| SLK World Member Join Date: Jul 2006 Location: Calgary
| Back in October, I had a women bang into the back of my car and it split my rear bumper shell. They also dented one of my exhaust tips. Since I don't drive the SLK in the winter, I parked it until recently when I finally took it to the body shop to get it fixed. BTW, in order to fix an exhaust tip, you have to buy half of the exhaust system and the price is $2200 CDN. Today I went to pick it up and noticed the Check Engine light was on. I went back into the body shop and they said they didn't do anything so they didn't know why this light would be on. (They did tell me the battery was dead so they had to charge it. This doesn't make sense because it has been parked since Nov and it fired up right away last week when I took it in??) I figured I was ready for the service B so I would get MB to check out the light. Upon driving away from the shop, I noticed the transmission was in "C" mode. I tried to change it but it wouldn't change. I also noticed that the transmission wouldn't change gears. I pulled over and put it into park. When I tried to put it back to drive, the transmission wouldn't go into gear. Reverse wouldn't work either. I had to get the road side service to bring a flat bed and take it to the dealer. Anyone else ever had this type of transmission issue?? |
| Founding Member Join Date: Jun 2006 Location: Buizingen - Belgium
Vehicle: '05 SLK 350 - 7G
| from his alias, I would say an SLK 55 AMG and a Canadian (CDN) but CDN-SLK55, it would be nice to fill your profile with your location and model as the specs aren't the same over the world. People who can help you with your questions will have a much easier time... and, of course, CDN-SLK55, Welcome to the forum |
Country: Thanks: 288
| Sorry to hear about that, I hope everything get fixed propperly.
Country: Thanks: 96
| This sounds like the control module to me. Had a similar prob after my re-build a fault leading to a loss of charging current at the battery caused the computers to drop below 10 volts and start to shut down systematically killing system after system. All depending on how they charged the car they could have damaged part of the charging system causing the battery to start to drain and the TCU to shut off (normally associated with other faults also) Parts of the network between the computers could have been damaged easy to do if you don't know how to correctly charge on on these causing signals to get lost. They could have damaged the transmission itself when working on the car and the system has gone into safe mode. Or it could be confused from a battery disconnect when charging and it will simply be reset and all will be well. I hope its the last option and i really hope your tranny is OK or you can get the shop to pay for any damages to it otherwise its gonna hurt.
| Don't feed the trolls... Join Date: Jul 2006 Location: Nfld., Canada
Country: Thanks: 285
| Sorry to hear about the trouble! Hope the vario roof is ok too after that hit in the rear?
__________________ - Bill Waiting on a 2009 C63 Opal Fire Red/Alpaca Grey R.I.P. 2006 SLK55 Caspian Blue/Beige Stock 1/4 mile results: ET 12.72, trap 110.80, 60' 1.80 Some guys they just give up living and start dying little by little, piece by piece. Some guys come home from work and wash up and go racin' in the street... - B. Springsteen |
| Founding Member Join Date: Jun 2006 Location: Austin, TX
Vehicle: SLK55 AMG
| Symptoms are exactly like the Trans Valve Body issue (though of course other problems might have the same symptoms). Check Eng light, trans goes into Limp Home Mode. There was a TSB for this. Supposedly only affect MY 2005 (I think, maybe early 06 production to). It really is an itermitent that can be cleared (temporarily?) by a battery disconnect. But does need to go to service, ASAP. |
| | #8 (permalink) |
| Well it has been two days and they still don't know what the problem is. I am a bit worried that the Body Shop screwed something up and I may get hit with a big bill for it. |
| | #10 (permalink) |
Country: Thanks: 96
| They can't find anything? I don't know of much that does not store a fault code for the DAS to read off, have they given it a once over by eye its normally hardware stuff the computer can't see but the eye can pick out easy. This is a MB dealer right i know you say it was taken to one i am just making sure they are approved.
| | #11 (permalink) |
| Ok, after 10 days, they have decided that my car needs a new transmission. They have been trying all kinds of things that Germany has been telling them and nothing has fixed the problem. Finally MB Germany told them to order the new transmission. It will take at least a week for it to get to Canada and another 3 days to get it installed. They have no idea what caused the failure or what part within the transmission has failed. Not a lot of confidence with my dealer right now... |
| | #13 (permalink) |
Country: Thanks: 96
| Ouch hopefully the warranty will be covering it for you.
| | #15 (permalink) | |
Country: Thanks: 96
Its not a cheap peice of kit
| | #16 (permalink) | |
__________________ - Bill Waiting on a 2009 C63 Opal Fire Red/Alpaca Grey R.I.P. 2006 SLK55 Caspian Blue/Beige Stock 1/4 mile results: ET 12.72, trap 110.80, 60' 1.80 Some guys they just give up living and start dying little by little, piece by piece. Some guys come home from work and wash up and go racin' in the street... - B. Springsteen | |
| maf sensor failure | jbanks15 | Ask DansSLK | 5 | 07-29-2008 05:29 PM |
| Intermittent indicator failure... | Rhino | SLK R170 General Discussion | 1 | 05-27-2008 06:36 PM |
| SLK350 spring failure | pjgraham86 | General Discussion | 4 | 01-14-2008 01:07 PM |
| HD Failure | easty | Off Topic | 10 | 10-20-2006 08:05 PM |
| Power failure | bejak | SLK R171 General Discussion | 4 | 09-30-2006 02:26 PM |
