2005 SLK 350 - OEM options - Mercedes Benz SLK Forum
#1 Old 06-11-2009
Vehicle: 05 SLK350
I'm in the midst of purchasing an SLK 350. I have a few questions re: factory options package.
I stumbled on this site for factory options. Is this correct?
http://www.motortrend.com/cars/2005/...ons/index.html
1) I was mainly wondering if there were OEM Xenon headlights.
The car I'm looking at has headlight washers.. and by looking at this, all I see the headlight washers are available only with the Xenon light package.
2) is this true? Power seats is an option? The base car only comes with manual seats? Are they height adjustable at least?
boomie is offline
#2 Old 06-11-2009
aka John
Chats: 1143
Quoted: 22 Post(s)
Hey boomie - take a few minutes to update your profile with your location - option packages vary greatly between markets.
Headlight washers are an option without out BiX, but are required with BiX. Also, shoot me the VIN number of the car you are looking for and I'll pull the datacard.
UK-C200 is offline
#3 Old 06-11-2009
Vehicle: 05 SLK350
i can't send you PM. First post.
heres the VIN
WDBWK56F85F051391
boomie is offline
#4 Old 06-11-2009
aka John
Chats: 1143
Quoted: 22 Post(s)
Here you go Boomie - looks like a very nice, very well optioned car. Bix, Lighting package, Sound Package (Harmon Kardon), COMAND, Airscarf, etc.
UK-C200 is offline
#5 Old 06-11-2009
Vehicle: 05 SLK350
wow.. that data sheets amazing..
so wait.. no power seats???
i can't believe the owner would get all these options, but no power seats...
boomie is offline
#6 Old 06-11-2009
Vehicle: 05 SLK350
does the manual seat height adjust? is it like an 8 way power seat, but just manual???
boomie is offline
#7 Old 06-11-2009
aka John
Chats: 1143
Quoted: 22 Post(s)
That's amazing to me - I've never see a US spec SLK without power seats - especially one this nicely optioned! You would expect to see :
242 FRONT SEAT RH ELECTRIC ADJUSTABLE WITH MEMORY
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRRO
Datasheets are normally spot on, but errors do happen. I'd really be suprised that this car does not have electric seats. As much as I use mine, I don't think I'd want to be without on the drivers side for sure...
That said, if this is the only thing missing on the car, I suspect Adam would make you a good deal on electric adjustable seat bases! :-)
EDITED : Never driven an SLK without power seats. My C class does not have power seats, and they are quite adjustable (front/back, up/down, recline, and some sort of "tilt" for the seat bottom itself.)
UK-C200 is offline
#8 Old 06-11-2009
Vehicle: 05 SLK350
Thanks for the quick replies. I'm getting close to the 15 posts to be able to PM.
Hmm.. Adam.. who's that and what does he do?
I want it spot on OEM.
Can I just buy a new seat and do a swap?
boomie is offline
#9 Old 06-11-2009
aka John
Chats: 1143
Quoted: 22 Post(s)
:-) Go say "Hello" to new joiners, you'll be over the limit quickly.
"Adam" is Adamantium on the forum - search the DIY thread. He's managed to retrofit about 10 things that are supposed to be impossible, so at the moment, he's setting the bar.
I suspect that retrofitting the seats would require a control module and a wiring loom. We've got good sources for both, so very doable.
Finding the control module from eBay rather than paying full price from the dealer (same with seats...) is probably the main thing to try and accomplish. I'll look tonight and see if I can find a part number or if it's just part of the front SAM. I'm almost 100% sure it's a separate module...
UK-C200 is offline
#10 Old 06-11-2009
Vehicle: 05 SLK350
you'd figure it plug and play.
thanks again.
boomie is offline
#11 Old 06-11-2009
aka John
Chats: 1143
Quoted: 22 Post(s)
Search the forums, find a post by "DansSLK", and check out his signature! :-)
UK-C200 is offline
#12 Old 06-11-2009
Vehicle: SLK 200K 2005
Chats: 58
Boomie,
welcome from NE England.
John, could you pull my data card if I PM you my VIN?
Normski is offline
#13 Old 06-11-2009
Vehicle: 350 6MT. Retrofitted 55 AMG body wheels seats cluster, Airscarf, Comand & UCI, Digital Climate.....
Chats: 171
I'm Adam and I am a patent attorney, but am guessing that answer is not what you were looking for.
It won't be plug and play, mostly because there are no plugs there.
You'll have looms for the AirScarf, heated seat and SRS system but will be missing the main plug that contols the power seats.
For that you'll need to buy some seats, the seat control module (john reckons that will give you memory mirrors and steering wheel position too) and a wiring loom.
I'd reckon I could source the loom and module for about $250 all in.
Then you just need the seats.
I saw some ripped AMG seats that needed a leather panel replaced, on ebay for $600. They only lacked air scarf, but you could shift that across from your existing seats with little issue.
Adamantium is offline
#14 Old 06-11-2009
Chats: 58
Originally Posted by Adamantium View Post
it won't be plug and play, mostly because there are no plugs there.
You'll have looms for the air scarf, heated seat and SRS system but will be missing the main plug that contols the power seats.
For that you'll need to buy some seats, the seat control module (john reckons that will give you memory mirrors and steering wheel position too) and a wairing loom.
I wish I was as talented as you with stuff!!!!
you make it all sound so easy.
Normski is offline
#15 Old 06-11-2009
Chats: 171
Norm,
am so not talented when it comes to this stuff, the fact is these are parts that were intended to be fitted by MB. So it's not like you need to be clever to fit them. The skill is in sourcing the right bits, that's it.
Once you've got them, with this car at least you only seem to need torx drivers and you are there!
#16 Old 06-11-2009
Vehicle: 05 SLK350
hmm... is there a tutorial out there for the power seats?
boomie is offline
#17 Old 06-12-2009
Chats: 171
hell no. it's not been done yet.
there are some red leather power seats on ebay UK.
Not sure how much international shipping would be. They are both electric and both heated with airscarf, so would be nearly all you'd need.
I can look into finding the module you need and then with any luck it can be sorted easily.
You'll need the custom loom, but it won't be much, then its just a case of plugging it in and giving it power.
Do you have power mirrors and a power steering wheel adjustment?
#18 Old 06-12-2009
Vehicle: 05 SLK350
it can't be that hard can it? i mean, its just having the right stuff.
i still shocked...
Nav, Sound, lighting, air scarf, sport suspension, yet no power seats.
boomie is offline
#19 Old 06-12-2009
Vehicle: '05 SLK 350
My 2005 350 is similarly equipped, and without power seats (I think that the power seats were an extra option in the '05 and became part of a package in '06) - the manual seats do have height adjustment (and well as front/back and tilt). Pretty basic, but work just fine for me.
rjm16 is offline
#20 Old 06-12-2009
Vehicle: 05' SLK350 BiX, Heated seats, air scarf, Comand APS, Parktronic
John, can you acquire datasheets for only US cars or can you get them irrespective. I just bought a used R171 and wanted to know the exact specs, I am in Australia.
Havok is offline
Human Verification
Uk options help Becky9 SLK R171 General Discussion 14 02-17-2009 07:42 PM
When you think that you have all the options SLK 55 Kleemann Off Topic 16 04-30-2008 01:31 PM
Options you wish you had, options you could do without. heezyo2o SLK R171 General Discussion 79 01-06-2007 01:12 AM
2007 Options in US Ikarus General Discussion 14 08-03-2006 08:29 PM
