Windrestrictor
Old 07-09-2007   #1 (permalink)
RacerCub68's Avatar
Default En-LIGHT-en me!
My driver's side front side light went out. I want to go get a replacement bulb, but I am unclear on removing the lens properly. Can anyone previde any hints?
Also, I think the difference in flash rate between the front turn signals and the LED mirror signals looks stupid. Are there LED bulbs I can put in the turnsignals that won't set the system crazy with codes? How about the back?
A friend was showing off his new BMW 328i coupe. I find it strange that BMW would make the parking lights LED, but the stop lights have slower lighting incandescent. However, they have an inside light that comes on after a further delay / further depressing of the brake, that seems a neat idea.
View RacerCub68's Photo Album RacerCub68 is offline
Old 07-09-2007   #2 (permalink)
Silver Supporter
Vehicle: 2009 SLK 55 AMG
see the sticky on benzworld.org
Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums » R171 SLK Class :
Sticky: DIYs, Documents, Manuals, and FAQ links. Covers roof rattles, and other common issues
there is a section called:
Clear Sidemarkers
by bmwnomore and fgwinn
Clear Bumper Lights, finally!
that tells you how to remove and install the bulbs.
hope this helps.
Premium 1, Multimedia, Lighting packages
Clearshield Protective Film
OEM MB Plexiglass Windscreen
Eurolight Clear Side Markers
Kleyman 3rd Brake Light Flashing/Strobing Module V1.5 (Noregrets Custom Works)
View jbanks15's Photo Album jbanks15 is online now
Old 07-09-2007   #3 (permalink)
RacerCub68's Avatar
Default Someone downed benzworld....
Clear Sidemarkers
hope this helps.
Looks like someone crashed them. I will have to retry later.
Warning: main(./links_config.php): failed to open stream: No such file or directory in /sites/benzworld.org/www/htdocs/links_global.php on line 15
Fatal error: main(): Failed opening required './links_config.php' (include_path='.:/php/includes:/usr/local/share/pear') in /sites/benzworld.org/www/htdocs/links_global.php on line 15
Old 07-09-2007   #4 (permalink)
To get to the sidemarkers, one needs to remove 2 smaller bolts (silver color) at the bottom that holds the horizontal plastic engine floor against the wheel well. Remove 2 larger black bolts at the wheel well. this allows one to flex the wheel well cover and access the back of the side markers (front wheels turned towards the opposite side). the bulb holder is a simple twist and remove. It uses wedge 5w lamp.
Old 07-09-2007   #5 (permalink)
Link to LED bulbs that may be suitable, without using resistors, but these are for the turn signal lamps: http://www.slkworld.com/general-modi...t-upgrade.html
Old 07-09-2007   #6 (permalink)
Silver Supporter
etyu, don't forget the torx screwdriver
was just at benzworld.org again and went to that link. no problem. comes right up for me.
http://www.benzworld.org/forums/r171...ar+sidemarkers
Old 07-09-2007   #7 (permalink)
I thought he just wanted to change the bulb/lamp and not have to remove the sidemarker assembly.
Old 07-10-2007   #8 (permalink)
RacerCub68's Avatar
Hmm, didn't seem to have anything much about taking the side markers off. I am not interested in clear, I'm interested in not breaking my factory ones when I replace the bulb.
Oh yeah, and it's not the cornering lamps (first pic in that thread) but the side fender lights.
Old 07-10-2007   #9 (permalink)
RacerCub68's Avatar
Maybe I'll wait and have the dealer do it since I have some rattles they need to address. ;-) "Flexing" various plastic peices does not always sound that good to me as I am somewhat brutish and tend to break things.
Old 07-10-2007   #10 (permalink)
Silver Supporter
you're right etyu. i thought he wanted to replace the amber with clear side markers.
Old 07-11-2007   #11 (permalink)
Senior SLK World Member
Vehicle: 2007 SLK55 AMG
shouldn't that be covered under warranty?
View mbSLRwannabe's Photo Album mbSLRwannabe is offline
should this light up at night mazeka SLK R171 General Discussion 10 08-14-2008 12:37 AM
AMG smoked rear light clusters / 3rd brake light. jfb1977 Where to get R171 SLK Items 2 07-24-2008 11:40 AM
SRS light on HwoALanG SLK R171 General Discussion 3 07-24-2008 11:07 AM
Light Tape SLKman Off Topic 3 12-12-2006 06:54 PM
New Interior Light bazzle General Modifications R170 10 11-14-2006 05:44 PM
