Country: Thanks: 96
| Hey guys, I could be attempting an AirScarf retro on a customers car in the next few days/weeks depending on him, just starting the thread up now and i will document the process. As far as i am aware this has not been done before so it could all go horribly wrong but with a bit of luck it will be cool, going to try it without removing the interior first to help keep the costs down.
Country: Thanks: 288
| Good luck, It's going to be a hard install.
Country: Thanks: 54
Country: Thanks: 135
| Will be interesting to see the final result
Country: Thanks: 96
| Estimate on the cost is about £1k because so long as you have heated seats the mounting hardware and air intakes are pre-installed. This is on a 2006/2007 (i need to check) SLK55. John, Yeah you do need to get under the seats but you can position them to give you enough access to the cable tray without removing them and then you just need to use a cable puller to route the wiring. The whole install is only 10 wires.
| | #8 (permalink) |
Country: Thanks: 54
| It's interesting. The strong desire for the things we don't have and the effort and expense we go to get them.
| | #9 (permalink) |
Country: Thanks: 96
| I think in this case it was a compromise, buy an almost new second hand car with all the options bar one or buy a new car custom optioned and face the depreciation. Pay £5k and wait for a new one or pay £1k to upgrade.
| | #10 (permalink) |
Country: Thanks: 377
| Good compromise PLUS everybody else learns technical stuff from the retrofit.
| | #12 (permalink) |
| Founding Member #8 Join Date: Jun 2006 Location: Co. Durham, UK
Vehicle: 2004 SLK350
Country: Thanks: 28
| Dan, would every SLK of the same type (i.e. 1.8's, 2.8's. 3.5's and 5.5's) had the same wiring loom, regardless of spec, so, for example, I don't have heated seats or airscarf, but would there be connectors under the seats for them. I know, when I ordered my car back in '04, It was 'built to order', but would it have a different loom, just because of the options I chose/not chose? I could imagine the heated seats/airscarf have a fairly high current draw - are the 'heavy duty' cables for these just lying under the seat??
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. 2005 BMW LT - 16 countries, 2 CONTINENTS & counting 2004 MB SLK 350 Andradite Green (6 speed manual] 1999 Ducati ST2 2003 Vauxhaul Vectra 1974 Triumph Bonneville 750 T140V 1937 Norton 500 single (all still current) |
| | #13 (permalink) |
| From Dan's post (#7) above: "... so long as you have heated seats the mounting hardware and air intakes are pre-installed." Good question Woolly: what if you don't have heated seats, how much work is needed?
| | #14 (permalink) |
Country: Thanks: 96
| Its certainly possible to retro heated seats either by themselves or with AirScarf but when the cars are built they have custom harnesses made, you will have the main body harness that contains a certain set of wiring looms for basic systems and then each option will have its loom integrated into the main harness. The other issue is the control unit if you order heated seats / AirScarf / heated steering wheel you will have it installed ready if you don't have any of the above options then the unit itself and the associated wiring must also be installed. If i where going to retro heated seats and the scarf into a car with neither i would - Remove the center console with the floor and rear wall carpeting and seats. Remove the lining in the trunk and remove the tray and mounts used to hold the roof when its open i would also lower the equipment carrier to access the harness Open the cable trays and route 4 heavy duty cables down from the interior fuse box down the passenger (Driver's side for the US) side of the car into the trunk following the main harness then back into the driver's side of the cockpit. Install the N25 control unit on the driver's rear wall and connect power/gnd wiring to it, i would also connect it up to CAN at this point and configure the car to talk to it. I would then build a custom harness containing all the wiring for both the seat heat and scarf systems for the drivers side of the car and route it from the control unit to the X55 connection point for the drivers seat. Then do basically the same thing for the passenger side routing the wiring via the trunk. Now its just a case of putting the car back together and doing function checks on the wiring before installing the seats. I would strip the seats down and install the internal harnesses, carbon pads and blower motors then connect them to the seat control units. After doing a function check i would re-install the seats and would fit a new upper control panel with heated seat and AirScarf control switches. To do the whole thing no more than 1 days work. Woolly, the systems consume 25 amps at full power and the conductor cross section of the heavy duty wiring is 2.5mm2, not exactly 'heavy' but for a car environment its high capacity. Hope this helps
| | #15 (permalink) |
| Elite SLK World Member | This should be a warning to people considering ordering a car. Order your car with all of the options that you think you might want because adding them later is far mor expensive. If you are buying a used car or one from dealer stock, be aware of this also. |
| | #16 (permalink) |
Country: Thanks: 96
| I think it works both ways mate. In this case its going to be cheaper to retrofit the parts than to buy new by a considerable amount. Certainly you have options that are very expensive to retrofit such as COMAND that takes days but then you have things like HK that is a 2 wire retrofit and takes about 30 minutes. A full heated seat and AirScarf retro would cost about £2k for the parts and £700 in labor, the AirScarf with heated seats already installed will cost about £1k in parts and only a few hours labor. I think what you need when buying a used car is to first research the subject figure out what can and what cannot be reasonably done, with a little info you can get some great deals.
| | #17 (permalink) | |
Country: Thanks: 54
| | #18 (permalink) |
Country: Thanks: 96
| The interior carpet will be coming out for this retro now because the ground point i was planning on using has 4 devices already attached so i will be using the ground under the seat instead. Not sure exactly when it will be done but i will keep you posted.
| | #19 (permalink) |
Vehicle: 2006 Slk 350
Country: Thanks: 3
| this seems to be alot easier and cheaper than I could ever imagine . (not that it is either, i just expected it to be MUCH more difficult and involving more $) |
| | #20 (permalink) |
Country: Thanks: 96
| Yeah i think the massive difficulty thing has come from dealers not having enough skills to do the work so instead just feed people BS about how its completely impossible and then that person tells another who tells another and so on. Especially if they use forums info like that can spread real fast and of course some people capitalize on it and charge obscene rates for jobs only they are capable of performing but in reality anybody with electrical skills can do it perfectly fine. |
