worth the $50, and acceptable to me. I find the reflector halogen high beams to "pass muster." If I had to do this again, I would have installed the 100 Watt Philips X-treme bulbs in my low beams. Even though technically illegal, I do not think any cop is going to take my car apart to the extent needed to check this out. In your case, you could install the 100 watt Philips X-treme bubs in your low beams for about $60 in parts. Based on what the lower wattage versions have done for me, I would think these would equal xenons. Heck, I may move the 55 watt bulbs to my fog lights and get the 100 watt versions for the low beams myself. I agree that the SLKs and all Mercedes should come standard with xenon headlights. Daimler AG's savings from not having two lines of headlamp units per model should absorb the cost. |
| | #8 (permalink) | |
Country: Thanks: 54
| | #9 (permalink) |
| SLK World Member Join Date: Jun 2007 Location: California
Vehicle: 2006 SLK 350 Iridium Silver | 2007 CLS 63 AMG
Country: Thanks: 4
| when we bought my wife's 06 slk350 in aug05, it had every possible option on it, nav,airscarf,hk,etc, except the lighting... i thought we could live with it, but after about 6 months, I couldn't... (i drive it sometimes)... I did a lot of research, including the problems with certain aftermarket-plug-n-play kits ,etc etc, and the MTEC kit turned out to be rock solid, did the install myself, came out to 300 or so... Here's the write-up I did. http://www.benzworld.org/forums/r171...lots-pics.html |
| | #10 (permalink) |
Country: Thanks: 40
| Actually, I mounted 80 watt replacement bulbs (Silverstar) on the low beams and fog lights on my '92 Eagle Talon TSI (turbo) in '93 and they were working fine in '98 when I sold the car (can't say the same for the rest of the car). I merely suggested the Philips X-treme bulbs as a "mid-range solution" to the problem of not having xenons. (remember to get the "X-treme" brand). They are not as good as xenons, no doubt about it. Their acceptability depends on the driver's night vision (and mine is not good). Yet, I do well with the 55 watt X-teme bulbs in the SLK. They are, IMO a good "cheap fix." There are, of course, better solutions involving more money for parts and labor. There was a test of after-market bulbs reported on another Mercedes Board, from which I learned about these "X-treme" bulbs. Basically, I think they will work for some drivers, but perhaps not for others, for whom a more involved and costly fix may be needed. Again, I totally fail to understand why xenon headlights are not standard equipment on all SLKs sold in the US. They are all pretty much $50K MSRP cars, and at that price point, they deserve xenons. |
| Sponsored Links | |
| | #11 (permalink) |
| SLK World Junior Member Join Date: Mar 2008
| 100w bulb will push twice the amperage through the stock wiring and most importantly - relays. design philosophy is overbuild by at least 50% so i am thinking the stock relays are build to control a 75watt headlights max. also a 100w bulb might melt the reflector or god knows what else in that enclosed space. i would not risk it because god forbid in an event of a fire the insurance claim will most likely by rejected due to "bad equipment". alex few cars |
| | #12 (permalink) |
Country: Thanks: 96
| Thats true. The wiring is normally protected by the fuse but the reflector can melt before that (very messy)
| | #13 (permalink) |
| Elite SLK World Member Join Date: Oct 2006 Location: Ellicott City & Salisbury, MD
Vehicle: 2007 SLK 280
Country: Thanks: 4
| that's what i said ~~ first time i got the SLK 280~~ No Xeon???! but ~! least it's bi-xeon... xeon flashes... ^^;;; anyway~~ i was looking around to get xeon kit or bulb but i think i'm going for the bulb cause cheap and plug and play~ but i guess i will have to get 55watts.... question?! how many watts stock halogen light can output? |
| | #14 (permalink) |
Country: Thanks: 40
| The stock low beam bulbs are also 55 watts. But the upgrade bulbs put out more light of a whiter color that gives more visability. |
| | #15 (permalink) |
Country: Thanks: 4
| Dealer won't install aftermarket parts!!!! i got it from one of my friend... he was selling his car and luckly he gave his hid kit to me and it was the H7 which is right size...... so i brought it to dealer and they called me next day that they couldn't do it.... i'm gona try tuner shop and see if they can install it.... so hard to install headlight... ( i will do it for myself but i do not have space or time to do this....) gosh ~ anyone knows good ship around Maryland or Virginia? |
| | #16 (permalink) |
Country: Thanks: 96
| To be fair they can't really be expected to can they ![]() They could get into a lot of trouble.
| | #17 (permalink) |
Vehicle: SLK280
Country: Thanks: 6
| Yeah I wouldn't think theres any way that a dealer would install an aftermarket HID kit onto the SLK. Way too many issues for them to deal with Any tuner shop/workshop should be able to do it, assuming that the HID kit fits. If I can do it in my garage with not much working knowledge, the professionals should be able to do it easily. |
| | #18 (permalink) |
Country: Thanks: 4
| well ~ i found tune shop that will do it for $80 per hour ~ i will be installing H.I.D by hopely tuesday so ~ i will post some pictures ! stay tune ! kit is o-nex and i think bulb is 4300K same as BMW ~ ( my friend gave to me -_- ) |
| | #19 (permalink) |
Vehicle: SLK280
Country: Thanks: 6
| good luck on that, let use know how it goes. Remember, you might need to bring it to the dealer to get them to program the diagnostics/computer that you now have xenons, so it doesn't think that the lights are blown(because of the lower current draw of the HIDs). |
