DIY : R171 Trunk Struts Replacement - Mercedes Benz SLK Forum
 61Likes
#1 Old 01-16-2011
DAS/STAR Registered Owner
Caboz's Avatar
Vehicle: SLK R171 2004 200 Kompressor - Kleemann K2
Other Toys: Volvo V50 2.0D
Quoted: 17 Post(s)
Today I Replaced the R171 Trunk Struts.
Part Number: A171 750 00 36
This is the DIY:
1. Remove the opening limiter:
2. Secure the hinges on both sides so the trunk doesn't close on you:
3. Remove the struts:
4. Grease the ball joints:
5. Install the new Struts.
Caboz is offline
#2 Old 01-16-2011
cconcepcion's Avatar
Vehicle: Slk-280 2006 Black/Black
Other Toys: MB CLA-250
Quoted: 11 Post(s)
Very helpfull information...I just change mine yesterday.
The black piece i just remove the square top without removing it from the arm.
..after 1 hour trying to figure it out !!!
cconcepcion is offline
The Following User Says Thank You to cconcepcion For This Useful Post:
#3 Old 01-16-2011
admin's Avatar
Vehicle: Linux Server
Chats: 488
Quoted: 8 Post(s)
Thanks for posting. The SLKStore.com has OEM Mercedes-Benz trunk struts if anyone needs these.
http://www.slkstore.com/home.php?cat=295
admin is offline
#4 Old 01-17-2011
Quoted: 315 Post(s)
Moderators, may I ask that this be made "sticky".
The Following 2 Users Say Thank You to etyu For This Useful Post:
#5 Old 01-17-2011
sokoloff's Avatar
Chats: 3
Quoted: 62 Post(s)
Is this job on the 171 that different than the job on the 170? I replaced the struts on my 170 and there was no need for wire ties or removing the opening limiter. Just pop the old strut off and put the new one in. Took about five minutes.
Len
2003 SLK320 36,000 miles
1959 220S Cabriolet - for sale -
1999 E300D 206,000 miles
2014 Smart electric 9500 miles
sokoloff is offline
#6 Old 01-17-2011
Vehicle: 2006 SLK 350 Designo (sold)
Other Toys: 2007 GL320CDI
Better to edit this and replace "disassemble" with "remove." Two times.
You don't take apart the bumpers and you don't take apart the shocks, you just remove/install them.
sabre2 likes this.
lkchris is offline
#7 Old 01-17-2011
Caboz's Avatar
Quoted: 17 Post(s)
Ok, done!
Caboz is offline
#8 Old 01-17-2011
Caboz's Avatar
Quoted: 17 Post(s)
On the R171 we have only two options; compress the struts (very difficult and easy to damage the struts) or like I described.
Because if you don't remove the opening limiter there isn't enough distance between the ball joints to install the new strut.
Chippyslk350 likes this.
Caboz is offline
The Following User Says Thank You to Caboz For This Useful Post:
#9 Old 01-17-2011
And, gee, it's how Mercedes specifies it be done.
And FWIW you can do one side at a time.
lkchris is offline
#10 Old 01-18-2011
Caboz's Avatar
Quoted: 17 Post(s)
Yes I recommend doing it one side at a time, but always secure the hinges or have someone hold the trunk for you, this all procedure takes no more than 10 min.
Caboz is offline
#11 Old 01-18-2011
Quoted: 315 Post(s)
IIRC, without removing the plastic triangular base with the rubber "stopper", the rubber bumper can be slid sideways from its trapezoidal base.
I like the idea of using plastic ties to partially secure the hinges and someone lifting up the trunk lid Thanks for the DIY.
ezsquid likes this.
#12 Old 01-18-2011
Vehicle: 2005 SLK55 AMG Black/Black
Other Toys: 2008 ML550 Black/Black P3
Thanks for taking the time to photograph and share. I also like your idea with the plastic ties. Great safety tip!
Brian_74 is offline
#13 Old 02-26-2011
Motzkoman's Avatar
Vehicle: 2012 SLK 350, 2011 GLK 350
Talking
Thanks ...just did mine...great DIY...
Motzkoman is offline
#14 Old 03-11-2011
HiHoSilver SLK's Avatar
Vehicle: SLK350 Iridium Silver Year:2004
Other Toys: Cadex Mountain Bike
Thank you very much, I am about to do this job and this description has been very helpful. Thank You
HiHoSilver SLK is offline
#15 Old 03-21-2011
Caboz's Avatar
Quoted: 17 Post(s)
My pleasure!
I noticed a big difference on lifting the trunk, almost didn't remember how easy it was wen it was new.
Caboz is offline
#16 Old 04-13-2011
Philly Bob's Avatar
Vehicle: 2005 SLK350, Iridium Silver, airscarfs, command, premium package, green filters
Strut replacement using a clamp
Thanks Caboz for the great instructions. Of course I found them after replacing mine. Here is an alternative solution, but Caboz has the best one. Wish I knew about removing the trunk limiters.
Prop open the trunk and slide back the spring clips from the struts. Brace the trunk open. After attaching the lower end of the strut, I used a 12 inch "quick clamp" to compress each strut about !/2 inch and snapped it into position. Replace spring clip. Thats all it took. Note clamp needs to be on the very end of the strut.
Philly Bob is offline
#17 Old 04-13-2011
Vehicle: I like it a lot
Other Toys: slk55
Quoted: 11 Post(s)
im guessing this would prevent the trunk lid from coming back down and hitting me on the head as I rummage in the boot.
rya96797 is offline
#18 Old 04-14-2011
Vehicle: 2006 SLK 280
Other Toys: Trophy wife, 2007 Acura MDX, 2011 Ford Edge Limited
I second the motion.........
Theregans is offline
#19 Old 04-22-2011
taroliw's Avatar
Vehicle: 2006 SLK350
Was pointed to this article by another member and really appreciate it being posted! Just wanted to point out that it may not be immediately evident how to remove the limiter clips -- I found it wasn't sufficient to just slide the rubber bit out. I had to gently wedge two screwdrivers (one under each side) to get the tabs to disengage from the slot in the hinge arm.
Other than having to find a way not to damage the clips while removing them, this was pretty easy!
taroliw is offline
The Following 2 Users Say Thank You to taroliw For This Useful Post:
#20 Old 04-22-2011
Quoted: 315 Post(s)
Welcome back taroliw.
Human Verification
R171 Door mirror indicator lamp replacement Ikarus SLK R171 General Discussion 13 12-17-2016 06:58 AM
Replaced trunk struts blue320 SLK R170 General Discussion 10 07-19-2011 10:41 AM
FS good trunk struts for 99 slk gettirdun Where to get R170 SLK Items 2 04-23-2010 09:54 PM
