| SLK World Member Join Date: Jul 2006 Location: West Midlands, UK
Vehicle: SLK55 AMG
| What is the best and easiest to fit roof module for a right hand drive UK SLK55 Car? Are the fuctions of them all the same. I believe some are difficult to fit to right hand drive uk cars as the wiring is different? Many thanks |
| | #2 (permalink) | |
Country: Thanks: 379
Mu suggestion would be to use the "pin" method to check out the voltage from the red wire and to cover any exposed wire ends with masking tape to minimize the risk of shorting a circuit and blowing a fuse. Here's a link to the pin method-- last few posts in this thread: http://www.slkworld.com/ask-dansslk/749-fuse.html Hope the above helps.
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Mod. R170 ant. EuroClear sidemarkers w/PIAA PlasmaIon lamps, chromed front & rear turn indicator lamps, PIAA SuperPlasmaGTX front parking lamps, HyperWhite license plate lamps ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Scott), bilateral rear fog lamps enabled. Last edited by etyu; 11-03-2006 at 01:47 PM. | |
Country: Thanks: 91
| Just to add to etyu's post you can get RHD modules now also with longer wires so you get some more flexibility as to where to put the thing. Also try and take power from the fuse box its safer that way
