Welcome to SLKWorld
Old 07-09-2008   #1 (permalink)
Click it or Ticket!
SLKCop's Avatar
Default Gas Consumption SLK230 top up/down results
Ok, as promised in an earlier thread, here's the final results of my 'research' regarding gas consumption while driving with top up and top down.
In order to keep things as consistent as possible I use the same gas station [QuikTrip, 93 octane] for both tanks of the test. I also ensured the tire pressure was the same for both tanks [30 front / 33 rear]. I didn't run the tank all the way empty on either test, but I tried to refill as close as possible, so for the top up test I drove 301 miles and for the top down I drove 259 miles. I don't have any modifications to the engine/air intake/etc. It's all stock.
On both tanks, I drove maximum of 70 mph, using cruise control as much as possible to maintain the same speed.
With the top closed up I used 11.371 gallons for 301.0 miles. That equates to 26.471 miles per gallon.
With the top down I used 9.677 gallons for 259.0 miles, which equates to 26.764 miles per gallon. Slightly better!
The week I drove with the top down was slightly cooler than the week with the top up, so I don't know how much that affects gas mileage, but all in all it appears as though I get almost exactly the same gas mileage regardless of whether the top is up or down.
Mike
2002 Black SLK-230
View SLKCop's Photo Album SLKCop is offline
The Following 4 Users Say Thank You to SLKCop For This Useful Post:
Old 07-09-2008   #2 (permalink)
Senior SLK World Member
KTownAMG's Avatar
Vehicle: 09 SLK AMG 55
Interesting comparison, I'll have to try that with mine. I'm actually glad to see the price of oil has actually gone down the last couple of days, we'll see how long that lasts... BTW, I can't remember if I told you or not, my wife and I will be SATX the week of 18 August, any chance you'll be around?
View KTownAMG's Photo Album KTownAMG is offline
Old 07-09-2008   #3 (permalink)
Donation Level 6
That's interesting. On my previous car, an Audi TT roadster, we got around 25% better MPG with the top up. I haven't done a formal test on my current car, but I think it does better with the top up. We're going on a 2000 mile roadtrip in August and I'll try it then.
View Tummy's Photo Album Tummy is offline
Old 07-09-2008   #4 (permalink)
Vehicle: 2002 slk230K 2008 Honda CRV
26 seems low, i have the same year/model and get around 30 hiwy.
View livefreeordie's Photo Album livefreeordie is offline
Old 07-11-2008   #5 (permalink)
Click it or Ticket!
SLKCop's Avatar
Yeah, when I'm doing only highway driving, I get 29-30 mpg. This was a mixture of highway and city driving, mostly highway, though.
Mike
2002 Black SLK-230
Old 07-11-2008   #6 (permalink)
Click it or Ticket!
SLKCop's Avatar
How long will you be there? I won't be off work until that Wednesday & Thursday. Maybe we could meet halfway, depending on your schedule? I think Kevin [DesignoSLK] is also going to be in the area around the same time if I remember correctly.
Mike
2002 Black SLK-230
Old 07-15-2008   #7 (permalink)
DesignoSLK's Avatar
Vehicle: 2000 Designo SLK230
Donation Level 3
That depends largely on KTownAMG, in an indirect way. I'll give you a call and explain.
Steve, just so you know, work sucked this weekend.
Kevin
An American in Germany...
Old 07-15-2008   #8 (permalink)
Vehicle: '09 SLK 350, Capri Blue/Black interior, Premium, Heating, AMG hood fins, window tint (a must in TX)
Other Toys: Sold my motorcycle /cry
I'll be around the 18th of Aug for sure, as I live in SA .
For the top up/top down mpg comparison, I think the top down decreasing mpg really only comes into play at highway speeds over 65mph so if you did any city driving at all, even if it was just 20% of the total miles driven, it could skew your numbers down to make top up/top down appear more even. At any rate, the SLK has a relatively low profile and small footprint, especially the kompressor version, so top down driving would only alter wind resistance slightly. The mpg should be pretty darn close, within 1-2mpg tops I would say, even for 100% highway driving. Wind screen could come into play as well (having vs not having one that is).
The only way to get a "truely" accurate comparison would be to pick the same 150-200 mile stretch of highway, going the same direction, approximately the same temp/heat index (affects road temp therefore tire "stickyness"/traction which *could* in theory affect mpg), with the same amount of wind within a mph or 2 coming from the same direction. Real world tests are very difficult to make very "scientifically accurate". Personally, I'll just take your results and run with them as my reason to drive with the top down!
View cousjcc's Photo Album cousjcc is offline
Old 07-29-2008   #9 (permalink)
SLK World Junior Member
Vehicle: SLK 200, 2000 (R170)
How is consumption related to speed? Any relation to torque too? I know that it's not the only rule "you drive slower - you use less gas". I think we'r getting close to science and SLK's now
View matejo's Photo Album matejo is offline
Old 07-29-2008   #10 (permalink)
Donation Level 6
Wind resistance increases approximately with the cube of the speed, so for the same distance the energy required is approximately proportional to the square of the speed.
The engine is the most fuel efficient at the torque peak.
Ike and the results of Gustav UK-C200 Off Topic 2 09-13-2008 12:33 AM
my slk230 can not open the top nycboy55 Help and Support 3 01-21-2008 03:25 PM
SLK350 dyno results Ynot General Modifications R171 2 01-11-2007 08:48 AM
Dragstrip Results FishtailnZ SLK R171 General Discussion 15 08-25-2006 10:18 AM
Dyno results thread easty Performance MODS for the R171 7 08-20-2006 02:06 PM
