Changing halogen bulbs in SLK300 - Mercedes Benz SLK World Forum
Go Back   Mercedes Benz SLK World Forum > Mercedes Benz R171 SLK Class Cars > SLK R171 General Discussion
SLKWorld.com is the premier Mercedes-Benz SLK Forum on the internet. Registered Users do not see the above ads.
Old 02-24-2011   #1 (permalink)
SLK World Junior Member
Vehicle: 2010 SLK300 R171
Default Changing halogen bulbs in SLK300
G'day
I bought a SLK300 a couple of weeks ago. Unfortunately the car isn't equipped with bi-xenon headlights and the standard halos are rather dim on unlit roads. I nearly ran off the road earlier in the week! I took the car back to the dealership to have lights raised but they said they can't do anything about it.
Has anyone changed the bulbs for the normal beam to whiter bulbs that give out more light? I asked the dealership about that but they said that those non-factory bulbs might cause a short and void the warranty on the electrics.
I've changed to such bulbs in the past on Mazda, Nissan and even Audi without any problems so was wondering if there's anything special about the Benz that MIGHT really cause a problem.
View slk300r171's Photo Album slk300r171 is offline   Reply With Quote
Old 02-24-2011   #2 (permalink)
AMG SLK::IL's Avatar
Vehicle: 2005 AMG SLK55
Just do a quick search of the forums for bulbs. There have been several topics like this in the past month or two. Most of us have gone to Phillips Extreme bulbs and are definitely happier.
View AMG SLK::IL's Photo Album AMG SLK::IL is offline   Reply With Quote
Old 02-24-2011   #3 (permalink)
Thank you so much for the reply. I shall do a search on the Phillips bulbs!
Old 02-24-2011   #4 (permalink)
Swagman's Avatar
Vehicle: 12' SLK55 AMG
Other Toys: 09 Freelander 2 TD4 2.2
And for those people that did try Phillips Extreme and were still unhappy, we have fitted an aftermarket HID Xenon kit which can be bought for £50 - £150, from retail outlets and takes about 2 - 4 hours to fit... Then you'll have more light than you can handle.. .
View Swagman's Photo Album Swagman is offline   Reply With Quote
Old 02-24-2011   #5 (permalink)
Vehicle: 2009 SLK 55 AMG
slk300r171,
If you wish to PM (Private Message) someone, you need 15 posts. To get those 15 posts quickly, just go to the ‘new members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM.
Premium 1, Multimedia, Lighting packages
Llumar (Clear Bra) Paint Protective Film
OEM MB Plexiglass
Clear Side Markers w/amber LED bulbs
LED Parking and LED License Plate Bulbs
View jbanks15's Photo Album jbanks15 is online now   Reply With Quote
Old 02-24-2011   #6 (permalink)
Vehicle: 2008 SLK55 AMG
Other Toys: X6, K1300GT, Bayliner 3488, and a few aircraft
Any info on this mod?
View rodell's Photo Album rodell is offline   Reply With Quote
Old 02-25-2011   #7 (permalink)
mb911's Avatar
Other Toys: 2008 C300
Chats: 15
H7 Philips X-Treme Powers will help you see a bit better. You can find these on ebay. They are made in Germany. From everything I know, this option is completely ok, they have approvals and whatnot in Europe. They are just replacement H7s that are about as good as you can get in H7s. Tiny bit whiter, fair bit brighter, but still halogens. A solid difference, not earth shattering difference, but helped me see a bit better. When I swapped these, the factory halogens looked awful. One even looked defective. They must buy the cheapest H7s on the planet. Not even 1 penny each I'm guessing.
Still wanted to see if I could do better, so I then I purchased and installed a MTEC HID 4300k kit for R171 on ebay. Pretty happy with the results. The projectors that come with the car standard help the HID kit turn out decent.
My only serious issue with my lights continues to be the low beam projectors are somewhat loose and rattle over bumps, did this before my HID kit too.
I don't drive much at night, so I could have probably just lived with the X-Treme Power. The SLK you sit lower though, and it makes me crave more light. Halogens in a big sedan aren't so bad.
Enjoy the R17X Series of Roadsters...
View mb911's Photo Album mb911 is offline   Reply With Quote
Old 02-25-2011   #8 (permalink)
Vehicle: 2001 SLK320 sport silver 6 speed manual
don't touch the bulb with your bare fingers. avoid any other bare skin touching the bulb either. any natural body oils or other foreign compounds will severely reduce the life of the bulb.
View advoc8r's Photo Album advoc8r is offline   Reply With Quote
Old 02-25-2011   #9 (permalink)
IIRC, the skin oil that may stick to the glass; this heats up during use and causes the glass to break easy, causing lamp failure. It is best to use nitrile/latex gloves when doing the change. If one inadvertently touches the glass with the fingers, clean with isopropyl alcohol (available up to 91% isopropyl alcohol from Walmart or Target) to remove the skin grease.
Pewter(cubanitsilber metallic)/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package; Designo Black Leather Cover on e-brake handle(Thank you Bill T), SmartTop v3.x, John's 3BFM, M113 AMG OEM air filters, Modified R170 ant., clear side-markers & front parking lamps w/error-free LEDs, chromed front & rear turn indicator lamps, steel mesh at battery bay cover & cabin air intake, sock-over-seatbelt buckles, belt-loop guide protectors, Lamin-X fog lamp protectors.
View etyu's Photo Album etyu is offline   Reply With Quote
Old 02-25-2011   #10 (permalink)
Hi all,
Thanks for all your replies. Sounds like the Phillips H7 extremes are the way to go. Anything must be better than the standard bulbs, which really are rubbish. It's unbelievable that the stock bulbs in my Holden Barina (Opel Corsa) are better than ones in a Benz roadster!
I understand they won't be as good as HIDs. The Audi A4 that the SLK replaced had bi-xenon headlights and those were very bright.
Old 02-25-2011   #11 (permalink)
Fanatical SLK World Member
jameslk55's Avatar
Vehicle: 2005 SLK55 AMG
I think the factory metal bracket behind the HID bulb isn't locked in place correctly or tightly. (There are metal brackets right?) When you have a free day, you should take out the wheel and fender lining and practice with your stock halogen bulbs to see if they fit right and rattle over bumps.
When I had my headlamps painted black, the installer seemed to have a slightly tough time getting the HID bulb to lock into place-even with the whole headlamp assembly off the car.
View jameslk55's Photo Album jameslk55 is offline   Reply With Quote
Replacing low beam halogen bulbs bobl Ask DansSLK 2 05-18-2011 04:20 AM
Replacing stock Halogen bulbs? Alec SLK R171 General Discussion 59 04-16-2011 10:51 AM
Need headlight upgrade from the regular halogen bulbs shnjb General Modifications R171 8 10-08-2010 02:35 AM
Changing the bulbs on the foglights ghostdunks Ask DansSLK 12 05-01-2007 04:41 PM
SLK Bulbs thanosSLK General Modifications R171 20 12-04-2006 09:57 PM
Powered by vBulletin Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SLKWorld 2006-2010
Design by Fife Web Solutions
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113
