Temperature Sensor - Mercedes Benz SLK Forum
#1 Old 05-19-2009
piperkid's Avatar
Vehicle: 2017 SLC300
Other Toys: Commander, Turbo Airplane, BMW Z3, C5 Vette, Honda VTX 1800 MC
Temperature Sensor
Anyone know where the ambient temperature sensor is located on the SLK 350 (2007).
The other day the display was reading 154f while driving. (It gets hot out here but 154?)
I think it is being influenced by engine heat.
If I can find where it is mounted I would consider relocating it.
piperkid is offline
#2 Old 05-19-2009
Quoted: 323 Post(s)
For non-AMG, IIRC, it's near the left side (driver side) fog lamp, look at the plastic grille that holds the fog lamp. There's a hole there where a black tapered probe (about 2.5 cm or 1 inch) sticks out.
It's known to come off the housing and give weird temps. If it's under warranty, MB should reattach it for free.
#3 Old 05-19-2009
Quoted: 323 Post(s)
From UK-C200 in a thread about removing bumper cover:
Next, there are two nuts that are recessed in the front foglight housing. Remove these carefully, as they tend to fall into the housing. (red circles, outside temperature sensor is in the yellow circle)
#4 Old 05-19-2009
Quoted: 323 Post(s)
BTW, welcome piperkid and thanks for putting the info in your profile on your first post. This saves jbanks from 1 more post
#5 Old 05-19-2009
aka John
Chats: 1143
Quoted: 23 Post(s)
;-) Welcome from London! It's pretty easy to poke the temperature sensor back in if it's fallen out, but you do have to remove either the drivers side fender well cover or the bottom front engine cover to get to it.
I think personally that turning the wheel to the stops to give yourself a bit of room makes the fender well removal the easiest - it's hard to remove the bottom cover without jacking the car up.
If the car is under warranty, go have a free cup o' coffee while the techs put it on a lift any fix it in 10 minutes!
UK-C200 is offline
#6 Old 05-19-2009
Quoted: 4092 Post(s)
Good job piperkid, saves me from typing:
The temp probe migh have fallen loose and hanging near the radiator and it must stay in its intended position. search the forum and you will find more info on how it works with the maf and engine.
If you have not, please use the 'search this forum' feature for your questions as they have probably been asked before.
In addition, If you have not, please post your questions in the appropriate discussion forum for a quicker response.
And finally, if you find something useful on your visit here today, please consider donating for security updates and repairs to the site. Any amount is welcome! Thanks!
Wavetrac LSD thread here:
#7 Old 05-19-2009
jameslk55's Avatar
Vehicle: 2005 SLK55 AMG
Quoted: 15 Post(s)
i thought he set up an auto-reply to every first-time poster. he might as well add it to his signature.
jameslk55 is offline
#8 Old 05-19-2009
i am trying to be the top poster! i have a looonng way to go!
#9 Old 05-19-2009
piperkid's Avatar
Thanks to all for the reply's.
piperkid is offline
Human Verification
engine Temperature !! no-way SLK R171 General Discussion 2 08-20-2007 07:17 PM
