Windrestrictor
Old 07-05-2008   #1 (permalink)
Default car keys wont work
can anyone help me.. ive changed the batteries for my keys but the remote still doesnt work.. i tried a lot of different kind of batteries but it still doiesnt work.. what could be the problem?
View entrepid's Photo Album entrepid is offline
Old 07-05-2008   #2 (permalink)
SLKman's Avatar
Donation Level 5
If the old batteries were not completely dead, put them back in and see if the door locks work. (Sometimes batteries gain a little power once removed.)
Make sure they are facing down when you put them in.
Make sure you put the correct matching batteries in ...CR2025.
SLKman
View SLKman's Photo Album SLKman is offline
Old 07-07-2008   #3 (permalink)
thanks sir slkman.. i tried it already i also tried a lot of fresh batteries.. but it still doesnt work.. what could the other reasons be?
Old 07-07-2008   #4 (permalink)
SLKman's Avatar
Donation Level 5
Purely a guess but maybe it has to be reprogrammed by dealer?
Hope someone here with more knowlegde will chime in.
Sorry I can't help.
SLKman
Old 07-08-2008   #5 (permalink)
Vehicle: 1998 SLK 230 Kompressor, Brilliant Silver, Anthracite cloth interior (JDM Import)
I did the same as SLKman..............just changed the batteries, and it works fine.
View Don B.'s Photo Album Don B. is offline
Old 07-09-2008   #6 (permalink)
Donor Conversion
jonathan's Avatar
Vehicle: Lovely Black SLK32
Donation Level 6
Hi Entrepid
I replaced the batteries in mine; you're supposed to do the reprogramming sequence described in the manual. Sorry can't remember the details but if you don't have them let me know and I'll look it up when I get home.
You can see if your batteries work by pressing the button on the keyfob and watching the little light flash -- two very brief little flashes, almost invisible, then one long flash is what mine do. The key seems pretty robust: I put mine on non-fast colours at 40 C and two hours in the tumble dryer without any problem.
Hope that helps.
Best regards,
Jonathan.
PS mine is a pre-facelift R170.
View jonathan's Photo Album jonathan is offline
Old 09-17-2008   #7 (permalink)
how do i reprogram the keys?
Old 09-17-2008   #8 (permalink)
Donor Conversion
jonathan's Avatar
Donation Level 6
Hi Entrepid
Manual says:
If you are unable to lock or unlock the vehicle with the remote control, the remote control may have to be resynchronized.
  • Aim transmitter eye at vehicle and briefly press transmit button LOCK or UNLOCK twice.
  • Within approximately 30 seconds insert key in steering lock and and turn it to position 2
The remote control should once again be operational.
Position 2 is normal engine-on position. (Position 0 is when you put the key in. Very German numbering!)
Hope that helps. I don't know if all the models are the same.
Regards,
Jonathan
keys and tags 320 dreamer SLK R170 General Discussion 7 3 Weeks Ago 08:59 AM
Does the car have to be on for the Gas Guage to work? DashingDaryl SLK R170 General Discussion 2 09-13-2008 03:57 AM
SLK 230 Wont Rev Above 4300 RPMs bumanng Ask DansSLK 13 08-04-2008 07:56 AM
1998 SLK wont run high RPMs in any gear bumanng Ask DansSLK 1 08-02-2008 03:41 PM
car keys problem entrepid SLK R170 General Discussion 4 06-26-2008 05:39 AM
