Welcome to SLKWorld
Old 08-11-2007   #1 (permalink)
Zut
Zut's Avatar
Vehicle: 2006 SLK350
Default Airscarf and Service B
This will not be a long thread. I just have a simple question re Service B. Here goes:
Does Service B include an Airscarf check and/or adjustment?
Although I always loved my Airscarf, I was a little disappointed with the fact that it needed to be on level III to be efficient. On I and II, it was not even noticeable. Last night, for the first time since my Service B last month, I used the Airscarf and I was impressed with the strength of the air stream and the intensity of the heat generated. I almost got blisters on my neck! Wow! They must have done something to it (and I am delighted they did). I meant to tell the service guy to adjust it last month and I forgot. So, if any adjusting was done, I suppose it was part of Service B. Is it possible my Airscarf has been checked and "improved" or is it just my imagination?
View Zut's Photo Album Zut is offline
Old 08-11-2007   #2 (permalink)
Gabus's Avatar
Vehicle: 96 SLK 230K
Other Toys: Volvo L3314N
Airscarf??? Do you have winter temperatures in Canada???
They probably just removed two dozen spiders and a couple of mice nests......
Gabus
Old 08-11-2007   #3 (permalink)
Senior SLK World Member
Nothing in my service book to indicate they do airscarf!!
View garyhun's Photo Album garyhun is offline
Old 08-11-2007   #4 (permalink)
They do a function check of the main systems and if the tech did not like how the scarf was working then it would have been adjusted not that much can be done to it just cleaned out really.
Also it could have had a fault that was shown on the SDS and fixed.
Old 08-11-2007   #5 (permalink)
Donation Level 6
Zut, I'm glad that your airscarf is working better now. I never use mine on position three as it is so powerful that I could bake bread on my shoulders.
View Duo-Art's Photo Album Duo-Art is online now
Old 08-11-2007   #6 (permalink)
reallife's Avatar
Vehicle: 2006 SLK 55
Donation Level 3
Default Level III
I use Level III on cold mornings in the winter to blow dry my wet hair after showering before leaving for work.
I think your Airscarf must have been malfunctioning all along. Level III is way to hot for routine use.
View reallife's Photo Album reallife is offline
Old 08-11-2007   #7 (permalink)
Zut
Zut's Avatar
I don't think my level III is so hot my neck will turn into brisket but it is significantly hotter than it used to be. I need all the heat I can get for I love to drive with the top down all year round (last year, I did it in December and January). I wish my Airscarf fan were a little more powerful, though. Not hairdryer strength but, you know, it could use a little more push so the outside airflow doesn't overpower the effect of the Airscarf, as it often does.
Old 08-11-2007   #8 (permalink)
Ynot's Avatar
I start out at level III to warm it up, I don't keep it on the 3rd setting, it's too hot. Glad to hear that you have this fixed.
Old 08-11-2007   #9 (permalink)
Zut
Zut's Avatar
As a matter of fact, I am not even sure it has been fixed to be perfectly honest! I shall ask my service guy next week. What DansSlk wrote makes a lot of sense. However, I don't understand why nothing was mentioned on my invoice.
Old 08-12-2007   #10 (permalink)
Silver Supporter
WhiteRabbit's Avatar
Vehicle: 2009 SLK 350
Maybe they changed the position of the head-rest. I find that if it is raised then the air-scarf is not as effective.
2009 SLK 350, Arctic White, Gullwing Red, 7G Automatic, Premium PKG I, Lighting, Heating packages, Auto Climate Control, smartTop roof module v3.22, Clear side-marker lenses.
View WhiteRabbit's Photo Album WhiteRabbit is online now
Old 08-12-2007   #11 (permalink)
Zut
Zut's Avatar
You are right about that but I did move the head-rest in all possible positions last year and it did not help. I also thought they reoriented the louvers but I don't think it can be done.
Old 08-12-2007   #12 (permalink)
I think it depends on the dealers some write everything they do down others just note that it was in for service work.
If it was showing a fault code then that would have been sorted as part of the service, it could also be software in the control unit that would have been flashed with the latest version and it could have increased the temp for mode 3.
Or dare i say it your imagination?
Old 08-12-2007   #13 (permalink)
Zut
Zut's Avatar
God I hope not!
AirScarf Retro-Fit DansSlk SLK R171 General Discussion 53 1 Hour Ago 08:28 AM
Service C after service D??? SuzaFan SLK R171 General Discussion 9 08-28-2008 06:11 PM
Is there any way to make airscarf blow without heat? Tummy SLK R171 General Discussion 3 08-07-2008 04:59 PM
airscarf PsychoAzn Help and Support 4 01-04-2008 08:00 PM
Airscarf broken? Animali Ask DansSLK 6 01-04-2008 12:51 PM
