coolant temperature for 350 - Mercedes Benz SLK Forum
  • 1 Post By nakulan7
#1 Old 05-30-2010
nakulan7's Avatar
Vehicle: 05 SLK 350, 7G Auto.
Other Toys: Lexus IS250
Chats: 2
Quoted: 25 Post(s)
Would appreciate some advice on this:
When on a long run my 350 has a coolant temp of around 90C sometimes a bit below. After reading the AMG coolant temp thread, out of interest i have been keeping an eye on this while starting up from cold and doing my commute of 7 miles or so one way.
On some days after about 7 -8 mins the bar crossed 80C. Sometimes it hovers about 80 and drops back and doesnt cross 80C even after 7 miles and about 20 mins of driving. Today it reached 80c after 10 miles and 21 min of driving but sometimes fell to about 60c and then climbed back up to 80c.
Is this worrying? I have often looked at this on long runs and it is steady at between 80-90 or at 90c and doesnt waver - atleast it didnt in my last long distance run.
Beppi likes this.
nakulan7 is offline
#2 Old 05-30-2010
frogfoot's Avatar
Vehicle: 2005 slk 350 6spd manual designo
Other Toys: Fiesta 1.6tdci work Hack /very large snap-on tool chest very handy
Quoted: 88 Post(s)
Hi Ram
Remember that the outside temp can make a differance to your coolant temp.
as last week was warm in the uk and this week aint the engine warm up time may be different over a short distance from day to day.
cheers pete
Its never Dull in Hull
not when you have a 350 MT
frogfoot is offline
The Following User Says Thank You to frogfoot For This Useful Post:
#3 Old 05-30-2010
Quoted: 287 Post(s)
Sounds normal as the coolant temperature fluctuates esp. with different driving conditions, may be more fluctuations if it is in stop-and-go traffic. It tends to be more constant on freeway driving.
I mainly look at the engine oil temp in the SLK 55, as it needs to warm up to 80C before trying to go beyond 3000 rpm.
Pewter(cubanitsilber metallic)/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package; Designo Black Leather Cover on e-brake handle(Thank you Bill T), SmartTop v3.x, John's 3BFM, M113 AMG OEM air filters, Modified R170 ant., clear side-markers & front parking lamps w/error-free LEDs, chromed front & rear turn indicator lamps, steel mesh at battery bay cover & cabin air intake, sock-over-seatbelt buckles, belt-loop guide protectors, Lamin-X fog lamp protectors, bilateral rear fog lamps enabled, etched ///AMG logo on gear shift knob by Blackrose-etching
#4 Old 05-30-2010
GeeJay's Avatar
Vehicle: '15 C220 CDI Coupe in Fire Opal
Chats: 90
Quoted: 52 Post(s)
90 degC is OK for coolant temp.
80 degF is a bit cool for oil temp... I think Eddy has his units mixed up...
GeeJay is offline
#5 Old 05-30-2010
nakulan7's Avatar
Chats: 2
Quoted: 25 Post(s)
http://www.mbworld.org/forums/c-clas...emp-gauge.html
This seems to suggest a thermostat issue. A generic google search has hits from almost every car enthusiast forum and all of them seem to blame this thermostat.
Pete, could you check your coolant temp and how it behaves when you next do a cold start and drive please? Thanks
nakulan7 is offline
#6 Old 05-30-2010
Vehicle: 05 55 (Brabus 6.1 S)
Chats: 28
Quoted: 7 Post(s)
Doesn't sound like a problem to me, stop start traffic is horrid for a proper check anyways.
Test on a long run with a similar load and similar ambient conditions.
DansSlk is offline
#7 Old 05-30-2010
Quoted: 287 Post(s)
I stand corrected, post corrected to 80 degress Centigrade for oil temp.
#8 Old 05-30-2010
Vehicle: 2006 SLK 350 Designo (sold)
Other Toys: 2007 GL320CDI
Agreed.
Thermostat should keep temp pretty constant, regardless of engine load or ambient temperature. That's its function. Warmup is supposed to be quick and fast.
lkchris is offline
#9 Old 05-30-2010
Chats: 28
Quoted: 7 Post(s)
Hardly, they often fluctuate in stop-go traffic.
Thermostat opens at about the same time on every trip, the temperature is stable between 80-90 on every trip, so all we have is intermittent temp drops on one trip.
Not exactly conclusive, try getting that replaced under warranty.
DansSlk is offline
#10 Old 05-31-2010
Quoted: 287 Post(s)
Just did a test this afternoon on the way home from work. Kept the coolant temp display on the MFD. Temp went from below 40C at start-up to 90C within 5 minutes of driving and stayed constant at 90C until I reached home.
Hope the above observation helps.
#11 Old 05-31-2010
nakulan7's Avatar
Chats: 2
Quoted: 25 Post(s)
Update
Thanks for the replies.
Did a trip this morning - 13 miles, 30 minutes - ambien temp about 15C. The coolant temp hovered back and forth around 80C to reach 90c at end of journey.
3 hours later, retunr via a scenic route. Quickly reached around 90C and kept on wavering back and forth occassionally dropping to just below 80C and when i pulled into the drive was back to around 90c. Ambient temp 20C, 23 miles, 1 hour.
Is this thermostat. or is this coolant temp sensor?
nakulan7 is offline
#12 Old 05-31-2010
Vehicle: SLK 350
Other Toys: BMW 335d Touring
I shouldn't worry about it too much. Mine moves around a bit, but between 80 and 90 is all quite safe. I don't know how they regulate the instrument voltage in a Merc, but years ago there were some horrible Lucas regulators used on Rovers and Jaguars - and as often as not these were at fault in allowing the fuel and temperature gauges to fluctuate. I suspect a better electronic system is used today.
grey man is offline
#13 Old 05-31-2010
Chats: 28
Quoted: 7 Post(s)
I wouldn't bother about that, it's working OK.
It's an electronic thermostat remember and its regulation range is 80-100 degrees, if you notice that it can't keep itself in that range for the majority of the time then get it looked at but until then you will almost certainly be turned away with a no fault found.
Just FYI, a stuck stat will give you a CEL.
DansSlk is offline
The Following 2 Users Say Thank You to DansSlk For This Useful Post:
#14 Old 05-31-2010
Vehicle: 2005 SLK 55 AMG
How can you determine oil temp, is there a menu setting somewhere?
madeinengland is offline
#15 Old 05-31-2010
Quoted: 287 Post(s)
This may not be available on the 2005 SLK 55. The cluster and menu/software in the SLK55 were changed later (but I forgot which model year).
#16 Old 05-31-2010
Chats: 28
Quoted: 7 Post(s)
I think it's 07 and on, you can for about 600 get a new cluster and it will have the menu present.
DansSlk is offline
#17 Old 05-31-2010
Wow 600 seems a lot, don't think I'm that bothered. I'll just guess !
#18 Old 05-31-2010
Chats: 28
Quoted: 7 Post(s)
Yeah it aint' cheap, whole new cluster *chav on* innit *chav off*
DansSlk is offline
#19 Old 05-29-2015
Beppi's Avatar
Vehicle: 2006 Mercedes-Benz 200slk
Other Toys: Boats
Quoted: 74 Post(s)
Send a message via AIM to Beppi
Beppi is offline
Human Verification
Coolant light type-r SLK R170 General Discussion 15 05-04-2010 10:07 AM
Engine temperature gauge and instrument panel lamps..! kole301 SLK R170 General Discussion 0 03-17-2010 04:42 PM
Coolant and Diff fluids/oils Tummy General Discussion 6 11-04-2009 01:17 AM
