Windrestrictor
LinkBack (1) Thread Tools
Old 07-26-2006   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Senior SLK World Member
Vehicle: SLK55 AMG
Default Adding garage door opener, can it be done?
Anyone found out yet if you can add the garage door opener to existing cars?
View aquascape's Photo Album aquascape is offline
Old 07-26-2006   #2 (permalink)
Yeah sure in the UK it is easy done not so easy in the US, etyu a member here tried to remove the overhead console but the final clip is both hidden and real hard to remove and he did not want to bust it i think he asked his dealer and the right harness was not installed on US cars but i am sure he will post the exact facts here.
UK cars its a real easy job the hardest bit is removing the console once thats done its a five minute job
Old 07-26-2006   #3 (permalink)
Founding Member #8
Vehicle: 2004 SLK350
Hi Aqua, good to see you here.
Not being mercenary, BUT the MB door opener is about 250 sheets - my electric (double) garage door assembly only cost 180 sterling, including 3 IR remotes - I keep one in the house, one in the BMW bike, and one in the SLK where the ash tray should be. As I drive up the driveway, I just pop the storage tray, then hit the remote - none of this 'groping around your mirror'
1999 Ducati ST2
2003 Vauxhaul Vectra
1974 Triumph Bonneville 750
T140V
1937 Norton 500 single
(all still current)
Old 07-26-2006   #4 (permalink)
Vehicle: SLK55 2006
but i've got 2 garages and a front gate (with different remotes) so i have to juggle 3 remotes....
Old 07-26-2006   #5 (permalink)
Founding Member #8
If you've got 2 garages and a gate, then you should have a butler to open them for you when you get home (probably a chaufeur as well, so you don't have to drive)
1999 Ducati ST2
T140V
(all still current)
Old 07-26-2006   #6 (permalink)
My obstacle was in removing the overhead console and I read (through Google translation) at a German forum (planear.de ?)that considerable force need to be applied and I didn't want to break the grippers.
I also asked for the parts no. of the garage door opener while I was at MB for first service. The assistant parts manager found out that there are 3 different modules, depending on the build of the car (my guess was that the intellicode HomeLink system/module is different for different countries) and the VIN will allow them to pick the correct module. The price varies from US$250 to $460.
One can purchase an aftemarket garage door opener remote (and some models can operate up to 3 garage door openers) for about $38 at HomeDepot for the singles, and close to $60 for the ones that control multiple doors. This may be a better and a lot cheaper alternative for cyberdrakon.
I know dinkoslk at another forum had the OEM garage door opener installed by a shop (Florida?) and it wasn't a problem. Just needed a power line and a ground line. If only I could remove the darn overhead console.
Old 07-26-2006   #7 (permalink)
Founding Member #7
mtiede's Avatar
I think there was someone on one of the other forums, probably BenzWorld or MBWorld, that tried to do this in the past. I seem to recall pictures and instructions for removing the overhead console. Try searching over there for more information.
Old 07-26-2006   #8 (permalink)
Sorry etyu i thought i read that the guy said the harness was not installed i remember now that you said you might just tap the overhead power line for the lights right, sorry about that i should have checked the benzworld post you made sorry.
The different types are for different country frequency's correct but even my UK EPC found the correct one for your car it was the only US one listed on the system so it should be real easy for them to find the right one the frequencies are listed right next to the PN.
I will have a go at removing my console in the morning see exactly what has to be done and will report back.
Dan
Old 07-26-2006   #9 (permalink)
Vehicle: '05 SLK350
aquascape, how about a 3-4 channel universal open you can program like this?
http://cgi.ebay.com/Gate-Garage-Door...QQcmdZViewItem
Though you may have to check the frequency range to make sure, but perhaps keeping one of these in the car, you can manage 4 RF openers at once.
Old 07-27-2006   #10 (permalink)
Dan
Dan, no need to apologize. Your recollection is correct. Even if it isn't, no apologies needed either.
Thank you very much for your great help. Much appreciated.
LinkBacks (?)
LinkBack to this Thread: http://www.slkworld.com/slk-r171-general-discussion/323-adding-garage-door-opener-can-done.html
Posted By For Type Date
Garage door closer new S Class - Mercedes-Benz Owners' Forums This thread Refback 01-26-2007 03:58 AM
ADDING UMI to a FL SLK watoke SLK R171 General Discussion 24 2 Weeks Ago 07:16 AM
Garage Door Opener Mod DesignoSLK General Discussion 8 04-15-2008 08:26 AM
AMG adding turbos, DI to 6.2 Dueclaws AMGs 1 04-08-2008 01:45 AM
Adding Aftermarket Bluetooth Phones FishtailnZ Ask DansSLK 7 11-16-2007 08:19 PM
garage door opener setup MJawa 55 Ask DansSLK 10 11-08-2006 10:52 PM
