HELP! ABS/BAS/ESP warning lights on and top problem - Mercedes Benz SLK Forum
 4Likes
#1 Old 09-15-2008
Hi everyone,
Full Problem Explained:
Just yesterday, I noticed that my ABS/BAS and ESP warning lights were lit up on my instrument cluster. I also noticed that once the car was parked and I wanted to put my top up, the switch to put the top up would flash red and the top would not go up as normal. I checked all the things that would make it flash normally like the shade in the trunk not being in place or the trunk open, etc, and everything was as it should be, so I am guessing that all of these things are somehow related.
I did however notice that once I turn the car off, then turn the key to the point right before your crank the car (when ALL lights are lit up on the instrument cluster) I was able to put the top up as normal. Today I was testing things out and when I first got into the car, I was able to put my top up and down as normal with the car running (before driving anywhere) but after having driven for 5 minutes, I was back to turning the car off and then the key to the point right before your crank the car (when ALL lights are lit up on the instrument cluster) before I was able to put the top up as normal
Before I go nuts and make my first visit to my local MB dealership, is there any easy quick fix techniques I should look into or anything I should check (ex. fuses, etc) to see if its something silly that is causing the problem (and to avoid paying an arm and half a leg at the MB dealership for something silly).
P.S. -- yes, I have done a few quick searches, and I have tried turning the steering wheel all the way the right then left when the car is on to "reset" things -- unless I was doing something wrong, that did not work -- also in my searches, I have not seen anyone with the top up problem I seem to have, so maybe that problem will clue someone into what is going on?
Cliff Notes Version:
ABS/BAS and ESP warning lights are lit up on instrument cluster
top does not go up when car is running, have to turn car off and then turn key to the point before the engine cranks (when all lights are lit up on instrument cluster) -- top will go up then. What is wrong and how do I fix?
Thank you to anyone who can help or shed some light on this topic. Sorry for the long post!
||SLK320||
||SLK320|| is offline
#2 Old 09-15-2008
Founding Member #7
mtiede's Avatar
Vehicle: 2017 SLC 300R
Quoted: 19 Post(s)
Isn't there a menu choice somewhere that let's you choose the max speed at which you can operate the top? Maybe that is set to zero? Just guessing...
mtiede is offline
#3 Old 09-16-2008
Quoted: 315 Post(s)
I don't think //SLK320// has the SmartTop module.
#4 Old 09-16-2008
Founding Member #7
mtiede's Avatar
Quoted: 19 Post(s)
The smarttop let you set it for more than 9mph, but I thought I remembered the 320 allowing you to set a speed too. Just slower speeds. But my memory is worth less and less as the days pass
mtiede is offline
#5 Old 03-10-2009
Vehicle: slk320
you need a new brake light switch
EDD57 is offline
#6 Old 04-02-2009
Vehicle: SLK 320
You get it fixed? Coz ive had the same or similar problem for almost a year now. I've been to Independents and the main dealer - they have changed, the brake switch located under the foot pedal, the front left brake sensor, and a steering angle sensor under the dash. I have also replaced the battery and checked all the wiring arounnd the ASR module. I've lost track of the times the faults which show up on diagnostics have been cleared. I've posted upteen requests on another forum and got little back in the way of help. Looks as though the same goes for this forum from the responces you have had.
Hope you have better luck than me - my car 2000 year SLK320 is booked in to another mercedes dealer for next thursday. I dont honestly think it will get fixed now. If it doesnt, then it's going - ive had enough of it. (
HarrySolomon is offline
#7 Old 04-02-2009
Thread Hijacker
dmjonez's Avatar
Chats: 1599
We could use a little more information. Specifically which codes do you get? The light is always on, or intermittent? Never any relief or improvement, even after the visit to the garage? No guarantee for their work? Can you start from the beginning and go through the whole issue, as there may be some small point that solves the entire problem...
