Windrestrictor
Old 10-30-2007   #1 (permalink)
Founding Member #3
mcat's Avatar
Default Understanding the operation of the light sensor
I would like to get a better understanding of the light sensor's operation in relation to the headlamps, dimming mirrors, comand display and autowipers.
The following used to happen before Mercedes Benz fiddled with the settings
- At dusk the dimming mirrors start to take on a green hue (slightly dimmed)
- Lights appeared to come on when they should
-comand display switches readily between night and day at levels I was happy with
- Autowipers were sometimes a bit slow of the mark.
And then when MB were upgrading my comand system they said they also reset the sensitivity of the light sensor as it was mismatched for the type of glass!!
I have not driven much since then to fully see the implications but the following now seem to happen.
- mirrors stay clear at dusk (good)
- lights come on more readily (not bothered)
- comand switches to night mode unless there is bright sunshine!!
- not driven in the rain so no idea what the effect on the auto wipers is.
I mention this to the tech when I dropped my car off for some body work. He said the comand should switch to night mode whenever the lights switch on. I am not sure I agree with that. Before they fiddled the two seemed to work independently of each other. My lights could be on and the comand will still be in day time mode.
So what is the true story. At what ambient light level should all these things switch?
View mcat's Photo Album mcat is offline
Old 10-30-2007   #2 (permalink)
They've not properly coded the RLS and now its malfunctioning.
It should work as follows -
Lights on at dusk
Interior lighting on shortly after lights
COMAND to night mode with interior lighting
The auto-dim mirrors are an independent system the rear view mirror has its own integrated sensor so it was likely a glitch that was causing them to dim when it got dusk, they should only dim when they see more light on the inside of the car than they do on the outside but i have seen some that do dim partly in dusk and we could find no reason as to why.
Sometimes the rain part of the sensor is a little slow off of the line to be honest with you.
The exterior and interior are 2 totally different systems to long as you have a light sensor installed, the exterior lights will come on first normally followed by the interior even if you where to set the exterior lights to off the COMAND would still switch and the interior lights would still come on.
The light switch has no effect whatsoever on the interior.
Old 10-30-2007   #3 (permalink)
Founding Member #3
mcat's Avatar
Lights on at dusk
What do you mean by the interior lighting? Is this the courtesy light that goes on when I open the door. I never thought about it before but are you telling me the door light only comes at night?
What is the RLS stand for?
cheers
Old 10-30-2007   #4 (permalink)
Interior lighting - All the lights on the inside of the car and on the doors, so thats the overhead lights, the puddle (courtesy) lights on the doors, the footwell lighting and the LED's for the console buttons.
They are not switched on during the day only at night, it saves the bulbs.
RLS = Rain and Light Sensor
Old 11-01-2007   #5 (permalink)
Founding Member #3
mcat's Avatar
I had the dealer check out my car today. I watched them on the Star Diagnostics. When they looked at the setting for the RLS it was blank. They tried to pick a setting (it is not clear which to pick either as there is about 5 options for r171 with no indication which to use) but no matter what he selected the RLS just would not store the setting and it kept returning to blank. The conclusion is that the whole mirror/light assembly unit is bust so they have ordered a new part which will come in next week.
In the mean time:
- My Comand is stuck on night mode
- My dimming mirrors won't dim
- My auto wipers think there is always water on my car
- My auto head lamps are permanently on
As Dan said I am not sure these all go through the same system so why would they all be inoperable at the same time. I don't hold out much hope of the new part solving the problem.
Old 11-01-2007   #6 (permalink)
I have had a look into this again mate and numbers 1, 3 and 4 are all managed by the RLS.
Number 2 is its own system but it does pass via the OCP so if it has failed then that could explain all 4.
But that would be a weird one if the buttons on it still work OK and all the interior lights come on when you open the door.
I am sure you already know mate but just in case -
COMAND can be set to day mode in settings
Wipers can be killed with stalk
Lights can be shut off by setting the light switch to O and setting headlamp mode to manual in the cluster.
As for the settings they depend on the type of glass and the installed lenses, perhaps this 'tech' should sit down and read the WIS before he starts playing with expensive bits of kit.
Old 11-02-2007   #7 (permalink)
Founding Member #3
mcat's Avatar
This would make sense as well. As the car thinks it is always night then the interior lights will always come on when the door is opened - which they do.
As for the type of glass and lens - why would they be different from r171 to r171. Don't we all use the same glass?
Old 11-02-2007   #8 (permalink)
Its weird normally if the OCP breaks the lights stop working.
As for the sensor settings, the SLK has more than one type of glass available and different lenses depending on the chassis number and the particular sensor version.
Perhaps they should have stuck to the old if it ain't broke don't fix it rule
Old 11-19-2007   #9 (permalink)
Founding Member #3
mcat's Avatar
Well, before the car was to go back in to have the whole sensor assembly replaced it started working again. I still went back to the dealer to get it checked out to make sure but told them not to replace anything. Everything was fine.
When there I asked them to upgrade the head unit so that I can get the ETA function on the front screen. They did it and I signed something so not sure if I will get a bill later or they did it as part of warrenty work.
Old 11-19-2007   #10 (permalink)
Glad it got sorted out by itself.
Old 11-19-2007   #11 (permalink)
Warranty covers that normally
AMG smoked rear light clusters / 3rd brake light. jfb1977 Where to get R171 SLK Items 2 07-24-2008 11:40 AM
Radio mutes with Roof operation?? nmslk SLK R171 General Discussion 20 04-23-2007 05:59 PM
Strange trans and engine operation in very cold weather resipsa Ask DansSLK 11 04-10-2007 01:33 PM
Rain and Light Sensor watoke SLK R171 General Discussion 5 02-26-2007 05:54 AM
Understanding FSS jbanks15 SLK R171 General Discussion 6 08-21-2006 11:08 AM
