Door panel removal - Mercedes Benz SLK Forum
 5Likes
#1 Old 05-05-2009
Vehicle: SLK 200K 2005
Door panel removal
Hi, I would like to know how to remove door panel, I have loosen door side screws but it seems it is fixed in the center, any idea?
aramis is offline
#2 Old 05-06-2009
Anyone can help?
aramis is offline
#3 Old 05-06-2009
aka John
Chats: 1143
Quoted: 21 Post(s)
Yes, but it will take a couple of hours, I'm in the middle of plumbing in a SDARS kit at the moment.
UK-C200 is offline
#4 Old 05-10-2009
Vehicle: 2006 SLK 280
Any news/updaet?
Heng is offline
#5 Old 05-10-2009
Vehicle: 96 SLK 230K
Other Toys: Samurai
Chats: 39
Got a German "how to".
The pic's says a lot.
http://tinyurl.com/r33w2t
ToolMaven and Hui Sweetcheong like this.
Gabus is offline
The Following 4 Users Say Thank You to Gabus For This Useful Post:
#6 Old 05-10-2009
Founding Member #7
mtiede's Avatar
Vehicle: 2017 SLC 300R
Quoted: 19 Post(s)
babelfish will help somewhat with translating the German.
mtiede is offline
#7 Old 05-10-2009
Those pictures are helpful. When I tried to pull the panel off, something in the middle of the panel (top part of door handle) prevented me to do so. Anyone can help?
Heng is offline
#8 Old 05-17-2009
Ok, today I tried to remove the door panel successfully. The picture shown the trick that prevented me to remove the door panel a while ago. I hope this will help you guys.
Again, thanks to Gabus helpful link.
ToolMaven likes this.
Heng is offline
The Following User Says Thank You to Heng For This Useful Post:
#9 Old 05-17-2009
Thanks to everybody, that will help a lot!!
aramis is offline
#10 Old 05-17-2009
Founding Member #7
mtiede's Avatar
Quoted: 19 Post(s)
So that black plastic piece was over something and you had to lift up first?
mtiede is offline
#11 Old 05-17-2009
that plastic piece goes into a small hole and have to be lifted up to completely remove door panel, once you have loosen all screws.
aramis is offline
#12 Old 05-17-2009
Yup, the black plastic piece actually locked to the metal of the door panel. You need to push/lift the whole door panel up in order to remove the door panel after loosen all screws and plugs.
Heng is offline
#13 Old 06-06-2009
Jakub's Avatar
Vehicle: SLK 200
is it easy to take the panel off ? I wanto to know whether there is high possibility of breaking plastic clips which hold the panel ?
Jakub is offline
#14 Old 06-07-2009
It's quite simple, if any plastic clip is broken, they can be replaced at a very low price, maybe one or two clips couls be broken, just do it very slow when pulling out the panel, then lift up to completely remove it.
aramis is offline
#15 Old 06-08-2009
Jakub's Avatar
Vehicle: SLK 200
thx for your answer. W would only like to know where, in case I break them, can I get the clips ? from MB ?
Jakub is offline
#16 Old 06-10-2009
Yes, you can get them at MB at very low price
aramis is offline
#17 Old 06-11-2009
Jakub's Avatar
Vehicle: SLK 200
cool, thanks for your reply
Jakub is offline
#18 Old 06-21-2009
Jakub's Avatar
Vehicle: SLK 200
I need some help. I tried to remove right door panel cause it creaks all the time when I try to open the door which is quite annoying and embarassing when somebody passes by at the same time I hear as if passing by next to a old russian car when actually it's MB slk. So when I tried to remove the door panel (in accordance with the german manual) I did everything they showed (cause I don't understand everything which is written there) I stopped at a point where all plastic clips are unclipped and that's it. The upper part of the door panel seems to be "glued" next to window and I can't find anything which still holds the door panel. I tried to lift and pull it as somebody described but it won't move. I don't to use excessive power cause I have the impression I might break something. What exactly should I do when the loud speaker is taken way, plastic clips are unclipped and the screw under this silver plasic is also unscrewed ? I would be grateful is somebody who acutally did it could say what I should do next. Also if you have some more detailed pics that would probably help too.
Jakub is offline
#19 Old 06-22-2009
Jakub's Avatar
Vehicle: SLK 200
I found this video footage http://www.youtube.com/watch?v=thAVY-3Ye6g . Is it similar to slk door panel removal ? As I wrote previously something between upper door panel and window is preventing me from taking it off. In video it seems as it there were some plastic clips in this area ? are there any ?
Jakub is offline
#20 Old 02-13-2013
hoangcao243's Avatar
Vehicle: SLK 350-2005 MT
Have you done it successfully ?
hoangcao243 is offline
Human Verification
How to remove door panel? doctort SLK R170 General Discussion 11 12-12-2011 04:36 PM
Inner door card removal Jiveman General Modifications R171 2 09-03-2008 06:55 PM
