| Senior SLK World Member Join Date: Dec 2006
| So I didn't get the climate control when I got my SLK and now I deeply regret it becaus even a civic's got a digital climate control now, I'm driving a Merc and to be honest sometimes I feel as if I'm no more than a civic when it comes to technologies. Question is, can I retrofit a climate control in the SLK or does it have to be done at the dealer, I havn't gotten a quotation from them yet but I'm guessing it will cost me. Will this be a plug and play? |
Country: Thanks: 96
| You can retrofit the control unit yourself to give you the digital display but you wont gain any of the extra features that come with the unit from factory. They cannot be retrofitted.
| I don't really like the climate control unit. I'm not even sure it works. I find I am constantly having to fiddle with it. I find it is blowing cold air when the outside temperature is 70 and the setting is for 75. I don't know why it is blowing cold. And it isn't just the outside air blowing, it is COLD. And then when it is HOT out, like 95 degrees, and the top is down, it won't blow the air at the max when it is in Auto. And even when manually set to the max, it isn't as high a volume as when the top is up. Go figure. And I find I have to sometimes be pressing the A/C button on and then off and then on, because it isn't cold enough with it off and too cold when it is on. I thought this was supposed to be a climate control. Set the temperature you want and you don't have to touch it again. My old Reatta worked better. I think the SLK 320 worked better too. So you may or may not want to switch units. The digital one does look better and I think looks better with the other buttons and knobs. |
Country: Thanks: 96
| Yeah function wise its not great. Works more like modern BMW's it has a very wide temp range, its blowing cold air into the car because the temperature at the climate control unit face is above whats set and it will cool it down a few degrees before heating it up again and repeating the process.
| | #7 (permalink) | |
Country: Thanks: 96
So its not always running even when the light is lit.
| | #9 (permalink) |
| SLK World Member Join Date: Jul 2007 Location: Bucks
Vehicle: 06 280
| I dont have the digital one I have the one with dials on. If you set the temp to say 20 does the ac cut in when it needs to? I find the merc system very confusing |
| | #10 (permalink) | |
Country: Thanks: 96
If the LED is out then the AC is disabled at all times to leave it like that is bad drills because the gas contains its own lubricant and disabling it especially in warm climates will cause the seals to fail rapidly and the gas to escape. Better to leave it active so the light is on (off for 05's) then the computer can control it engaging the clutch as needed. Under full-throttle acceleration the clutch is dis-engaged so you have no parasitic drag but even with the compressor running drag on a 5.5ltr engine is minimal maybe a few horsepower taken up by all the drives on the belt.
| | #11 (permalink) |
Country: Thanks: 96
| Ah OK then the system is running when you have the light on, not a bad thing as i explained in my above post as it keeps the system lubricated.
| | #12 (permalink) | |
| Elite SLK World Member Join Date: Apr 2007 Location: Bay Area, CA
Vehicle: '07 SLK55 AMG
Country: Thanks: 22
| | #13 (permalink) |
Country: Thanks: 96
| One cool thing about Germans mate, They have a knack of thinking way outside the box and coming up with little easter eggs that not many others can match. The cars engine control unit alone has more processing power than a space shuttle (granted its older technology but still)
| | #15 (permalink) |
Country: Thanks: 96
| Trust me mate you will get used to finding out stuff like this when it comes to your car. About the only things it cant do are make you a coffee and wipe your arse. And i am sure both problems are being worked on
| | #16 (permalink) |
| i still can't get over the fact that this is a 60k car and the air con unit is manuel, that is just disgraceful, omho, it should really come standard. The "added" features should really be something significant like vario roof module or something. Germans, what are they thinking!? |
| | #17 (permalink) |
| SLK World Member Join Date: Feb 2007 Location: S.F. Bay Area
Vehicle: SLK350 MT AMG PKG
| I have the digital climate control, does anybody know why when I parked my car and close the top, the A/C start to blast? I'm sure it's a feature, but not exactly sure why, other than it feels nice on a hot day... (actually it doesn't do that when it's not hot) Yes, I agree to the detail in design MB puts into the cars... |
| | #18 (permalink) |
Country: Thanks: 96
| The AC has 2 modes top-up and top-down because of different airflow patterns in the 2 situations. When the top is closing the system switches to top-up mode and the sensors tell it the interior temp is above/below the tolerance for that particular mode so on a hot day the AC will go to full cooling to reduce the interior temperature. If you have HK audio you will also notice a blip in the audio as it changes DSP for top-up mode.
| | #19 (permalink) | |
| Elite SLK World Member Join Date: Apr 2007 Location: Alabama
Vehicle: 2005 SLK55
Hope that makes sense and like I said probably doesn't appy to all people but for me the slk55 was at the limit for what I wanted to spend on my next car. Now lets talk about some rain sensing wipers that come standard on a c230 but not on a slk55. Hey at least it an easy upgrade/fix. | |
| | #20 (permalink) |
| SLK World Member Join Date: Aug 2007 Location: San Francisco Bay Area
| This is a great thread. I just picked up my car about two weeks ago and I couldn't figure out the manual A/C button either. Now I understand that even though the A/C light is on the actual interior tempature determines whether or not the A/C compressor is activated. I have the manual system, so with the dual tempature controls the A/C can be active on one side and not the other? Thanks. |