dj
dmjonez is offline
#8 Old 10-17-2010
Vehicle: 1998 230SLK
Other Toys: Nissan Elgrand, 1960 Vauxhall Victor
I have exactly the same problem on my 230SLK, has anybody given you any other ideas as to what it could be. The ABS and other warning lights are on all the time, and the hood goes up sometimes, but another time it wont. I would be pleased if you could throw any light on this problem
Thanks Chris
Chris42 is offline
#9 Old 10-17-2010
Quoted: 3701 Post(s)
chris, fyi last post was over a year ago
Wavetrac LSD thread here:
#10 Old 10-17-2010
Other Toys: 1986 560SL, 2012 VW Tiguan, 2008 GMC Sierra slt
Quoted: 67 Post(s)
Hey Chris this is an old thread but have a look at the K40 board for bad solder joints, check the main oil tank in the boot which controls the roof it may be low on oil. Have a look at the PSE pump in the boot, if its wet that could be one of the problems with the roof. If all looks good then you may have a bad limit switch for the roof.
#11 Old 06-05-2011
Took the car to an Independent Garage and they did a diagnostic test, told me that the ring on the end of the drive shaft had broken, that was causing the ABS lights to come on. They phoned Mercedes and were told that you cannot buy the ring on it's own, have to buy the whole drive shaft (£625). I came home and looked online at Mercedes scrap dealers, and found one for £40 + £18 postage. Ordered it, came within 3 days, I then took it to the garage they charged me £120 to put it on, that included MOT, so I was well pleased with that.
Chris42 is offline
#12 Old 03-12-2013
DavidJB's Avatar
Vehicle: 2013 SLK250CDI Palladium Silver
Other Toys: cameras,golf clubs,fly fishing rods and reels
Ok I had exactly the same problems on an SLK 230 Roadster several years ago,Did the usual brake switch.wheel sensor checks and changes but did not solve the problem. It used to clear itself then soon came back again.
Had it in to an independent Merc specialist garage who had the car for test drives and checks for about a week. Eventually after lots of false alarms they traced the problem to a faulty solenoid on the end of the crankshaft.Apparently a seal had failed and allowed oil to seep past the solenoid and migrate along the electrical wiring loom up to the ECU.They fitted a new solenoid ,new wiring loom and managed to dry out the oil that had got onto the pcb components and solenoids inside the ECU thankfully.
I also had to have a new IFZ control unit and new PSE pump at the same time,do not know whether these faults were caused by the faulty wiring loom or not but suspect they were all interelated.
The total bill for parts and labour which included recovery to their garage, diagnostic tests,starter line and new ignition door key was £2,086.27 inc VAT.This all happened in March 2010. I reckon I got away lightly with the bill.
DavidJB is offline
#13 Old 03-12-2013
robbiemarcelo's Avatar
Vehicle: 1997 slk230 Linarit Blue
Do the slk230 have a setting where you can put the top up when moving? mine needs to be fully stopped before you can operate the top.
robbiemarcelo is offline
#14 Old 03-12-2013
that is what the smarttop mod does for you:
http://www.slkstore.com/product.php?...cat=268&page=1
Remote control of convertible top - open and close your convertible top using the original factory remote control key fob.
Passive mode - allow factory test equipment to be utilized without causing irregularities in their read-outs.
Extra chirp signal function - when operating the power locks, the horn sounds once briefly. (this can be turned off)
Open/Close top while driving - open and close the top while driving up to 38 mph.
Individually programmable - configure features/functions of the smartTOP module to meet your personal preferences.
One Touch Top - 'one touch' convertible top operation allows you to open and close automatically.
Extra top convenience mode - turning the ignition on or off does not interrupt convertible top operations.
#15 Old 07-11-2013
Vehicle: SLK 230 Kompressor, Polar White with Mondrian Blue/Black leather
Other Toys: Mini Cooper S
Same thing has just happened to me...ASR/ABS light on = no top mechanism.
Merc garage diagnosed wheel motion sensor faulty. Part on order - just need it quick as the sun is shining !!
