Engine Temp - Page 2 - Mercedes Benz SLK Forum
 8Likes
#21 Old 04-25-2012
Vehicle: SLK R171 200k 2005
Originally Posted by VincentSLK View Post
According to the owners manual for my 350 it says "if antifreeze additive is present in the correct concentration, the value displayed may rise to 120C under normal driving conditions. The coolant temperature may rise to the end of the temperature range at high outside temperatures and when you are driving on mountain roads."
I agree with you. That is what the manual says. Personally, I have never seen the coolant temperature to exceed 95C.
SamuraiSpirit is offline
#22 Old 04-25-2012
Vehicle: (05) SLK350
I wouldn't want to either 90C is where a car should be in my opinion and I would rather it stayed there!
SamuraiSpirit likes this.
VincentSLK is offline
#23 Old 04-25-2012
Chats: 2
Quoted: 13 Post(s)
Ok, I stopped by one of the Indy MB dealers and spoke with an SA(just to be sure, that's ServiceAdvisor). He said in early versions(170 and early 171's, the outside temp probe worked with the ventilationsys, and if it wasn't working properly, could cause a CEL, but that the problem Jeff had was probably totally MAF related... so there IS a chance for a CEL to be caused by the ambient temp probe...
Is that ok Jeff
Think outside the box!
Galo is offline
#24 Old 04-25-2012
Quoted: 3330 Post(s)
I will always take a 'is' chance! Thanks for checking Mark!
Wavetrac LSD thread here:
#25 Old 04-25-2012
PitchRate's Avatar
Vehicle: 2006 SLK55 AMG Black/Black
Quoted: 32 Post(s)
I believe these are the Mercedes OBDII various temperature codes:
P0109 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
B1227 Outside temperature indicator temp sensor
There are also a series of fuel temperature codes.
Not sure if all these are applicable to all Mercedes models or not.
Bob
I'm older so I drive fast as I have less time left to waste.
PitchRate is offline
The Following 2 Users Say Thank You to PitchRate For This Useful Post:
#26 Old 04-26-2012
subarita's Avatar
Vehicle: slk 350 '04 manual
Other Toys: Subaru GT turbo
Mine works normally between 95 - 100º C
JonB likes this.
subarita is offline
#27 Old 04-26-2012
PitchRate's Avatar
Quoted: 32 Post(s)
I believe the cooling system in the SLK55 is fairly robust. I also normally see a pretty steady 90o C.
It is interesting that from the service manual the thermostat doesn’t fully open until the coolant temperature is above 102 C.
Cooling modes (thermostat).
By Pass Mode – (thermostat closed) when coolant temperature <87 C
Mixed Mode - (thermostat partially open) when coolant temperature >87 C and <102 C
Cooling Mode - (thermostat fully open) when coolant temperature >102 C
JonB likes this.
The Following User Says Thank You to PitchRate For This Useful Post:
#28 Old 04-27-2012
out of interest does anyone know where the temperature sensor is located (on a 350) for the cooling system? I would have expected it would be after the coolant has passed through the engine and on the return side of the system, but I have a suspicion it might be before the engine.
#29 Old 04-27-2012
PitchRate's Avatar
Quoted: 32 Post(s)
The coolant temperature sensor is located at the rear left cylinder head.
subarita likes this.
The Following 3 Users Say Thank You to PitchRate For This Useful Post:
#30 Old 04-27-2012
Nice one - thanks!
perfectly located then, so my suspicion was totally wrong
It just seems very sensitive as the temperature can fluctuate up and down by a surprising amount in a short amount of time, I am used to seeing a solid 90C and it never really changing, but on my 350 is it's often up and down by 5 - 10C
Thanks again for the pic
#31 Old 07-28-2012
docleo's Avatar
Vehicle: 2002 SLK230 Black
Other Toys: 85' Mazda RX-7, 02' VW Beetle Turbo, 01' Yamaha Waverunner GP1300R, 97' Seadoo GSX
Can someone help me with this- my R170 during summer on straight drive the temp needle always at 100C then at traffic on 90C but when i turn off the engine at start again after 20min or 1 hour it was hard starting, i need to switch it off and start again. by the way i'm in abu dhabi the temp here during summer it reach up to 52-55C and my R170 was US version not GCC spec., (can you help me want i need to do or replace?)
docleo is offline
#32 Old 08-09-2012
Vehicle: 2007 SLK 280
I like to recycle threads, and this seemed like as good a place as any.
