| SLK World Junior Member Join Date: Aug 2006 Location: Florida
Other Toys: 2007 SLK 350, 2003 GMC Envoy, 2008 Lexus RX350
| I am at a loss to replace the cabin filter. I have located and removed the 3 torx screws under the glove compartment. I cannot go further trying to pull, push, or slide the cover. The right side is loose but the left side is "locked" if I may say so. I need the knowledge and expertise of Forum members who have already performed this replacement. Thanks in advance for your assistance The car is a 2007 model year. |
Country: Thanks: 96
| Pull out the torx screws and then grab the left side where it integrates with the center console and pull toward you its held on by a clip once thats out you can just remove the cover. You will then have access to the bottom of the airbox just unclip it and replace the filter, make sure you properly re-install the filter and its holder otherwise you will have an airleak. Same sort of thing applies to the under dash panel it has a hook that sits on a ring attached to the airbox make sure you align it correctly so they fit together otherwise the air from the airbox will not enter the flow guide on the panel correctly and will just heat up the equipment box.
__________________ One thing you will learn with German cars - If it's simple it ain't happening. Last edited by DansSlk; 10-09-2007 at 04:04 PM. |
Country: Thanks: 377
| Please post step-by-step pix when you're doing this so we can all learn from your experience. Thanks.
| | #4 (permalink) | |
Vehicle: 2009 SLK 350
Country: Thanks: 80
__________________ 2009 SLK 350, Arctic White, Gullwing Red, 7G Automatic, Premium PKG I, Lighting, Heating packages, Auto Climate Control, smartTop roof module v3.22, Clear side-marker lenses. | |
Country: Thanks: 96
| Its best to use the windscreen defogger mode first then test on full blower speed afterward. The air intake is different for both modes
| DIY: Service E Cabin Air Filter Replacement | slk350ncls63 | SLK R171 General Discussion | 32 | 08-26-2008 11:39 PM |
| Cabin Light Lights Sporadically | MBSLK-AMG | Help and Support | 7 | 08-01-2008 04:27 PM |
| Where is the cabin filter? | nlagos | General Discussion | 13 | 03-28-2008 12:32 AM |
| Cabin Filter Replacement | WhiteRabbit | SLK R171 General Discussion | 10 | 05-30-2007 05:37 PM |
| Noise in the Cabin... | watsons | SLK R171 General Discussion | 6 | 05-19-2007 08:45 PM |
