| Elite SLK World Member Join Date: Jun 2006 Location: Oak Park, Illinois, USA
Vehicle: 2005 Black SLK
Country: Thanks: 5
| In the past, much debate has occurred in these R171 forums about those rear center console speakers. Tonight, on the commute home in global warming temps, the iPOD a'blazing on shuffle served up some Flaming Lips "Do You Realize?" As you may recall, it begins with a funky "O..n..e, T..w..o, T..h..r..e..e, F..o..u..r" that in this venue (an SLK) issued forth entirely from those rear center console speaker. Yes, LYRICS, not simply ambience piped into the cockpit from the rear. Whoa! |
Vehicle: ///AMG
Country: Thanks: 17
| Congrats cannot really say i've noticed them much. Maybe I should play a little classical and listen real careful
| | #3 (permalink) | |
| Senior SLK World Member Join Date: Jun 2006 Location: Gig Harbor, WA
Vehicle: 2006 SLK 55
Yes, I have noticed vocals and real music from these speakers as well. If you put your ear up to them you can hear it distinctly. Ordinarily, the sound level is reduced so as to be just below your hearing threshold but great enough to add some ambience or fullness to the overall effect. I have always enjoyed the system and often listen in the car while sitting in the garage with the top up. The quality is amazing, notwithstanding all the complaints from people who haven't bothered to give the system an objective listening. | |
| Founding Member Join Date: Jun 2006 Location: Montréal QC
Vehicle: 2006 SLK350
| Lyrics probably can be heard from the rear but I don't think this is the main purpose of the rear speakers. I believe these speakers mainly help create an ambience within the cabin. Although it seems like the main audio source remains in the front, the rear speakers make it possible to keep the sound levels balanced. It is a thankless job but without these speakers, the overall sound would probably not be so smooth. I have friends who are very picky when it comes to audio and they were rather impressed by the quality of the SLK sound system. So far, my only disappointment as far as sound is concerned is the automatic sound-level control. I think mine doesn't work. |
| Founding Member Join Date: Jun 2006 Location: Rochester, NY
Vehicle: 2004 SL 500, Firemist Red/Charcoal, Panorama Roof; 2006 SLK 350, Firemist Red/Red
Country: Thanks: 1
| Zut, I've tried to listen closely for evidence that the volume does adjust automatically based on ambient noise levels. If in fact it does so, it is beyond the capability of my poor ears to hear. Maybe you have to have a dog in the car to confirm that it's working? Dinoman |
Country: Thanks: 96
| I also find it easy to hear the rear speakers in ones in the console a little better than the ones each side of the car. Zut the auto levelling consists of a microphone in the overhead console and some software in the gateway that enables it above a certain speed the Mic listens for the sound the speakers are producing and can then work out the background noise. It goes wrong a lot sometimes the Mic goes pop as its only a tiny little thing and cant really handle the output of the system but more often the cause if SW there are many new releases of it have the dealer update to the latest one when you are next there it might help fix it.
Vehicle: ///AMG
Country: Thanks: 17
| I played with this a little on the way to work and considering there are 7 speakers its strange theres only a left right balance. Be cool to play with the speakers individual and see the effecting result.
| | #8 (permalink) |
Vehicle: '05 SLK350
Country: Thanks: 1
| I think the positioning of the speakers on the car in the rear (not the center ones) is below ear level for most of us. And the the bucket seat design, most of the sound ends up getting diverted behind the seat. A while ago i used to have an little device that came with a set of computer speakers that allowed you to control the amount or rear speaker output by downfeeding specifically to the rear channels. I wonder if it would work the same on the SLK. Since it uses simply RCA connectors and 3.5mm headphone jack, i think i can give it a try with the Aux port and an MP3 player. Will dig it up and let you know. |
| | #9 (permalink) |
| When I drive with the top down at speeds exceeding 100kmh on a noisy motorway, I have to turn up the volume manually and when I stop the volume is excessively high and I must turn it down manually again. I thought the auto levelling system was supposed to take care of that. |
| | #10 (permalink) | |
Country: Thanks: 96
It works OK with the roof closed does it?
