Vehicle: 2009 SLK 350
Country: Thanks: 80
| I replaced the cabin ACC filter in my SLK today. Even though my USA 06 SLK 280 only has the base climate system (not the digitial one) it still had an activated charcoal filter installed. The new filter (Mann) actually came with instructions, just pictures, no text. The images are low resolution and fuzzy. There are couple of things to watch for: First - to release the wire-harness connector from the power outlet, you pull the connector sideways not straight back from the outlet. Second - after you install the filter but before putting the under-dash panel back on, start the engine and put the AC fan on high. Now check around the filter housing. There should be no air leaking from the housing at all (thanks to Dan for the tip). Getting the filter housing cover seated just right took me 3 - 4 tries before there was no air blowing out of the housing.
__________________ 2009 SLK 350, Arctic White, Gullwing Red, 7G Automatic, Premium PKG I, Lighting, Heating packages, Auto Climate Control, smartTop roof module v3.22, Clear side-marker lenses. |
Vehicle: 2009 SLK 55 AMG
Country: Thanks: 8
| great! how about some pictures? btw, per my manual, passenger compartment replace combination filter at 26000 miles or 2 years. how many miles do you have? it should have been taken care of as part of your scheduled maintenance unless you are not at 26000 miles/2 yrs yet or unless 280 model does not have this maintenance schedule.
| I wonder if that filter is causing the stink I smell when the A/C is coming on now that the weather is warming up. Think changing it might help? |
Country: Thanks: 96
| What sort of smell is it mate? The dealer has some spray gunk we set the car to a cleaning mode plug the unit in and seal up the car then this things fills the AC system with whats basically air freshener and after 30 minutes the car comes out smelling like a summer rose as it says on the tin. Sometimes nasties get into the system and they start to smell the filters are normally OK but since the crap is downstream they do no good.
| | #5 (permalink) | |
Country: Thanks: 377
I haven't noticed any smell from the AC but this may be a more common problem where there is more moisture in the ambient air based on location/geography.
| | #6 (permalink) | |
It smells like mold that has gotten wet (which is probably what it is). Would really like it if they actually had some way of removing whatever smells rather than "deodorizing" it. I was hoping it was just something in a grungy filter that might be able to be replaced. Oh well... | |
| Elite SLK World Member Join Date: Mar 2007 Location: Salisbury North Carolina USA
Vehicle: 99 SLK230
| I had a simular odor problem in a car. I removed the filter and sprayed a diluted bleach/water solution on it. Reinstalled for a week running system and then replaced the filter with new and the problem went away. As Dan says, there are probably other chemicals that smell better than bleach that will kill mold etc, but bleach works. |
| | #8 (permalink) |
Country: Thanks: 8
| you sure it is not New Jersey you are smelling?
| | #10 (permalink) | |
Country: Thanks: 96
Real PITA of a job to do.
| DIY: Service E Cabin Air Filter Replacement | slk350ncls63 | SLK R171 General Discussion | 32 | 08-26-2008 11:39 PM |
| Cabin Light Lights Sporadically | MBSLK-AMG | Help and Support | 7 | 08-01-2008 04:27 PM |
| Where is the cabin filter? | nlagos | General Discussion | 13 | 03-28-2008 12:32 AM |
| need help (cabin filter) | SLeeK350 | SLK R171 General Discussion | 4 | 10-17-2007 03:11 PM |
| Noise in the Cabin... | watsons | SLK R171 General Discussion | 6 | 05-19-2007 08:45 PM |
