Welcome to SLKWorld
Old 08-18-2008   #1 (permalink)
Vehicle: SLK 320 RED!!!
Default What's missing from my SLK boot?!
I have a collapsible wheel, but no inflator like it says in the manual. Should that be on the wee square thing on top of the wheel?
Should there also be wheel nuts or do you use the main ones off a wheel the car?
Might there be something under the wheel? Sorry, a bit weedy or I'd wrestle the wheel out and look!
Can anyone help?
thanks
Shona
View shonaslk's Photo Album shonaslk is offline
Old 08-18-2008   #2 (permalink)
Founding Member #7
mtiede's Avatar
Yup, I believe the pump is under the wheel. And if you rock the inflatable tire side to side, it is easier to get in and out.
Old 08-19-2008   #3 (permalink)
Click it or Ticket!
SLKCop's Avatar
Don't use the wheel bolts from the primary tires. When you use the spare, you must use shorter bolts, otherwise damage will occur.
Mike
2002 Black SLK-230
View SLKCop's Photo Album SLKCop is offline
Old 08-19-2008   #4 (permalink)
Just had another look.
No pump, no nuts...
Back on the phone to the dealer tomorrow...
Old 08-19-2008   #5 (permalink)
Founding Member #7
mtiede's Avatar
Wow, and you took the wheel out? On mine the nuts are in a kind of plastic shrink wrap thingee under the wheel.
What about the Jack and the wheel change alignment tool?
Old 08-20-2008   #6 (permalink)
No, nothing under the wheel.
The Jack's on the right, but what's the wheel change alignment tool?!
Shona
Old 08-22-2008   #7 (permalink)
Senior SLK World Member
Vehicle: 2002 slk230K 2008 Honda CRV
Do you have the little tool kit (useless) and first aid kit??
View livefreeordie's Photo Album livefreeordie is offline
Old 08-22-2008   #8 (permalink)
Founding Member #7
mtiede's Avatar
The alignment tool is a little aluminum rod with wheel threads on one end. When you are taking a wheel off and then putting one back, you remove the top bolt first, screw in this rod. Then remove the rest of the bolts and slide the wheel off the rod. When replacing the wheel, just slide it back over the rod and then all the bolt holes will be aligned. No fooling around trying to line up the holes during a time when your hands are around the wheel well waiting to get smashed.
Old 08-22-2008   #9 (permalink)
Is the spare tire (collapsible) similar in the R170 to the R171? Does the R170 come with an air pump also? (Just asking, as I am not familiar with the R170).
Old 08-22-2008   #10 (permalink)
Click it or Ticket!
SLKCop's Avatar
Yes, and yes.
Mike
2002 Black SLK-230
The Following User Says Thank You to SLKCop For This Useful Post:
Old 08-22-2008   #11 (permalink)
yes..... and ..... no.....
but figured the first aid kit might be a bit expired by now anyway...
Old 08-22-2008   #12 (permalink)
Founding Member #7
mtiede's Avatar
Oops. Either I didn't notice it was a 320 or OP added that after my post. Don't remember exactly how things were in the 320, but I know I had the wheel tool. I think with the 320 there was a little tool kit wrapped in cloth and the tool was in that. Sorry for any confusion caused.
Old 08-22-2008   #13 (permalink)
you can always refresh it, I change mine at least once a year.
Missing windscreen jd320 General Discussion 3 09-23-2008 12:14 PM
old slk boot size ad mpg vegard_dino General Discussion 3 03-31-2008 07:22 PM
Is a cap missing from this tube? reallife Ask DansSLK 9 12-19-2007 01:27 PM
SLK R171 Boot Tub with SLK Lettering For Sale Andy747 SLK R171 General Discussion 0 05-06-2007 04:05 PM
Missing Posts DesignoSLK Help and Support 5 01-01-2007 12:05 AM
