Welcome to SLKWorld
Old 06-05-2007   #1 (permalink)
Vehicle: 2006 SLK55
Default How to dyno '55
I am planning to dyno my car next week - and I never dynoed a car before. Do I just enable dyno mode, put in manual mode (1st gear) and let it rip? Just confirming.
View Hakaze's Photo Album Hakaze is offline
Old 06-05-2007   #2 (permalink)
Zeiser50's Avatar
Vehicle: SLK 55 AMG
Yes .
... And try to avoid collision with walls, cars, ...
------Michel------
-SLK 55 AMG 2005-
View Zeiser50's Photo Album Zeiser50 is online now
Old 06-05-2007   #3 (permalink)
Yep thats it.
As Michel says just make sure it does not jump forward.
If your on a 4 wheel dyno where the rears drums are connected to the front then you don't need dyno mode because all the wheels will be rotating, you only need it if the back wheels are going to be the only ones doing anything.
Old 06-05-2007   #4 (permalink)
Senior SLK World Member
Vehicle: 06 SLK55 AMG
just curous what is a Dyno?
what's the Pro/Con on turning to Dyno mode?
View leelk's Photo Album leelk is offline
Old 06-05-2007   #5 (permalink)
Dyno / Dynamometer is a device that uses the torque and rotational speeds of the driving wheels to measure a engines output in BHP.
Because its measured at the wheels a drive-train loss of about 15-20% is normally factored in.
Because the SLK's ESP system uses speed sensor information from all 4 wheels and a dyno drum normally only sits below the driving wheels leaving the front 2 doing nothing the cars computer gets confused and will either activate the ESP thinking the car is out of control or will engage the speed limiter system you don't want either of these happening on a dyno for obvious reasons.
Dyno mode disables all the traction control systems and the speed limit system (not the Vmax) so that the car can be run to its maximum without all the wheels turning this is great on a dyno or brake tester stand but not so good on the road because the traction control system will not step in at all to help you out if something goes wrong and you lose control of the car you also lose even simple things like ABS when in dyno mode.
Old 06-05-2007   #6 (permalink)
Vehicle: '07 SLK55 AMG
Other Toys: Honda motorcycle
Along the lines of this thread- Does anyone know if there are any dyno's here in Northern California? (South bay would be best) I'd like to break in the car and then take it to the dyno to see what it has before I install things like the green filters, etc. (baseline)
Old 06-05-2007   #7 (permalink)
Thank you for your information, Dan you are the man...
I wonder are there anything Dan doesn't know?!?!??
Old 06-05-2007   #8 (permalink)
Vehicle: 2005 SLK55
Saturday 12:30CST I have an appointment to put mine on the dyno. Not sure what model but it is a Dynojet unit.
Anyone have an idea which gear to do the pull in. In most cars they do them in 4th but not sure if that would change with it being a 7spd. It doesn't really matter too much but usually on higher HP cars 4th puts more load on the car and it runs slightly different numbers than say 3rd. I guess I will look at the gear ratios on the 55 and pick 2 and try it in both.
To the guy that said 1st gear, it technically can be done in 1st I believe, but it is usually done in 3rd or 4th as it loads the engine more. You can actually sample multiple gears in one pull I believe.
View VitaminT's Photo Album VitaminT is offline
Old 06-05-2007   #9 (permalink)
If it where me i would run it up the range the car will not allow implausible shifts anyways so if you want to run it in any gear other than 1st you will need to shift while its on the rig.
Maybe S mode would be better because you could restrict the shift range to the highest gear you wanted to test and just nail the throttle, don't kick it down of course because that will bypass it.
Old 06-05-2007   #10 (permalink)
Vehicle: 2005 SLK55
I will probably just run in M mode in 4th. Just get it strapped to the dyno, run the car like driving down the road to 4th gear and then do a 2k-redline in 4th.
As you are probably aware they do the same thing with cars with sticks. Just drive like normal until you get in forth, lay out of the throttle in 4th, hit the "record" button on the dyno and punch it. When done, stop recording and let off.
I will post the pulls up Saturday or Sunday and let you all know how things went. I am hoping for 300whp but it is going to be like 95deg here so I don't know if I will make it. Won't be near as spectacular as my buddies 768whp turbo Honda Civic.
Old 06-06-2007   #11 (permalink)
Yeah that sounds cool.
Was just making sure you knew about getting it into the correct gear, we have had people come into the shop with the primary complaint being the car wont select gears and we have to explain that the car wont allow you to select a gear below a threshold speed or when the resulting RPM's would stall or over-rev the engine.
Clearly you know the score so i look forward to the results and good luck
Old 06-06-2007   #12 (permalink)
alroumi's Avatar
Expect to do 299-303hp to the wheels, I would try both 3rd and 4th gear runs due to the 7gearning of the SLK.
06 Porsche Cayenne S
07 Jaguar XKR Coupe'
Old 06-06-2007   #13 (permalink)
I guess I answered my own question here- Apex Motorsports in Santa Clara off Central Expressway seems to have a Dyno. I'll contact them and maybe we can gather a few of us to go down and do a "dyno day" in August?
Old 06-06-2007   #14 (permalink)
Vehicle: 2006 SLK55
Hmm... does the tire effect the dyno results at all? I would assume so - I ask because I rear tires are in need of change.
Old 06-06-2007   #15 (permalink)
Vehicle: 2005 SLK55
Nope. The only difference, and it probably wouldn't show up at all, would be if the old tires weigh less than the new ones but really it doesn't matter.
Old 06-10-2007   #16 (permalink)
Vehicle: 2005 SLK55
Went to the dyno today. Did it just like we talked about here, put it in dyno mode, manual tranny mode and the operator just drove it up to 3-4th gear and did the pull.
Anyway in 3rd made 299.8. In 4th did 292.0. He said the resolution (? beats me) looked better on the 4th gear pull even though it was less. I didn't see the 3rd gear run for but a second but it didn't look smooth, it had lumps it it. Anyway did another pull jut like the last in 4th and did 290.7.
It was about 90-93 degrees, full tank of gas. Only mod is green filters and some BBS RA wheels. The runs were not too long after I had driven 10-15 miles on interstate so I am sure the airbox was very hot. At 3500rpm it is running about 12.5:1 AFR and by 5500 it is burried below 10:1 so I guess I need a Renntech tune or something because that is riiiich for a NA car.
Old 06-10-2007   #17 (permalink)
Good results.
How did they get the AF ratio info OBD?
Old 06-10-2007   #18 (permalink)
Vehicle: 2005 SLK55
No it was just a tailpipe sniffer. Not really accurate but better than nothing. I wouldn't tune a car by it that's for sure but it is something worth having on the chart.
Old 06-10-2007   #19 (permalink)
Yeah your right its better than nothing
Old 06-11-2007   #20 (permalink)
Vehicle: 2005 SLK55
One thing I wished I had him do is he seems to roll into the throttle and start recording about 3400. I wish on one of the two 4th gear runs he did I had him roll into it on one, and stomp it on the other. Just feels to me like the car responds differently sometimes.
I think it did it that way because he is used to most automatics downshifting it if jumps on it where mine was in Manual mode.
Hey there is always next time. Maybe I can get me a Renntech ecu and airbox and dyno again. They give those things away right? Nissan chipped ECU=$500, Renntech chipped ECU=$2000, hmm beats me why the difference other than they know they can get it.