Always Wanted One is offline
#16 Old 06-12-2015
Vehicle: 2001 slk230 124,000 miles YELLOW, not yellow
Other Toys: 2011 vw jetta
Had the same problem today. Started the car, put down the top, ABS/BAS/ESP lights went on and the top would not go up until I turned off the ignition, turned the key to position 2 (all lights on, no cranking) and the top went up.
I will take it to my service guy and ask him to try the fixes outlined here, cheapest first. Do you know the part number of the part that your dealer ordered (wheel motion sensor)?
Where is the K40 board to look for bad solder joints? Is that the PSE pump in the boot, if its wet that could be one of the problems with the roof? I recently took the vacuum door lock module apart, saw it had been wet, and cleaned everything with electric board cleaner - got my door locks working again, but not my interior light. That was a couple weeks ago, and will look at it again.
I will try to find the main oil tank in the boot which controls the roof to see if it may be low on oil. Where is that, anyone? If all looks good then you may have a bad limit switch for the roof.
Any additional advice would be welcome!!
Thanks,
Fred
4thesun is offline
#17 Old 06-13-2015
ABS/BAS/ESP lights - top - HELP!!! now cruise and tranny
[QUOTE=4thesun;2125594]Had the same problem today. Started the car, put down the top, ABS/BAS/ESP lights went on and the top would not go up until I turned off the ignition, turned the key to position 2 (all lights on, no cranking) and the top went up.
As an aside, I just had it in 4 days before this started to have the motor and transmission mounts replaced, oil change, state inspection.
I will try to find the main oil tank in the boot which controls the roof to see if it may be low on oil. Where is that, anyone? If all looks good then I may have a bad limit switch for the roof?
Thanks,
Fred
First, I don't know how SLK 320 got here (my mistake I'm sure) this is an SLK 230 2001, 145,000 miles, daily driver.
New info. So on my way home I found that the cruise control no longer worked.
Next, went to the grocery and the car has difficulty shifting into gear, once it gets there, it will only run in 3rd gear. Car is parked in the driveway. I will try cleaning the board on the door lock pump again, but don't have a lot of hope about that.
Oh, yeah - the CHECK ENGINE light came on. I'll take a look at the codes and get back to you all.
This looks more and more serious -- or simple, I hope.
Help!
Fred
4thesun is offline
#18 Old 07-28-2015
Vehicle: 2001 slk320 sport
I have a slk320, 2001. The fog lights come on by themselves, no one in the car, no key in the car. Also, the head lights will intermittently go off. I turn the switch counterclockwise one position, then back to on position, the headlights come on. Sometimes the fog lights come on at this time and I have to turn the switch to off, on, off, on, many time to get the fog lights to go off. Replaced the $400 switch and still have the problem. Any suggestions, anyone?
cpnewell158 is offline
#19 Old 09-29-2015
Vehicle: R172 SLK 55 AMG 2012. Aluminium roll bars, Harmon Kardon, Carbon fibre package, Ambient lighting
Quoted: 8 Post(s)
I had a similar problem, turned out to be a sensor in the wheel, inexpensive fix
Mikeslk is offline
#20 Old 09-30-2015
I have been told that the BAS ESP indicates a failed brake switch or a failed computer. This man that told me this used to be a repairman in a MB dealership. On the passenger side, in the trunk, remove a panel and verify there is adequate hydraulic fluid in the reservoir.
Human Verification
  LinkBacks (?)
LinkBack to this Thread: http://www.slkworld.com/slk-r170-general-discussion/7381-help-abs-bas-esp-warning-lights-top-problem.html
Posted By For Type Date
forum mercedes abs | VIRGILIO Ricerca | Web This thread Refback 11-07-2008 08:41 AM
BAS/ ESP light on Miss B SLK R170 General Discussion 5 08-20-2009 10:27 PM
BAS ESP Caption mun802 SLK R170 General Discussion 8 04-02-2009 03:48 PM
