| Elite SLK World Member Join Date: Nov 2006 Location: Minneapolis, MN
Vehicle: '05 SLK55
Country: Thanks: 1
| I want to find the best way to mount the front license plate bracket. The car was a FL car where a front plate is not required. In MN it is required and I'm hoping I don't have to just screw the bracket into the plastic bumper. What are my other options? Note the bumper is off the car right now getting a crack fixed so now's the time to figure out a mounting process. Also, should I have the black lic plate mount painted silver to match the car? Thanks, Michael |
Country: Thanks: 135
| If you have the amg pkg, slk55er as a great tutorial here. http://www.benzworld.org/forums/r171...ont-plate.html If you don't, slktyperice mentioned something about a L-bracket, where you can drill holes under the bumper, so the hole isn't as visible. I personally would not mount it at all unless you get harassed by the police, Colorado is unfortunately one of the states that requires front license plate and I've driven over a decade w/o one with no problems.
Vehicle: '05 SLK55
Country: Thanks: 1
| This helps a ton. I was considering mounting the plate by itself on the mesh but having the bracket there looks less ghetto. Thanks for the link and tip. -Michael |
| Elite SLK World Member Join Date: Oct 2006 Location: Plano, TX
Country: Thanks: 39
| I pick up a great item from gominigo.com. It goes in the tow hook connection on the front of the car. Ask for the Mercedes Benz 'No Holes' License Plate Bracket (NHLPB), version JB for SLK R171. I am not sure what version is needed for R170. |
| | #9 (permalink) | |
Country: Thanks: 39
I will take a side few later today and then post. | |
| | #10 (permalink) |
Vehicle: '05 SLK350
Country: Thanks: 1
| Just found the installation instructions on their website. Has more pictures. Looks really intersting. I think i am going to Home Depot to build my own ![]() http://www.images.gominigo.com/INSTR...NOHOLES_MB.pdf http://www.images.gominigo.com/GMG-NoHolesHelper.pdf some more info and pictures here: http://gominigo.com/NHLPB-MB.html But for $60 it is a bit over priced. |
| | #11 (permalink) |
| SLK World Member Join Date: Feb 2008 Location: Skokie
Vehicle: 2006 SLK 55 (soon)
Country: Thanks: 2
| hey guys....this is my first post...i will soon have an slk 55...i was waiting to post when i first got the car but i had to post once i saw thiss....i actually have the plates tied to mesh on my S55 and my E500 4-matic...im not to fond of drilling holes in the bumper either.... |
| | #13 (permalink) |
| SLK World Junior Member Join Date: Nov 2007 Location: San Jose, Bay Area
Vehicle: 02 C230, 08 SLK350
| i am kinda worry right now.. my NHLPB arrived today right by my front door, but then when you guys talk about the R170 and R171 i am thinking if i got the wrong kit or not... because when i order from gominigo, they only say SLK up there and the towhook code aren't matching, i will try tonight when my SLK is home |
| | #14 (permalink) |
| SLK World Member Join Date: May 2007 Location: San Francisco, CA
| This kit is great. I installed mine, got a correctable ticket signed off, and removed the license right after. PERFECT! (Here in SF they give you $100 tickets for no front license plate, but it's dropped to $10 if you get an officer to sign off after installing the plate.) I was just going to pay my $100 fine when I luckily came across this. Thanks guys!! |
| Getting around the front license plate | chadwick | General Discussion | 7 | 05-17-2008 03:23 PM |
| removable front plate. | cyberdrakon | General Modifications R171 | 6 | 10-09-2007 02:48 PM |
| Spiffy Lic. Plate I saw while @ dealer (Calif.) | webslinger | General Discussion | 3 | 10-08-2007 08:24 PM |
| front license plate | pimpslk | General Discussion | 13 | 07-26-2007 08:41 PM |
| lic plate lamps | V8SLK | Ask DansSLK | 6 | 12-05-2006 12:17 PM |
