How to refill Hydraulic Pump Hard Top - Mercedes Benz SLK Forum
#1 Old 04-23-2009
Hello,
Just got a 2000 SLK 230 and I need to fill up the Hydraulic pump for the hardtop. I've read that I need to remove the pump in order to fill her up but this seems a little complicated. Is there any plug in the pump that is used to fill her up? I see several TORX screws and I don't know if any of them is to be used to refill the pump. Thanks
wdethoma is offline
#2 Old 04-23-2009
Other Toys: 1986 560SL, 2012 VW Tiguan, 2008 GMC Sierra slt
Quoted: 73 Post(s)
The screw on top of the pump is for the refill, the one on the side is to releave the preasure when you open the top manualy. There is a refill line on the side as well.
#3 Old 04-23-2009
Thanks for the reply. The top torx grey screw is the only screw I see. There is another one next to the gold torx. The gold being the one used to lower or raise manually. Where do I have to releave pressure? Thanks
wdethoma is offline
#4 Old 04-23-2009
This is a pic from the side of the pump. Which of the three screws is the one I need to refill the pump? Thanks
wdethoma is offline
#5 Old 04-23-2009
wdethoma is offline
#6 Old 04-23-2009
there are three screws at the top. http://yfrog.com/0lpumptop005j
wdethoma is offline
#7 Old 04-24-2009
Vehicle: 96 SLK 230K
Other Toys: Samurai
Chats: 39
Hi
Should be a screw on top of the pump - upper right side.
It should fit a hex/allen/unbrako(dunno what you call it) key size 5.
Oil level should be between min and max.
After filling, tighten screw with 8NM torque
EDIT: If you look down through the "brush", you'll see the screw.
Gabus is offline
#8 Old 04-25-2009
Vehicle: 2003 Yellow SLK230
Other Toys: 2014 Tesla Model S, 2013 Toyota Tacoma
Just curious, I would think that this should be a "closed system" where the fluid level ought to remain constant. Under what conditions would you need to add fluid to the pump? Was there a leak or bad seal or something that was replaced first?
atebit is offline
#9 Old 04-25-2009
Thanks. That is the correct screw. Hard time to refill it. Found that I have one of the hard top cylinders leaking big time. Have a one month warranty so they will fix it for me on Monday.
Some other info: Under normal circumstances you shouldn't need to refill the hydraulic fluid in the pump unless you have a leak. Due that I just bought the car and the pump looked so new, I thought that maybe it had been exchanged and it needed more fluid due that the system had pulled it all in (Bleed).
wdethoma is offline
#10 Old 09-26-2009
can someone tell me what hydralic rating the fluid is for the convertable roof?
zhark is offline
#11 Old 10-05-2009
Vehicle: MB SLK 230 Kompressor
Hello, I have the same problem, now I need to buy the liquid and find the leak.
Can you please tell me the brand and specification for that liquid?
Tks
Seiya1972 is offline
#12 Old 10-15-2009
Tks
OK finally I went to the Dealer, $20 and the part is: 1 liter A000 989 91 03 10
Cya!
Lackew likes this.
#13 Old 10-15-2009
Quoted: 3968 Post(s)
seiya1972, zhark,
And finally, if you find something useful on your visit here today, please consider donating for hosting and licensing fees to the site. Even $5 is welcome! Thanks!
Wavetrac LSD thread here:
#14 Old 10-28-2010
Thanks for the good info!
bridgewater is offline
#15 Old 02-26-2011
Vehicle: SLK
That helps thanks.
snbush67 is offline
#16 Old 10-02-2012
Thank you it helped a lot
tinymimo is offline
#17 Old 10-02-2012
tinymimo,
In addition, if you haven’t, please post your question in the appropriate discussion forum for a quicker response. Be patient and a knowledgeable member will address your question.
New members and guests should be aware that the 'New Posts' link next to the 'Search' link top right of the info bar is a great way to see all of the posts you have missed since you were on the forum last. Remember to click 'mark forums read' under quick links when you leave.
Thank you,
Moderator/Founding Member
#18 Old 06-08-2013
Easy way to access filler hole?
Looks like easy access to the refill hole on top IF one would take the plastic panel(s) inside the trunk off. Has anyone had experience doing it that way? How difficult is it to remove the panel(s)?
aeee is offline
#19 Old 06-08-2013
aeee,
Want to post a picture? Start a new thread or make a post, click on the ‘paper clip’ or go to ‘advanced’ and then ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’!
#20 Old 08-22-2014
hutano
Guest
Posts: n/a
Chats:
Quoted: Post(s)
Removing panes
Panels will take approx. 1 hour to remove. Remember to open the trunk on both ends; otherwise it looks impossible.
Human Verification
Next CLK appears to be getting a folding hard top. Tummy Off Topic 2 10-28-2008 01:43 PM
Hard top problems for my slk villafestejoinn Caring for your SLK 1 08-07-2008 09:33 AM
Hydraulic Fluid for Roof Pump cw4bryant General Discussion 1 07-31-2008 06:30 PM
Hydraulic roof leak being fixed nmslk SLK R171 General Discussion 13 05-30-2007 08:30 AM
