Go Back   SLK World Forum > Mercedes Benz R171 SLK Class Cars > SLK R171 General Discussion
Tire Rack- Revolutionizing Tire Buying
Old 11-03-2006   #1 (permalink)
Vehicle: SLK55 AMG
Default Heated rear screen not working, any ideas?
My heated rear screen turns itself back off (ie the light on the switch goes off and screen stops working) about a second after i turn it on?
Any ideas?
View aquascape's Photo Album aquascape is offline   http://www.slkworld.com/Boss Key
Old 11-03-2006   #2 (permalink)
Super Moderator
How long do you wait until after engine start before powering stuff up do you run the heated seats and airscarf or use the front screen defrost at the same time?
Could be an undervoltage in the system the screen is a low priority and is shut off but it should automatically fire up again once there is enough charge.
Do you hear the relay click when you press the switch?
Old 11-03-2006   #3 (permalink)
DesignoSLK's Avatar
Vehicle: 2000 Designo SLK230
Donation Level 3
HA...I'm an idiot! I was trying to envision the windscreen between the roll bars as being heated?!?! I forgot you UK guys call the windshield the windscreen. Hence, the "rear screen" is the rear defrost for us defectors....
View DesignoSLK's Photo Album DesignoSLK is offline   Boss Key
2009 Camaro FishtailnZ Off Topic 10 11-29-2007 03:02 PM
Remove paneling on rear center section Zeiser50 SLK R171 General Discussion 2 08-18-2007 01:27 PM
Remove rear bumper Zeiser50 SLK R171 General Discussion 1 08-18-2007 12:14 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
