How To Fix Center Console?: Pic Included - Mercedes Benz SLK Forum
 15Likes
#1 Old 02-07-2012
Vehicle: 2007 SLK 350
My center console lid has come off. It does not seem broken. It is just unattached. How do I re-attach it? I have included pics.
Der Flieger likes this.
aj9079 is offline
The Following User Says Thank You to aj9079 For This Useful Post:
#2 Old 02-07-2012
Quoted: 3968 Post(s)
i am familiar with it as my 05 slk 350 had the issue. just want to make sure yours is attached with the springs?
it snaps in and then u have to whack the back. do you see the spring area? maybe take another pic from another angle
Wavetrac LSD thread here:
#3 Old 02-07-2012
might help:
Center console lid : problem solved
Center Console Lid R171
#4 Old 02-07-2012
yes, that was my same issue. see that piece sticking out in the 3rd pic? you have to fit that in where it goes for both of those pieces (one on the other side) and then whack it at the rear and it will reseat
#5 Old 02-07-2012
2nd pic on the left side shows the spring assembly
#6 Old 02-07-2012
i turned the piece inwards that was sticking out and put it in its proper place. i smacked the back of the console, but no luck.
aj9079 is offline
#7 Old 02-07-2012
Takes practice. And patience. Bend the springs in like where they want to be and get them in position. Push down at the spring location. It takes a while to learn the whack a mole!!
#8 Old 02-07-2012
ok i did it
the trick was to balance the lid evenly after turning the springs inwards and then smacking it down by the spring area dead in the center.
aj9079 is offline
#9 Old 02-07-2012
Congrats! Welcome to whack a cover graduation!!!
BarrySLK280 likes this.
#10 Old 01-24-2013
Vehicle: SLK55 AMG
Angry Same problem...
Except my console top is still attached on the passengers side. When I go to close it, the slider on the driver side sticks out. Any help on this? I'm new to the forum, as I've just purchased my first SLK. This is an annoying little problem!!!
MilesDevin is offline
#11 Old 01-24-2013
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
Miles,
Unfortunately, in return for the joy of getting to drive these wonderful machines, our German friends have provided us with a few little annoying quirks. The center console you have found. The "cupholder" is another one, otherwise known as the "I want to destroy my headunit" module. Then there's the ""you better know your headlight switch settings by heart, because you sure can't see it" one. Let's see - then there's the "you can't get into your car to jump off a dead battery without compromising the window seals" feature. The "eye poker" radio antenna is also standard equipment. The "we can't understand why you would want a glove compartment, so that's where we put the CD Changer" is optional.
And I'm sure that there are more. The good news is that they won't matter a hill of beans compared to the complete joy of taking your SLK through a set of S curves in the mountains.
Welcome to the forum.
Gene
REB_TN_06 is offline
#12 Old 01-25-2013
tricolour's Avatar
Vehicle: 2006 SLK 55 Designo Graphite, 2005 SLK 350 Black, 2001 SLK 320 Black.
Other Toys: 3.2 Boxster S, XJ 40 Jaguar, Bimota DB9C, Triumph Bonneville SE & Thruxton R.
Quoted: 32 Post(s)
This is what AJ9079 & I did after reading all Jeffs (and others) advice.
Tuck the offending slider(s) under as you close the lid making sure the lid is central when closed (the slider will slide on its base as you close the lid) and then give the lid a good sharp smack down at the back of the lid on the offending slider side.
This will locate the rear pin.
Worked for me after nothing else did.
tricolour is offline
#13 Old 09-17-2013
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 119 Post(s)
Having a similar problem..after the Mrs got a little overzealous opening the bottom (pulling up) then slamming it down while trying to open it sideways..
this is another informative link..
As above, one lift spring is extended (the other is now broken btw) however the opening slider/buttons appears to be jammed in from the driver side and the rear hinge pin on the driver's side is extended and fixed (the forward pin is spring loaded out but will move).
So JB...am I all set to whack a mole (assuming I get the lift arm tucked in)?
FUN 4 2
Der Flieger is offline
#14 Old 09-17-2013
Yup! Whack a mole it is unless you get the whole bottom of the console replaced
#15 Old 09-18-2013
Quoted: 119 Post(s)
well...
moles 1, JJ 0
broke the left rear pin. the console now opens only to the left (it will open to the right, but will also fall off into the drivers lap...) sigh
so.. I'm in the market for a new lid... any ebay experts care to wade in??
OEM 260$
http://www.genuinemercedesparts.com/...agramCallOut=3
FUN 4 2
#16 Old 09-18-2013
cover part 70
File Type: pdf cover to housing armrest a17168002969f38.pdf (29.0 KB, 40 views)
#17 Old 09-18-2013
Part Number 17168002969F38
Part Name COVER
MSRP $338.00
Core $0.00
Save $67.60
Online Price $270.40
http://mercedespartssuperstore.com/p...&siteid=217866
#18 Old 09-18-2013
jpav's Avatar
Vehicle: 2005 SLK350
OK, so an amazing coincidence happened....this very problem happened to me today on my drive home from work. The thing wouldn't close and it was loose in the front on the side that was still "connected".
1. On the underside about 2 inches or so from the back there are two plastic clothespin looking things on springs. When you try to close the lid, they stick out about 3/4 of a inch. These must be leveraged inwards and have resting on a platform (same thickness as the pins, about 1/2 inch thick and with raised edges).
2. Just behind that are what amounts to ball joints that the lid must snap into. You need to give it some force, and the lid must be exactly aligned in order for it to work. Perform step one and then press downwards, not with a whack but when a steady force like you are putting on a tight pair of shoes without untying the laces.
3. The front should also be aligned so to speak. Instead of the ball joints there are just little felt looking hooks, about 1/3 inch radius that have to go around the plastic latches on the lid (it's not actually felt. I know the name of it but I can't think of it right now. It is what they use to line boxes. It is like a spray on felt stuff.) This requires almost no force.
Sorry I have no pictures, but I got the thing back together successfully after about 2 minutes of fooling with it.
Edit: PICTURE! (Color coded, first do red, then green then blue)
jpav is offline
The Following User Says Thank You to jpav For This Useful Post:
#19 Old 09-20-2013
Quoted: 119 Post(s)
Thanks...your explanation parallels those of JB et al.
However in my case the release buttons (they shuttle to either side to let the lid tip) seem to be jammed inwards - they move somewhat but not like they should. It would seem to me that something has gone over-center and is now jamming.
Has anyone ever gutted one of these?
FUN 4 2
#20 Old 09-21-2013
jpav's Avatar
I remember feeling as though mine were the doing the same thing. Try holding your index fingers over each of the buttons, and try to depress each one and see if it makes the other one move out some. I believe this should be the least of your issues, b/c they might pop back out when they close around the "felt covered" hook arms in the console tray.
jpav is offline
Human Verification
Center console removal questions . . . lilred320SLK SLK R170 General Discussion 3 05-23-2012 06:42 PM
98,99,00,01... Entire Center Console for sale... ucmagic Where to get R170 SLK Items 3 05-13-2011 09:12 PM
USB Port added to NEW center console! Plus new lights! ucmagic General Modifications R170 9 05-11-2011 10:30 AM
Center Console Light BrianS SLK R171 General Discussion 14 08-05-2009 12:08 AM
Those rear center console speakers bclark SLK R171 General Discussion 43 08-15-2006 09:17 PM