| | #11 (permalink) | |
| | #12 (permalink) |
Country: Thanks: 96
| You should notice it working at higher volumes the way i test it is to slow to a crawl turn the volume up then accelerate and listen to the increases they are noticeable if you listen close. It might be worth checking yours as they are prone to failure the option some people go for it to have the Mic disconnected and another installed in the foot-well the auto-increase still works but there is less wind-noise so it is more efficient at speed
| | #13 (permalink) | |
| Elite SLK World Member Join Date: Jul 2006 Location: South Beach (Miami Beach, FL)
Yes, I can hear my leveling easily. The causeway to the beach ends abruptly from 55 MPH (74 is my usual) to a 30 MPH zone and a stop light. When slowing down rapidly, I can hear the music level go down a little more then it should when the top is up. The feature first premiered on my '94 S500, and it was tied only to speed, so it only was useful when the windows were down. However, I think the SLK's listening version is much better. I can tell it works more accurately then the Mark Levinson in my Lexus LS430. The Mark Levinson, BTW, can be optimized based on the listen stage. You can set it for driver only, driver & front seat passanger, and all 4 seats. It changes the processing and is an intersting effect. Who the hell is Mark Levinson, anyway? BTW, if you ever get a chance to hear the BOSE stereo in a '94 S500, it is the best sound system I have ever heard in a car OR a house! Four 10" subwoofers, each handling a different frequency range, 15 total speakers. Stereo in all 5 seating positions. Of course that car had dual glass windows. | |
| | #14 (permalink) | |
| | #15 (permalink) |
Country: Thanks: 96
| If you look at your RVM you will see a small opening almost elliptical the Mic is hidden behind there or behind the middle of the 3 grills on the overhead console it depends on a few things but it will be one of those two places
| | #16 (permalink) | |
| | #18 (permalink) | |
| SLK World Member Join Date: Jul 2006 Location: Syracuse, New York
Vehicle: 2005/SLK350/Blk/Blk
First, the rear speakers are more simular to those rear channel speakers of a Home Theater system - purpose to fill the forward looking sound stage with realistic reflective yet subtle sound. Second, car owners over the years have become accustom to the 2 channel stereo provided in older vechcles - where the "boom" and mid-range volume came from the rear. User then adjusted the fade control to bring in the front (typically) smaller speakers to develop an all encompassing sound. Third, the Logic7 system is not stereo (L-R 2 channels) it is 7.1 processed surround sound creating a realistic forward facing aural environment. An evironment to replicate theater/concert environment. (i.e. just like Home Theater system) . I am on the fence, however, on whether MB should provide controls for adjusting surround... not sure if it is necessary. I know us tweakers can't stand not having control or adjustment options. But unlike the Home Theater system where you have control to make adjustment, the automoblie does not have the same aural design issues.The home theater listening environment is unique in every home. (Not the case in my SLK.) For example, a home theater has to be set up and customized to match the location of "centers stage" to the location of the primary listening/seating position. Adjustment varies, of course, based on the size of the room, height of the ceiling, windows, type furniture, floor covering,, wall acoustics, etc. So, you can agree that this is not case in the static SLK seating arrangement. (Not much room for you to move furniture arround. )Well, that's my professional opinion, for what it is worth, without having any MB factual engineering data. So, i guess the bottom line is to enjoy your surround sound listening environment, without the painful lose of hearing in your right ear. ![]() Just my thoughts. | |
| | #19 (permalink) |
Vehicle: '05 SLK350
Country: Thanks: 1
| Thanks for the great input... I agree, i really love the sound in our SLK with 7.1 HK. Though us tweekers always want more buttons, i think the performace on the audio system for a car our size is above average... if you just stop to think that in such a small space for 2 people there are 11 speakers (actually 12 if you count physical speakers as there are 2 in the center console-they must output the same so MB counted them as 1) I love the system, before i got my SLK i was already planning on the Audio upgrade... Subs, amps... mids.. so on. But once i heard it with a high quality MP3, i was very pleased. |
