DIY Handbrake Adjustment - Mercedes Benz SLK Forum
#1 Old 02-12-2012
Vehicle: 2005 SLK55
Anyone have instructions/photos for how to adjust the hand brake on an '05 SLK55? I assume it's similar if not the same as any other R171. I noticed that I'm having to pull my handbrake lever up much further versus when the car was new, and I assume that's due to normal brake wear. Thanks in advance for your help.
shark is offline
#2 Old 02-12-2012
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 119 Post(s)
Just a quick search...
Handbrake!
Procedure for hand brake pad replacement
also search handbrake and hand break and handbreak (often misspelled)
FUN 4 2
Der Flieger is offline
#3 Old 02-12-2012
Vehicle: 2005 SLK55
Thank you! Actually I did do a search before I posted and did see the thread that ultimately had the answer, but the title of the thread had led me to beleive it dealt with a different issue, and I never read the thread all the way to the bottom. Thanks again.
shark is offline
#4 Old 02-13-2012
Chats: 2
Quoted: 13 Post(s)
shark, as I read your last post, you did find the p/b adjustment method, right? I found that "releasing"/backing off 10 teeth was too much. Try 7 teeth as a starter, as long as you can turn the hub by hand. I stopped at 7 teeth, but will probably take it to 5 teeth when Spring gets here. Three(3) clicks on the parking brake handle will easily hold the car on somewhat shallow up/down-hill situations, but I need that 4th click to hold in my driveway(I call it Mt. Galo).
The adjustment process is a pain due to having to put the wheels back on to test the holding strength, but if one is a diy-er, it's worth the trouble.
Think outside the box!
Galo is offline
The Following 2 Users Say Thank You to Galo For This Useful Post:
Human Verification