I have a 2007 SLK 280. About 61,000 miles.
I was driving to work and got a "Message". The message was ONLY a picture of the temperature icon, with no accompanying text. I had been turning the A/C on and off periodically to clear inside windshield condensation.
According to the manual, that message indicates a malfunction in the fan.
I checked the coolant temperature on the MFD, and it was at about 90C, which I believe to be normal.
The message has not been available on three subsequent starts and short drives. Temperature has been solid on 90C. Goes there and stays there.
My mechanic tried to download codes, but none were available (this was not a full StarTech thing, just the handheld plug-it-in-under-the-dashboard thing).
Fan operates. Fan goes to higher speed when switching on the A/C. Temp stays consistent.
At this point, I'm thinking this incident was just a false-positive and everything is fine. I plan to just keep driving and monitoring the coolant temp pretty constantly. I'm not planning to change the fan until I get more indicators.
Any comments or advice would be very much appreciated.
tomtuttle is offline
#33 Old 01-26-2013
LaPastouda's Avatar
Vehicle: 2005 Mercedes SLK 200
Other Toys: Harley Davidson (now For Sale !)
driving home last night it was -2 degs and the coolant temp reading didn't go above 50 !
The heater didn't get very hot either !
Any ideas ?????
LaPastouda is offline
#34 Old 01-26-2013
FOUNDER - SUPER MODERATOR
Vehicle: SLK350 MT
Chats: 1297
Quoted: 114 Post(s)
Originally Posted by LaPastouda View Post
. . . . Any ideas ?????
Move somewhere warmer?
How long was your drive home, and how long had your car been standing before you headed off?
Woolly is offline
#35 Old 01-26-2013
If the temp doesnt rise above that after a few miles I would venture to say your thermostat is stuck open
JonB is offline
#36 Old 01-26-2013
LaPastouda's Avatar
car was stood for 2 hours and it was a 1 1/2 hour journey home.
Is checking/removing the thermostat a DIY job ?
I'd have thought even with the thermostat stuck open, the engine would have got warmer than that ????
#37 Old 01-26-2013
cobra8272's Avatar
Vehicle: '05 SLK350
Other Toys: Fender Strat, Fender Tele
With the thermostat stuck open temp will vary with outside temp and driving conditions but yes 50C would be reasonable.
The thermostat is there to get the engine up to temp quickly and keep it within the optimum operating temperature range.
JonB likes this.
cobra8272 is offline
#38 Old 01-26-2013
The thermostat stays shut until the the engine temp increases. if it stayed shut you would overheat rapidly Staying open means the coolant is circulating all the time and is not getting up to temperature. There is a thread in here about changing thermostats. But that would be my first guess. One way to tell is to start from cold and hold the top hose if it starts to warm up slowly its a sure bet the stat is open. It would normally stay cold until the temp in the engine is getting up to the correct temp. then the stat opens and you woud feel the hose get hot pretty quickly
50 is low an engine runs best as near boiling point as poss like around 80 degrees
cobra8272 likes this.
JonB is offline
#39 Old 01-26-2013
LaPastouda's Avatar
found this on another thread
http://www.youtube.com/watch?v=Oyobl...ature=youtu.be
looks easy enough so will be ordering another TS and giving it ago.
Where can I get the part No. from ?
and any suggestions as to where to get it from cheapest, shipped to France ?
#40 Old 01-26-2013
I doubt they would be expensive from an MB dealer
JonB is offline
Human Verification
DIY - Engine mounts replacement for post facelift R170 Mantist SLK R170 class DIY 31 05-03-2016 12:23 AM
DIY - Engine mounts replacement for post facelift R170 Mantist SLK R170 class DIY 10 11-23-2014 12:14 PM
E 430 Amg dltslk Mercedes Benz Posers 4 04-02-2008 12:36 PM
Mercedes Benz DiesOtto Engine MarkR171 Off Topic 3 07-26-2007 09:05 PM
models and prices SLKman General Discussion 23 02-09-2007 05:02 AM
