| Elite SLK World Member Join Date: Apr 2007 Location: Bay Area, CA
Vehicle: '07 SLK55 AMG
Country: Thanks: 22
| I'm going to pull and clean the wheels on the SLK55 and didn't know what/if the wheel nuts needed to be to a set torque. I've always done the "good and tight" on each one and seem to think 60 was in the ballpark but was curious. Thanks in advance! -Webslinger |
Country: Thanks: 22
| Cool, thanks! I ended up using that dinky brush thing that came with the "Mr. clean" system and shoved it back between the spokes. The results are reasonable for now as I work out getting the car jacked up as my jack sits too high. I need to fab some small 2x6 boards or something to put under the car to clear the jack to pull the wheels. I need a better RO filter than that kit as it's the only reason I bought it and the water flow is pathetic. Car looks good after the detailing tho! |
Country: Thanks: 135
| I had my 17"s on since my last track day, I keep it on, just in case I'm going to Hasting, Nebraska for another one but it's unlikely now, I can't get anyone to go with me and my cousins are coming that weekend so I put my 19"s back on and torque it with 80 lbs/ft.
Country: Thanks: 22
| What/how do you jack the car ? my floor jack sits too high and I don't want to bust out those caps and use the factory jack. |
| | #6 (permalink) | |
| | #7 (permalink) | |
Country: Thanks: 22
Where did u get that second jack pad that you put the rubber piece on? | |
| | #8 (permalink) |
| That's not my jack, that was modified by fred (fgwinn), I just used the jack w/o any modifications.
| What size lug bolts | etyu | SLK R170 General Discussion | 3 | 10-17-2008 08:33 PM |
| Socket size for lug nut | RL 1 | General Discussion | 3 | 02-20-2008 11:26 PM |
| Torque Values? | jimbeemer | Help and Support | 2 | 10-22-2007 02:43 PM |
| Torque Spec? | zxxn | Ask DansSLK | 1 | 03-11-2007 01:00 AM |
| Stock '55 torque convertor? | FishtailnZ | Ask DansSLK | 8 | 12-05-2006 04:38 PM |
