Go Back   SLK World Forum > Mercedes Benz R170 SLK Class Cars > SLK R170 General Discussion
Tire Rack- Revolutionizing Tire Buying
Old 05-27-2008   #1 (permalink)
SLK World Junior Member
Default Intermittent indicator failure...
Hoping someone may have a clue...my dealer certainly doesn't.
I have an SLK32 AMG (2003). It's ran pefectly for the last 3 years, except for the indicaotrs failing on numerous (intermittent) occasions.
It always seems to happen when the service dept is closed. But even when I've driven straight there, nothing is logged in the car's memory as a fault.
This, to be frank, is driving me nuts.
FYI, the control unit, and the multi-function indicator stalk have both been replaced under warranty...unnecessarily as it turned out.
Any suggestions as to the cause, or any similar experiences would be much apprciated.
Thanks.
View Rhino's Photo Album Rhino is offline   http://www.slkworld.com/Boss Key
Old 05-27-2008   #2 (permalink)
DesignoSLK's Avatar
Vehicle: 2000 Designo SLK230
Donation Level 3
Welcome to SLKWorld Rhino!!
When you say "indicators", are you referring to the turn signals?
You might want to pose this question to Dan in DanSLK. You'll probably get more of a response.
View DesignoSLK's Photo Album DesignoSLK is offline   Boss Key
intermittent windshield wipers dont work Hunter AMGs 8 03-30-2008 10:18 PM
SLK350 spring failure pjgraham86 General Discussion 4 01-14-2008 01:07 PM
Transmission Failure CDN-SLK55 SLK R171 General Discussion 15 03-23-2007 06:43 PM
HD Failure easty Off Topic 14 10-20-2006 08:05 PM
Power failure bejak SLK R171 General Discussion 4 09-30-2006 02:26 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
