Auto headlight function won't work - Mercedes Benz SLK Forum
#1 Old 05-06-2009
HwoALanG's Avatar
Vehicle: 2007 SLK 280(Current) - Had SLK 350
Omg! Have you guys ever had this kind of problem??
I started car this morning and my head light starting to turn on...normal right.
But after sun comes up and I thought headlight would turn off. But no!!
It keep stays on and won't shut off... even in bright sunny day.
So I switch to turn off position and it still stays on!!!
I put into parking light position and still stay on!!
And if I put into manual on headlight position.... fog light comes on and headlight stays on.
Only way I can shut it off is put into off position and turn off the ignition.
I tried anything possible, but I think I might blow up the fuse or something....
I have aftermarket HID... and I hope that's not screwing things up....
And my car is out of warranty... I need help!!
SAM is doing it’s own thing!
Another weird thing I noticed was SRS sign came on this morining but it went away after few min...
gosh... i hope it's not huge problem.....
HwoALanG is offline
#2 Old 05-06-2009
Vehicle: 05 55 (Brabus 6.1 S)
Chats: 28
Quoted: 7 Post(s)
OK check the headlamp mode on the cluster settings menu is set to Manual, then try setting the switch to Off and see if they respond, it could just be they are set to Auto and the sensor is dirty.
I wouldn't have thought the HID's would be causing this unless some very bad wiring has caused damage at some point, that SRS light is probably nothing to worry about since it reset so fast and it is not related to the headlights in any case.
DansSlk is offline
#3 Old 05-06-2009
HwoALanG's Avatar
Thanks for quick respond. Dan
we always appreciate your help.
It was acting really weird. Everything was failing and I got all kind of warning lights. Include check engine light.
But thank god. I found the cause.
It was the moisture that somehow got into fuse box. Cause I opened up the hood this morning…
and saw Fuse box cover was loosed... and later I found out that I’m missing one of the clips that suppose to hold the fuse box cover...
Gosh... I drove it for all day today and everything is okay now. I think engine bay heat vaporize the moisture.
Thanks again and last question.
Where can I get the fuse box cover clip?? Do I have to buy the cover itself?
HwoALanG is offline
#4 Old 05-06-2009
Quoted: 3701 Post(s)
under warranty? take into mb and say, look, missing clip!!
Wavetrac LSD thread here:
#5 Old 05-06-2009
Quoted: 315 Post(s)
Good point
Good point jbanks
#6 Old 05-07-2009
Founding Member #7
mtiede's Avatar
Vehicle: 2017 SLC 300R
Quoted: 19 Post(s)
Original posting says its out of warranty.
mtiede is offline
#7 Old 05-07-2009
HwoALanG's Avatar
thank you !
HwoALanG is offline
#8 Old 05-07-2009
aka John
Chats: 1143
Quoted: 22 Post(s)
A1715400182 is the part number for the cover, the clip is not listed as a separate part.
UK-C200 is offline
#9 Old 05-08-2009
HwoALanG's Avatar
god!! i have to buy the cover... gosh~!!
Thanks anyway!!!
HwoALanG is offline
Human Verification
Marginally not Safe for Work. Alfa Romeo Booth at Russian Auto show cyberdrakon Off Topic 1 04-15-2009 02:09 PM
'09 SLK 350 Roof and window function vincent007 SLK R171 General Discussion 30 11-18-2008 04:36 PM
Navi ETA Function X2 DansSlk SLK R171 General Discussion 89 09-20-2008 03:36 PM
Disabling the cornering light function phatchink General Modifications R171 5 06-21-2007 09:53 AM
